OldBeetles Samba Member
Joined: October 10, 2024 Posts: 65 Location: Northeast
Posted: Tue May 06, 2025 4:08 am Post subject: Parking brake release lever popped off |
Hi all, I tried searching for this but to no avail.
So, I had someone drive my '60 and when they parked, they pulled up a little too hard on the parking brake lever which caused the release rod/button to pop out. I did some research and understand the way the hook on the metal rod is supposed to hook onto the pivoting lever, but could not for the life of me get it to "grab"
I was trying to do this while everything is still connected, by lifting the lever up high enough to free the pivoting lever that holds the parking brake in place, and on the other end holds the release rod.
Can this be done while everything is still connected? Is there a trick to it? |
Cusser Samba Member
Joined: October 02, 2006 Posts: 33577 Location: Hot Arizona
Posted: Tue May 06, 2025 6:34 am Post subject: Re: Parking brake release lever popped off |
This happened to my 1970, and I got it re-engaged, but this was over 4 decades ago and I cannot remember, but there was a trick to it. It's still OK to this day.
Wait for someone else to reply, don't panic. And you should adjust your rear brakes too so the lever doesn't raise too high. _________________ 1970 VW (owned since 1972) and 1971 VW Convertible (owned since 1976), second owner of each. The '71 now has the 1835 engine, swapped from the '70. Second owner of each. 1988 Mazda B2200 truck, 1998 Frontier, 2014 Yukon, 2004 Frontier King Cab. All manual transmission except for the Yukon. http://www.thesamba.com/vw/forum/album_page.php?pic_id=335294 http://www.thesamba.com/vw/forum/album_page.php?pic_id=335297 |
Posted: Tue May 06, 2025 7:18 am Post subject: Re: Parking brake release lever popped off |
| Cusser wrote: |
Wait for someone else to reply, don't panic. And you should adjust your rear brakes too so the lever doesn't raise too high. |
Thanks. Hopefully someone else will chime in. I have no idea how he did that, since it's adjusted properly. It only requires a small pull to hold the car, so he must have really cranked on it. |
wagen19 Samba Member
Joined: November 16, 2007 Posts: 912 Location: germany
Posted: Tue May 06, 2025 8:08 am Post subject: Re: Parking brake release lever popped off |
| OldBeetles wrote: |
| Cusser wrote: |
As far as I know, this can only happen, when the combination of parts as hand brake lever and sector handbrake is not original or not matching to car.
There are many different original parts of levers and sectors and additional aftermarket parts in not allways good quality. (wear?)
Allways good is, doing a proper service job on your car in time.
Handbrake: group 711
https://www.thesamba.com/vw/archives/manuals/1956%...201956.pdf |
zerotofifty Samba Member
Posted: Tue May 06, 2025 8:44 am Post subject: Re: Parking brake release lever popped off |
It is a trick to re-assemble. I recall I had to remove the lever to do it.
The cause is often that the cables are too slack, which allows the handle to be pulled up past the end of the ratchet teeth, then the little arm that engages the teeth flops out of place and she falls apart.
Once you get her back together you should tighten the cables to reduce the excess slack in them. I kind of recall, but memory is bad that when adjusted correct, it might be about four clicks of the ratchet is all you can get. I bet your handle came up pretty high to fully engage the emergency brake before this happened, a clear sign that the cables were too loose.
The cables can loosen as the shoes in the drum wear, and this is fixed by adjustments at the star wheel in the drum. when this is out of wack, your foot pedal for the brakes will have excessive travel
If the brake shoes are adjusted fine, then the cables can be adjusted at the emergency brake lever
So BEFORE adjusting cables at the lever, make sure the shoe gap is adjusted FIRST, then take up any additional excess slack at the emergency brake lever. adjust so you get around four*** clicks max, then you handle will no longer be able to go too far up, and come apart.
*** See factory manual for actual number of allowable clicks, it might be four. _________________ Sorry About That Chief.
Give Peace a Chance.
Words to live by. |
runamoc  Samba Member
Joined: June 19, 2006 Posts: 6490 Location: 37.5N 77.1W
Posted: Tue May 06, 2025 9:06 am Post subject: Re: Parking brake release lever popped off |
remove the brake cables, taking one loose is all that's needed, and swing them out of the way. Lift the arm up as much as you can, take your little finger or 'tool' and flip the 'catch thing' up as you press on the button to get the non geared side of the catch back into the hook of the push button rod. While pressing the button lower the lever all the way back down. Re-connect brake cables. Adjust them so the lever doesn't come up so high as to have this happen again.  _________________ Daily driver: '69 Baja owned 45 yrs - Plan B: '72 Ghia
Yard Art: 2 Sandrails
Outback: '69 Ghia - '68,'69,'70,'72 Beetle - '84 Scirocco, GTI - Pair of '02 Golfs- '80 Rabbit Diesel
VW Wiring = It's just wires |
Posted: Tue May 06, 2025 9:47 am Post subject: Re: Parking brake release lever popped off |
Thanks for the tips! I am going to make another attempt at this.
I don't think it needs adjustment though, because it holds firmly after 3 or 4 clicks. The guy who drove it really pulled hard on it, is all I can figure. |
KTPhil  Samba Member
Joined: April 06, 2006 Posts: 36455 Location: Conejo Valley, CA
Posted: Tue May 06, 2025 10:08 am Post subject: Re: Parking brake release lever popped off |
My rule of thumb was slight brake drag at 2 clicks, firm hold at 4 clicks, superhuman pull to get 5 or more.
Any looser than this, I adjust the brake stars, then recheck the cable adjustment (including balancing the two on early models without the equalizing bar).
Another tip is to avoid cutting your buttcheek on the cable ends, which get buggered and sharp after a few adjustments: rubber brake bleeder caps over the cable ends, before you pull the boot back over them. _________________ Current Fleet:
- '71 Fastback
- '69 Westfalia
Retired:
- '67 Beetle
- '65 Beetle (x2)
- '65 Bus
- '71 Squareback |
gt1953 Samba Member
Joined: May 08, 2002 Posts: 13960 Location: White Mountains Arizona
Posted: Tue May 06, 2025 10:11 am Post subject: Re: Parking brake release lever popped off |
Mine did that and looked at an exploded view for reassembly...a lil tricky but not difficult. Easy to do with a seat out. _________________ Volkswagen: We tune what we drive.
72 type 1
72 Squareback
scrivyscriv Samba Electrician
Joined: October 04, 2011 Posts: 3390 Location: Memphis
Posted: Tue May 06, 2025 8:03 pm Post subject: Re: Parking brake release lever popped off |
[quote="gt1953"...a lil tricky but not difficult. Easy to do with a seat out.[/quote]
I second this! Either seat can come out for it _________________ Robert in Memphis
Engine rebuild thread
If you're ever in the Memphis area, you are welcome to stop by for advice and help. |
