trilogymac Samba Member
Posted: Wed Apr 09, 2025 8:22 am Post subject: Bug VS bus Torsion housing to swingaxle centerlines |
Im building a set of adapters to install RGB,s in my bug. Are the torsion housing to axle centerlines the same?
Thanks!!
Bill |
jsturtlebuggy Samba Member
Joined: August 24, 2005 Posts: 4578 Location: Fair Oaks/Orangevale, CA
Posted: Sun Apr 13, 2025 8:00 pm Post subject: Re: Bug VS bus Torsion housing to swingaxle centerlines |
Yes they are the same distance apart. If you just making a J type of block to attach reduction box to spring plate, you will actually need to cut off end of spring plate where it would slip around Bug axle tube.
Find the original Baja Prepping VW Sedans & Dune Buggies by Bob Waar. My copy was printed in 1970.
The book has pictures of what you want to do. _________________ Joseph
Elrod Motorsports
Motion Tire Motorsports
Into Volkswagens since 1960 |
BFB Samba Member
Posted: Mon Apr 14, 2025 5:50 am Post subject: Re: Bug VS bus Torsion housing to swingaxle centerlines |
or just go ahead and build a 4 link for it so you can eliminate the anti- squat now vs. later _________________ "how am i supposed to torque the rear wheel nut to 250 ft lbs??? " - clonebug
Most experts aren't. |
Posted: Tue Apr 15, 2025 4:40 am Post subject: Re: Bug VS bus Torsion housing to swingaxle centerlines |
Thank ya'll very much!
Best,
Bill |
Dale M. Samba Member
Joined: April 12, 2006 Posts: 20765 Location: Just a tiny bit west of Yosemite Valley
Posted: Tue Apr 15, 2025 7:17 am Post subject: Re: Bug VS bus Torsion housing to swingaxle centerlines |
Don't forget to flip the ring gear in transaxle.... _________________ “Fear The Government That Wants To Take Your Guns"
Posted: Tue Apr 15, 2025 8:25 am Post subject: Re: Bug VS bus Torsion housing to swingaxle centerlines |
I have a rebuild 1964 B&D transmission (MI) that has never been installed. I'm going to take the tranny and the RGB parts to them and have them inspect and assemble everything. I think I need a different nose cone to fit the 64 in my 57 as well.
Thanks for all the help.
Thanks,
Bill |
