finky999 Samba Member
Posted: Sat May 03, 2025 2:33 pm Post subject: question from the mechanically challenged (heater) |
I'm considering buying a 1974 Thing. It's in Texas with no heater. I'll use it in North Carolina where it can get cold in the winter, or in the summer at night driving with no top.
1) how hard is it to find a device to keep the cabin warm? (it doesn't have to be original technology)
2) is it possible for a non-gear head to install?
Thanks in advance. Wish me luck on my purchase decision. |
KAmes Samba Member
Joined: February 16, 2014 Posts: 917 Location: Illinois
Posted: Sun May 04, 2025 5:55 am Post subject: Re: question from the mechanically challenged (heater) |
| Thanks. That's a good option to know about. |
mondshine Samba Member
Joined: October 27, 2006 Posts: 2819 Location: The World's Motor Capital
Posted: Sun May 04, 2025 7:43 am Post subject: Re: question from the mechanically challenged (heater) |
For the budget minded, a Chinese replicant of Kevin's Webasto might work for you.
https://www.amazon.com/VEVOR-Diesel-Bluetooth-Disp...9&th=1
At just over 100 bucks brand new, it could be hard to beat.
The only downside is that it burns Diesel, so you might keep a 5 gallon can of Diesel in your garage.
Alternatively, you could gather the parts to complete the heating system that came with your '74.
The stock heating in '74s works pretty well, at least down to 35º or so.
Good luck. |
doublecanister Samba Member
Joined: September 23, 2008 Posts: 1222 Location: Richmond, Va
Posted: Sun May 04, 2025 10:09 am Post subject: Re: question from the mechanically challenged (heater) |
hey finky999
Fastmc25 did a diesel heater install not too long ago...
https://www.thesamba.com/vw/forum/viewtopic.php?t=...p;start=40
Check it out, it was a nice install and he reported it worked fine for heat.
T _________________ ****************************************
2020 - Mustang Eco Boost [High Performance]
1973 - Thing
1966 - Mustang GT- Fastback
1951 - Ford F1 pickup Flathead V8 |
el_safari Samba Member
Joined: January 01, 2005 Posts: 400 Location: Nouvelle Aquitaine,France
Posted: Sun May 04, 2025 2:47 pm Post subject: Re: question from the mechanically challenged (heater) |
They are no parts left from the 1974 original heat system?
It use the heat from the motor like the beetle and it is enough for me where I live(Bordeaux)!  _________________ La terre n'est qu'un seul pays |
Schepp Samba Member
Posted: Tue May 13, 2025 1:07 pm Post subject: Re: question from the mechanically challenged (heater) |
I put a Chinese 2kw heater in my bug. I run it with kerosene, cleaner burn no stink. Tiny bit more expensive for the fuel.
A half gallon spun aluminum tank lasts a week of regular use on medium heat output.
I replaced all the common failure point, cheap connectors with waterproof Deutch DT connectors.
Get a small unit and run it on high, burns clean. If you get a bigger unit and run it on low, it'll clog up with soot fast.
The unit itself doesn't get hot. You can actually put your hand on it.
The heat output on high will fry an egg or dry off wet socks in 30min.
fastmc25 Samba Member
Joined: January 01, 2004 Posts: 1224 Location: East Tennessee
Posted: Tue May 13, 2025 2:17 pm Post subject: Re: question from the mechanically challenged (heater) |
8k unit
Works great. _________________ Peace,
Paul
1973 Type181 Kubelwagen (Thing 2 ) 2110cc
1971 Transporter (Pickle) 1914cc
1961 Deluxe Beetle (Christine) 1776cc
1973 Adventurewagen Baja Bus (Clyde) 3.4L
1970 Formula Vee Beetle 2276cc
I identify as: “A Grumpy Old Vet” |
jminer Samba Member
Posted: Wed May 14, 2025 11:12 pm Post subject: Re: question from the mechanically challenged (heater) |
| This post is full of great ideas. I've been contemplating what to do with heat on my 73 and the factory unit in it looks like it caught fire and melted pretty good. I like the idea of running a modern aux kerosene heater a lot. |
Schepp Samba Member
Posted: Sat May 17, 2025 7:10 pm Post subject: Re: question from the mechanically challenged (heater) |
I’ve read many cases of people plumbing the parking heater heat ducts straight into the heater channels in their VW’s with great results.
Any gas tank will work as long as is vented properly.
There’s lots of YouTube videos and articles about installing them and the do’s and don’ts. |
