Beetle 1962 | The Correct Tail Light Position
eriksonalex1307
eriksonalex1307 is offline
PostPosted: Tue May 13, 2025 4:00 am    Post subject: Beetle 1962 | The Correct Tail Light Position Reply with quote
Hello All,
I have a 1962 Beetle with no hole for mounting the tail light.
Could anyone help me the correct measurement position for 1962 tail light ?? If we measure it from the fender lips that attach to the rear apron.
I attach a photo to give a clear explanation for my question. The tail light i use would be the same as my photo
Thank you.
Erik
eriksonalex1307
PostPosted: Tue May 13, 2025 4:03 am    Post subject: Re: Beetle 1962 | The Correct Tail Light Position Reply with quote
Anybody could help me with details measurement ?? Or Drawing ?? As per my understanding, it should need 3 holes on each fender.
Thank you
sportin-wood
sportin-wood is offline
PostPosted: Tue May 13, 2025 9:48 am    Post subject: Re: Beetle 1962 | The Correct Tail Light Position Reply with quote
From the gallery
Dave
1966 Bug project
1973 Thing project
rcooled
rcooled is offline
PostPosted: Tue May 13, 2025 12:25 pm    Post subject: Re: Beetle 1962 | The Correct Tail Light Position Reply with quote
That dimension marked in your photo is 10.16cm, or exactly 4 inches, measured from the edge of the fender bead to the edge of the tail light gasket.
eriksonalex1307 wrote:
...it should need 3 holes on each fender.
Yes, three holes is correct...two 6mm holes to mount the housing and one a bit larger for the wires. The hole for the wires is approximately 46mm up from the lower mounting hole and in line with the other two.
'63 Ragtop (current)
'65 Ghia coupe (totaled)
'69.5 Ghia convertible and
eriksonalex1307
PostPosted: Tue May 13, 2025 12:56 pm    Post subject: Re: Beetle 1962 | The Correct Tail Light Position Reply with quote
Thank you for the drawing and explanation. Appreciated it very much.
my3bugs
my3bugs is offline
PostPosted: Tue May 13, 2025 1:02 pm    Post subject: Re: Beetle 1962 | The Correct Tail Light Position Reply with quote
sorry no help here BUT maybe you know someone with a good fender ???
this is such a common question not just for your year but for all year bugs . after market fenders rarely have the holes in the right place ...... for a split and oval bugs i have made paper templates to send to friends for there projects .... im suprised no parts venders have these simple to make templates available for the different years .
here is a HEART tail light template and a copy of it i made for a friend
eriksonalex1307
PostPosted: Tue May 13, 2025 3:01 pm    Post subject: Re: Beetle 1962 | The Correct Tail Light Position Reply with quote
Well ... the one i need is for 1962
