no trans output shaft seal?!?
1974BeetleSD
1974BeetleSD is offline
PostPosted: Wed May 14, 2025 8:22 pm    Post subject: no trans output shaft seal?!? Reply with quote
So im back and i pulled the throwout bearing to change the leaky trans output shaft seal. Once i removed the throwout bearing and this metal tube, I see the following: is this an empty space where the seal is supposed to be??? I must be missing something, I can not believe the motor was installed without the output shaft seal. it is leaking, but a slow leak. (see old posts) what da hell??
1974BeetleSD
PostPosted: Wed May 14, 2025 8:23 pm    Post subject: Re: no trans output shaft seal?!? Reply with quote
here is the seal i purchased.
1974BeetleSD
PostPosted: Wed May 14, 2025 8:26 pm    Post subject: Re: no trans output shaft seal?!? Reply with quote
it probably wasnt leaking much because the trans was underfilled Brick wall
can anyone confirm or deny if that seal is supposed to go there Shocked Boo hoo!
Cusser
Cusser is offline
PostPosted: Thu May 15, 2025 7:11 am    Post subject: Re: no trans output shaft seal?!? Reply with quote
I would tap in the seal, absolutely !!!
My 1971 Super is still on its factory transmission seal (it's been mine since 1976).
I have replaced the transmission seal on my 1970 (mine since 1972). The 1970 transmission uses the "early" style release bearing.
Root_Werks
Root_Werks is offline
PostPosted: Thu May 15, 2025 1:55 pm    Post subject: Re: no trans output shaft seal?!? Reply with quote
Oh boy, yes, install a seal. That bellhousing looks pretty oily. Probably why.
When I set my timing, why do I flush, then take a pee?
bsairhead
bsairhead is offline
PostPosted: Thu May 15, 2025 2:55 pm    Post subject: Re: no trans output shaft seal?!? Reply with quote
White lithium grease is your friend.
