tommylg Samba Member
Joined: August 12, 2013 Posts: 154 Location: murfresboro tn
Posted: Wed May 14, 2025 6:33 am Post subject: starting fluid/2 oz fuel - starts then dies |
As the subject notes, with a spray of starter fluid and a dribble of fuel the car runs and then dies - much like fuel starvation.
I disconnected the hose to the pump and got zilch. I disconnected the hose from the pump to the carb and got zilch.
I disconnected the coil wire and cranked the motor hoping to prime the pump and got zilch.
Should I hear my pump actuating?
Before I dive in with a new fuel pump, any suggestions?
What a great start to the day(pun intended),
Tommy _________________ 1972 Super |
Cusser Samba Member
Joined: October 02, 2006 Posts: 33516 Location: Hot Arizona
Posted: Wed May 14, 2025 6:57 am Post subject: Re: starting fluid/2 oz fuel - starts then dies |
| tommylg wrote: |
| I disconnected the hose to the pump and got zilch. |
This is where to start. The line from the tank TO the fuel pump inlet must be clear to allow gasoline to flow. Disconnect the inlet line to the fuel pump; maybe jack up the front, or use rags and compressor in the fill pipe to see if gas will flow out the inlet line to the fuel pump. _________________ 1970 VW (owned since 1972) and 1971 VW Convertible (owned since 1976), second owner of each. The '71 now has the 1835 engine, swapped from the '70. Second owner of each. 1988 Mazda B2200 truck, 1998 Frontier, 2014 Yukon, 2004 Frontier King Cab. All manual transmission except for the Yukon. http://www.thesamba.com/vw/forum/album_page.php?pic_id=335294 http://www.thesamba.com/vw/forum/album_page.php?pic_id=335297 |
