Help needed with wiring flamethrower coil
Leo the biker
Leo the biker is offline
PostPosted: Fri May 10, 2024 9:51 am    Post subject: Help needed with wiring flamethrower coil Reply with quote
Hi guys, my trike has a petronix flamethrower coil and electronic ignition. I have just rewired all the ancillaries, while I was doing it, I found a wire that had one end connected to the coil, the other didn't connect to anything so I removed it. The trike now won't start, i haven't done anything else with the coil wiring. It has one wire from the ignition to the positive side and 2 wires from the negative side going to the distributor. I'm told that the trigger wire goes to the tachometer, but I don't have one. It also seems odd that 2 negative wires go to the distributor. Someone did look and tried to get it started, so they may have swapped wires around. Thanks in advance for any help.
Schepp
Schepp is offline
PostPosted: Mon Jul 15, 2024 10:03 am    Post subject: Re: Help needed with wiring flamethrower coil Reply with quote
A thick black wire comes from the ignition switch to + side of coil.
Red wire from electric distributor wires goes to + coil side. Black goes to - coil side.
The random (-) wire may have gone to a tach or ?.
The reverse lights are also powered by the (+) side of coil.
That's all that would normally be connected to a coil.
