Door sill screws
modoc_333
modoc_333 is offline
PostPosted: Mon Apr 28, 2025 6:11 pm    Post subject: Door sill screws Reply with quote
71 Ghia. Does anyone know the exact screw that holds the metal door sill down? I need to buy some.
jpajya
jpajya is offline
PostPosted: Mon Apr 28, 2025 7:54 pm    Post subject: Re: Door sill screws Reply with quote
I think this may be what you're looking for (VW Part#:N139541)
https://airheadparts.com/vw-part/screw-panhd-phillips-sheetmetal-2-9x13/
John
'70 Ghia convertible
modoc_333
PostPosted: Tue Apr 29, 2025 8:49 am    Post subject: Re: Door sill screws Reply with quote
I think they should be flat rather than panhead.
jpajya
jpajya is offline
PostPosted: Tue Apr 29, 2025 10:07 am    Post subject: Re: Door sill screws Reply with quote
okay, but I can tell you that these panhead screws work fine, and are more similar than a flathead to the "filister head" called for on page 8-77 of the parts manual.
https://www.thesamba.com/vw/archives/manuals/1972_...201972.pdf
John
modoc_333
PostPosted: Tue Apr 29, 2025 2:37 pm    Post subject: Re: Door sill screws Reply with quote
I think I used the wrong term. I really was just wondering if it were ok to be domed on top. Mine are all phillips head screws but flat across the top and tapered underneath more similar to thos shape. No idea if original. Probably not.
jpajya
jpajya is offline
PostPosted: Tue Apr 29, 2025 3:55 pm    Post subject: Re: Door sill screws Reply with quote
yes, it's okay to be domed on top. If you're looking to maintain original look, go with the panhead (domed) screws, like at the link I provided. Here's a separate discussion where TDCTIDI includes two pics of a sill with original screws.
https://www.thesamba.com/vw/forum/viewtopic.php?p=8860880&highlight=#8860880
However, if you do a search on "sill" for Ghias in the gallery, in some restorations, you'll also see use of screws that are tapered underneath. Reasons could be varied, whether personal preference, availability, better fit for aftermarket sill, or door alignment that is too tight/narrow to allow the original type screw.
https://www.thesamba.com/vw/forum/album_search.php...t_dir=DESC
John
Heiferman
Heiferman is offline
PostPosted: Thu May 01, 2025 7:26 pm    Post subject: Re: Door sill screws Reply with quote
I just remove mine from.my 1970. They were all rounded on top. #1 Philipps.
I will have to dig for the baggies if you want a pic.
- 1973 Thing, 1970 Ghia, some LandCruisers and an old Ambulance
SCG9860
SCG9860 is offline
PostPosted: Fri May 02, 2025 9:29 am    Post subject: Re: Door sill screws Reply with quote
Part # N139541 ST Airhead Parts.
modoc_333
PostPosted: Wed May 07, 2025 5:57 pm    Post subject: Re: Door sill screws Reply with quote
Thanks. That's exactly what I ordered the other day.
