DesertG Samba Member
Posted: Fri Jun 06, 2025 6:58 am Post subject: Fast Fab vs JayCee Spring Push Rod Tubes |
I see the Fast Fab's have a stainless steel washer on both ends of the tube as a backing to help keep the rubber seal seated.
The JayCee only has a washer backing on one end.
Which set should I get.
Thank you! _________________ 1965 Beetle, 1970 1600cc DP, 12v |
txoval Samba Member
Joined: January 23, 2004 Posts: 3842 Location: The Woodlands, TX
Posted: Fri Jun 06, 2025 7:18 am Post subject: Re: Fast Fab vs JayCee Spring Push Rod Tubes |
I use the FastFab…high quality
Unfortunately no experience with Jaycee’s tubes |
volky1970 Samba Member
Joined: November 11, 2006 Posts: 407 Location: A very hot Island with BUGS that KILL!!!
Posted: Fri Jun 06, 2025 7:52 am Post subject: Re: Fast Fab vs JayCee Spring Push Rod Tubes |
Thank you! But..that did not answer by question.  _________________ 1965 Beetle, 1970 1600cc DP, 12v |
Posted: Fri Jun 06, 2025 7:57 am Post subject: Re: Fast Fab vs JayCee Spring Push Rod Tubes |
DesertG wrote: |
Thank you! But..that did not answer by question.  |
There was a comment there about FastFab I wanted you to see. I have the Jaycee ones before EMPI acquired it. Never had an issue. Clean / wash them before install. _________________ 1970 Beetle Turbo 2109cc MS II EFI, W/M Injection, Intercooler, FORD Wasted Spark Coilpack, 48lb. Injectors. |
Posted: Fri Jun 06, 2025 8:01 am Post subject: Re: Fast Fab vs JayCee Spring Push Rod Tubes |
Oh. Thank you. _________________ 1965 Beetle, 1970 1600cc DP, 12v |
Alexander_Monday Samba Member
Joined: November 09, 2007 Posts: 399 Location: Springfield Missouri
Posted: Fri Jun 06, 2025 8:35 am Post subject: Re: Fast Fab vs JayCee Spring Push Rod Tubes |
I have original JayCee tubes before EMPI so I can't speak to the latest ones, but my originals have been leak free and came with washers for both ends. I did replace the o-rings this last time because they were getting a little wear from removal and install and I used Nitrile 22mm OD 2mm width. Be sure and use a little lubricant on the o-rings. _________________ Danth’s or Parker’s Law:
“If you have to insist that you've won an internet argument, you've probably lost badly.”
Alexander_Monday->What were the rings gapped at?
bedlamite->Almost enough.
andk5591 wrote: |
The original german engineers have attained sainthood and it is impossible to improve perfection.
Anything that anyone does to deviate from the original designs will be made to wrench on 20 year old Yugos with Harbor Freight tools in hell. |
Posted: Fri Jun 06, 2025 8:57 am Post subject: Re: Fast Fab vs JayCee Spring Push Rod Tubes |
Thank you. Maybe I am missing something but if I look at Jaycee, the one end of the tube is not machined to take a washer _________________ 1965 Beetle, 1970 1600cc DP, 12v |
chrisflstf Samba Member
Joined: February 10, 2004 Posts: 4059 Location: San Diego
Posted: Fri Jun 06, 2025 10:03 am Post subject: Re: Fast Fab vs JayCee Spring Push Rod Tubes |
DesertG wrote: |
Thank you. Maybe I am missing something but if I look at Jaycee, the one end of the tube is not machined to take a washer |
I got mine a long time ago at a local shop.
I did find this pic of the original JayCee packaged ones and it appears they only had washers for one end in that package so maybe Steve (the shop owner) gave me extra washers for the other end?
andk5591 wrote: |
txoval Samba Member
Posted: Fri Jun 06, 2025 7:02 pm Post subject: Re: Fast Fab vs JayCee Spring Push Rod Tubes |
I bought the Fast Fabs in 2019, used them on 3 different engines.
I imagine they are the same design as Jaycee, but anodized.
Seems like the most common reason for leaks now is the seal cut at the heads…not a pushrod tube problem. |
Posted: Sat Jun 07, 2025 2:30 pm Post subject: Re: Fast Fab vs JayCee Spring Push Rod Tubes |
Since I am in between engines, I pulled one out of the drawer.
The JayCee's I have have 2 different size valve spring shims for washers.
andk5591 wrote: |
74 Thing Samba Member
Posted: Sat Jun 07, 2025 3:34 pm Post subject: Re: Fast Fab vs JayCee Spring Push Rod Tubes |
Those are just valve spring shims. Jaycee/Empi now provides a stainless washer in the kit. The valve spring shims you have are wider then the washer they currently provide so it supports the seal better (obviously you have 2 different shims-I would use the widest necessary to support the entire pushrod tube seal. |
