Alleycat1990 Samba Member
Posted: Tue Jun 10, 2025 4:56 pm Post subject: Back seat woes |
I put a bunch of stuff under the backseat/Bed while I was working in my Vanagon. Now I cannot for the life of me open it. I pull the lever and grab the handle and now way will it open it is like it is stuck. Anyone have any ideas? _________________ 1990 Vanagon GL purchased fall of 2024
never winter driven and well maintained
minor repairs needed example odometer |
markswagen Samba Member
Joined: January 28, 2018 Posts: 1555 Location: san diego
Posted: Tue Jun 10, 2025 5:59 pm Post subject: Re: Back seat woes |
push down as you pull on the lever.
failing that.
_________________ markswagen {mobile mechanic} san diego area all early VW's cared for.
619 201 0310 |
Posted: Tue Jun 10, 2025 6:04 pm Post subject: Re: Back seat woes |
I have tried everything short of an exorcism. No cigar. Tomorrow morning I will try unscrewing the front panel. Or a stick of dynamite. Thanks. _________________ 1990 Vanagon GL purchased fall of 2024
Posted: Tue Jun 10, 2025 7:19 pm Post subject: Re: Back seat woes |
westfalia
tin top
1990 ?
tin top, the seat base just pulls up.
westy, early the button left to release the clip.
late pull it directly out for the same result.
push down on the seat base, as you do either. _________________ markswagen {mobile mechanic} san diego area all early VW's cared for.
619 201 0310 |
dhaavers Samba Member
Joined: March 19, 2010 Posts: 8385 Location: NE MN (tinyurl.com/dhaaverslocation)
Posted: Tue Jun 10, 2025 7:38 pm Post subject: Re: Back seat woes |
Sit hard & heavy on the seat, pull the pin, lift the seat.
…and may God be with you. <sign of the cross>
- Dave _________________ 86 White Wolfsburg Westy Weekender
"The WonderVan"
Posted: Wed Jun 11, 2025 3:34 am Post subject: Re: Back seat woes |
I tried all 180 pounds of me pushing on the back kneeling on it.I put my arm through the little hole. Looked it up in Bentley so I could see what the mechanism looks like . It might as well be a kids drawing.
Not a tin top. _________________ 1990 Vanagon GL purchased fall of 2024
dobryan Samba Member
Joined: March 24, 2006 Posts: 17136 Location: Brookeville, MD
Posted: Wed Jun 11, 2025 5:09 am Post subject: Re: Back seat woes |
Alleycat1990 wrote: |
Not a tin top. |
It likely has something under the seat that has shifted and is blocking the release lever. You may need to get creative to find a way to move anything that is near the latch mechanism. _________________ Dave O
The Western Syncro build
Posted: Wed Jun 11, 2025 5:19 am Post subject: Re: Back seat woes |
Thanks for the suggestions much appreciated. I tried that last night I am going to try again this morning with a fresh brain and a large Expresso or a bigger hammer N.  _________________ 1990 Vanagon GL purchased fall of 2024
vanis13 Samba Member
Joined: August 15, 2010 Posts: 4382 Location: ABQ NM USA.... Except when not
Posted: Wed Jun 11, 2025 5:24 am Post subject: Re: Back seat woes |
Grind off the heads on the carriage bolts (near delete in this picture), push the bolt shanks back and the mechanism (hopefully) pulls up.
.... And then delete this latch as in this post (second page does an alternate way to prevent locking without deleting latch)
https://www.thesamba.com/vw/forum/viewtopic.php?t=721523
Alternately, you may be able to reach in from behind the seat, from the engine lid side, to dislodge the offending item.... You may also be able to get to the screws on the hinges that hold the seat to remove them to show even more room from the back. _________________ 83.5 Westy with Subaru 2.5, 4 spd manual, center seat, COLD A/C on 134a!, Winter camp heated with an Espar B4 gasoline furnace
www.SuperVanagon.com - some stuff I make |
Posted: Wed Jun 11, 2025 5:28 am Post subject: Re: Back seat woes |
Now that is the picture and instructions needed! Mega thanks _________________ 1990 Vanagon GL purchased fall of 2024
Posted: Wed Jun 11, 2025 10:11 am Post subject: Re: Back seat woes |
I tried everything still could not get it open . I took my sawmill and cut the u bracket. Now I need to find one. _________________ 1990 Vanagon GL purchased fall of 2024
Posted: Wed Jun 11, 2025 10:13 am Post subject: Re: Back seat woes |
I tried everything still could not get it open . I took my sawmill and cut the u bracket. Now I need to find one. |
how did you get to it? _________________ 83.5 Westy with Subaru 2.5, 4 spd manual, center seat, COLD A/C on 134a!, Winter camp heated with an Espar B4 gasoline furnace
Posted: Wed Jun 11, 2025 10:17 am Post subject: Re: Back seat woes |
2 pieces of hardwood with a 4 foot crowbar. _________________ 1990 Vanagon GL purchased fall of 2024
Posted: Wed Jun 11, 2025 10:37 am Post subject: Re: Back seat woes |
vanis13 wrote: |
how did you get to it? |
2 pieces of hardwood with a 4 foot crowbar. |
by lifting up the back / from the engine side or something else?
I can tell its frustrating for you and clarity will help the next person afflicted with this. You are not the first. _________________ 83.5 Westy with Subaru 2.5, 4 spd manual, center seat, COLD A/C on 134a!, Winter camp heated with an Espar B4 gasoline furnace
ALIKA T3 Samba Member
Joined: July 30, 2009 Posts: 7179 Location: Honolulu,Hawaii and France
