Is this a Type 3 RHD drivers side footrest?
FunkyOldPatina
FunkyOldPatina is offline
PostPosted: Wed May 07, 2025 4:16 am    Post subject: Is this a Type 3 RHD drivers side footrest? Reply with quote
Hi guys,
I've seen beetle footrests before which this is similar to, but this one is different (yes I realise its RHD Wink) in that it has a fold where the accelerator pedal would go through?
Does anyone know what VW this is off? I have Google checked for Type 4 411/412 and nothing has come up for that, and this is the first of these I've seen.
Thanks guys.
Bobnotch
Bobnotch is offline
PostPosted: Wed May 07, 2025 11:15 am    Post subject: Re: Is this a Type 3 RHD drivers side footrest? Reply with quote
It might be a type 3 right side RHD foot plate. I only say that due to the distance of the clutch pedal slot from the brake pedal slot.
Bob 65 Notch S with Sunroof
Tram wrote:
Tram wrote:
FunkyOldPatina
PostPosted: Wed May 07, 2025 2:37 pm    Post subject: Re: Is this a Type 3 RHD drivers side footrest? Reply with quote
Thanks for your thoughts. I've not found a pic online of a LHD Type3 drivers foot plate to see if it is the mirror opposite of that?
Or maybe its a Type 34 or Thing plate?
Either way it's not one I've seen before Smile
gtixpress
gtixpress is offline
PostPosted: Thu May 08, 2025 7:38 am    Post subject: Re: Is this a Type 3 RHD drivers side footrest? Reply with quote
This is a LHD foot plate from my Squareback (1969).
Joe P.
1969 VW Type 3 Squareback
2002 VW GTI 337 (Limited Edition)
2018 VW Atlas SE VR6 4Motion
2019 VW Beetle S Final Edition Convertible
FunkyOldPatina
PostPosted: Thu May 08, 2025 2:30 pm    Post subject: Re: Is this a Type 3 RHD drivers side footrest? Reply with quote
Thanks, that looks completely different from mine unfortunately Sad
Ok, so I think its safe to say its not Type 3...
KTPhil Premium Member
KTPhil is offline
PostPosted: Thu May 08, 2025 2:59 pm    Post subject: Re: Is this a Type 3 RHD drivers side footrest? Reply with quote
Try contacting Samba member parmaynu.
About 9 years ago he said he sells replacement RHD Beetle pedal parts, and he may identify this for you.
Current Fleet:
- '71 Fastback
- '69 Westfalia
Retired:
- '67 Beetle
- '65 Beetle (x2)
- '65 Bus
- '71 Squareback
really-whale
really-whale is offline
PostPosted: Sat May 10, 2025 2:55 am    Post subject: Re: Is this a Type 3 RHD drivers side footrest? Reply with quote
First thought was that's for sure a RHD plate, but mine has a slightly more vertical clutch pedal opening. It does still seems like it would be from a RHD type 3 though?
I've included a picture of the one I have, it's off a ~71 RHD squareback pan.
Pete - '67 Aust. RHD Squareback - Build Thread - Engine Thread
View user's profile Send private message Visit poster's website Twitter Gallery Classifieds Feedback
FunkyOldPatina
PostPosted: Sat May 10, 2025 10:57 am    Post subject: Re: Is this a Type 3 RHD drivers side footrest? Reply with quote
Dude, you are a star! Thank you very much!
I had it narrowed down to a 412 (UK version of a 411) or a Thing or a Type 34.
Interesting how its so different from the one posted above by gtixpress? I was thinking this would pretty much be a mirror-image of a LHD tin but I guess I was wrong Laughing
really-whale
PostPosted: Sat May 10, 2025 1:40 pm    Post subject: Re: Is this a Type 3 RHD drivers side footrest? Reply with quote
Glad I could help! Yeah, the RHD pedal assembly is pretty different, and the reason it's not a perfect mirrror is that the pedals are still in the same order left to right for both LHD and RHD..
I'm assuming the plate you have there will be earlier and suit a pedal assembly where the stalk for the clutch pedal is angled outward more than mine. I'm not sure of the year to year differences there..
FunkyOldPatina
PostPosted: Sun May 11, 2025 1:57 pm    Post subject: Re: Is this a Type 3 RHD drivers side footrest? Reply with quote
It's exactly the same as yours, which is handy as yours is a 71 so later Type3.
My Type 3 knowledge ain't great - I know they changed from sloping front bonnet to more upright bonnet around 1967 but surprised if this changed the footwell area? I would be surprised but you never know with VW!
Bobnotch
Bobnotch is offline
PostPosted: Mon May 12, 2025 8:07 am    Post subject: Re: Is this a Type 3 RHD drivers side footrest? Reply with quote
The last of the "sloping front bonnet" was 69, for 70 VW changed the entire front end, then for 71 added 2 springs to replace the torsion bar set up, and kept it thru 73 when production stopped.
As far as I know, the floor pan didn't really change much. For 68-69 VW added some stiffening channels under the floor to meet safety requirements. Mid 68 also brought IRS with the AT models, then continued using it for 69 on. Sure you could still get a swing axle in the panel van version, but it was the extra heavy duty version. Also the front heater outlets were controlled by the lever on the tunnel, the tubing for the cables was tack welded to the floor pan (72-73).
I hope this helps.
Tram wrote:
Tram wrote:
ALLWAGONS
ALLWAGONS is offline
PostPosted: Tue May 13, 2025 12:48 pm    Post subject: Re: Is this a Type 3 RHD drivers side footrest? Reply with quote
It sure looks different. Compare it to this pic from the parts manual.
Bobnotch
Bobnotch is offline
PostPosted: Tue May 13, 2025 1:57 pm    Post subject: Re: Is this a Type 3 RHD drivers side footrest? Reply with quote
I would think a 411-412 would have foot plates without any slots, as they use hanging pedals. Nothing mounted to the floor. A Thing however could use those plates, as would a type 1 based Ghia, since both use the same pan.
Tram wrote:
Tram wrote:
