cdennisg Samba Member
Joined: November 02, 2004 Posts: 21009 Location: Sandpoint, ID
Posted: Thu Feb 26, 2009 11:26 pm Post subject: Does anyone know these carbs? |
Does anyone know what these carbs and intakes fit? I rediscovered them in one of my boxes of stuff and I don't recall exactly where I got them.
I have a pair. They are identical (I think) but I have no linkage.
Any ideas? _________________ Confusious say it takes it takes two wipes to know you need three, but it takes three wipes to know it only needed two. |
miniman82 Samba Swamp Donkey
Joined: March 22, 2005 Posts: 9515 Location: Southern Maryland
Posted: Fri Feb 27, 2009 3:35 am Post subject: |
Gonna guess by the big 'W' on the side that they are Webers? _________________ Build thread: http://www.thesamba.com/vw/forum/viewtopic.php?t=212747
| Glenn wrote: |
| satterley_sr wrote: |
I just wanted to bitch but I'm getting no sympathy. |
Welcome to the Samba. |
volkenstein Samba Member
Joined: June 26, 2005 Posts: 871 Location: The Land of Oz
Posted: Fri Feb 27, 2009 5:42 am Post subject: |
Brazilian Webers too by the language on the metal plate on the fuel bowl. IIRC these pre-date the 34 Pict replacements. Do a search, someone else on TheSamba brought these carby types up maybe early last year.
Oh yeah, there's a brazilian guy that has popped in to join up last year. Maybe PM him (if you can find his posts!)?
HTH
Volkenstein _________________ 71 RHD AS Super - "Klaus"...
Wisdom of youth, energy of old age... |
joe cool Samba Member
Joined: August 20, 2006 Posts: 1262 Location: Yolo County CA
Posted: Fri Feb 27, 2009 8:12 am Post subject: |
Brazilian Weber DFV 228, I believe.
Rebuild kits are available from Portugal and Brazil. I would like to hear about a US supplier if anyone knows of one. |
Posted: Fri Feb 27, 2009 8:24 am Post subject: |
Thanks for the replies folks. I knew they were Webers, I figured that would be obvious. I also figured Brazilian from the text on the tag, but what vehicle were they for? I did a little searching, but I didn't find anything of significance. Thinking of setting up linkage to try to run these. If anyone knows of rebuild kits that would be great.
Thanks again, Corey _________________ Confusious say it takes it takes two wipes to know you need three, but it takes three wipes to know it only needed two. |
busman78 Samba Member
Joined: August 17, 2004 Posts: 4671 Location: Oklahoma City, OK
Posted: Fri Feb 27, 2009 10:52 am Post subject: |
| They are Weber DFV228, imported and distributed by CB Performance many years ago. You would have to contact CB to check availability of kits. |
Posted: Fri Feb 27, 2009 10:55 am Post subject: |
Thanks, will do. _________________ Confusious say it takes it takes two wipes to know you need three, but it takes three wipes to know it only needed two. |
vwstew Samba Member
Posted: Sun Dec 07, 2025 3:13 pm Post subject: Re: Does anyone know these carbs? |
| Thank you all, I just bought a set of these unmarked carbs.gonna search for rebuild kits. |
