Pitman arm and tie rods ends attached to a plate vs. each other.
Silverteener
Silverteener is offline
PostPosted: Wed Apr 30, 2025 7:49 am    Post subject: Pitman arm and tie rods ends attached to a plate vs. each other. Reply with quote
Hi everyone,
I'm working thru the front suspension of my 62' and the pitman arm and inner tie rod ends both attach to this plate instead of each other. I've search to see if I can find out what it is and what it's for but can't find anything about it. Can anyone tell me what it is and what it's for? Any help is greatly appreciated!
Thanks!
rcooled
rcooled is offline
PostPosted: Wed Apr 30, 2025 12:32 pm    Post subject: Re: Pitman arm and tie rods ends attached to a plate vs. each other. Reply with quote
That's not a VW part...both tie rods should attach directly to the pitman arm.
That piece was added by a previous owner to quicken the steering response and reduce the number of turns lock-to-lock.
It's not recommended for use in street-driven cars
This is the part > Quick Steering Kit
'63 Ragtop (current)
'65 Ghia coupe (totaled)
'69.5 Ghia convertible and
Silverteener
PostPosted: Wed Apr 30, 2025 12:36 pm    Post subject: Re: Pitman arm and tie rods ends attached to a plate vs. each other. Reply with quote
Thank you! I'll leave it off then. I appreciate the info!
jeffrey8164
jeffrey8164 is offline
PostPosted: Wed Apr 30, 2025 1:50 pm    Post subject: Re: Pitman arm and tie rods ends attached to a plate vs. each other. Reply with quote
It was sold as a “Quick Steer” kit so you don’t have to turn the steering wheel as far to make a turn.
I have one on my Ghia that I installed as a lark since I had it in my stash.
I’m pretty sure I will remove it at some point. It’s kind of nice in parking lots but at speed through the mountain twisties, it creates a lot of oversteer that can be rather hair raising.
Volkswagen!
(Compression 8.7:1)
