Rear suspension/geometry question
Bevan
Bevan is offline
PostPosted: Sun May 18, 2025 11:44 am    Post subject: Rear suspension/geometry question Reply with quote
I have a short shaft swing axle on my 1966 Squareback. At rest and driving forward the car has a bit of rear negative camber. Whenever I reverse the car I get positive camber. I have dialed in more toe in thinking it might be the issue but it still happens. Do I need to dial in some toe out?
Any suggestions are greatly received.
Thanks.
KTPhil Premium Member
KTPhil is offline
PostPosted: Mon May 19, 2025 8:52 am    Post subject: Re: Rear suspension/geometry question Reply with quote
Swing axle cars like a little toe-out at the rear anyway. It makes them more stable on undulating corners.
Current Fleet:
- '71 Fastback
- '69 Westfalia
Retired:
- '67 Beetle
- '65 Beetle (x2)
- '65 Bus
- '71 Squareback
Bobnotch
Bobnotch is offline
PostPosted: Mon May 19, 2025 10:41 am    Post subject: Re: Rear suspension/geometry question Reply with quote
Thanks.
That's just the way it was designed. It happens on stock height, raised (off road) or lowered. It's also why Ralph Nader killed the Corvair due to the rear of that car doing the same thing. VW ended up going to IRS to help solve this problem, as did Porsche and eventually GM did with the last years of the Corvair.
Bob 65 Notch S with Sunroof
Tram wrote:
Tram wrote:
Bevan
Bevan is offline
PostPosted: Mon May 19, 2025 12:46 pm    Post subject: Re: Rear suspension/geometry question Reply with quote
I had read that, reading what Bob said, I think I'll dial in some toe out and forget about it. I'll just make sure don't reverse when I park up Very Happy
Cheers Bob. That makes a lot of sense.
