VW2024 Samba Member
Posted: Thu May 29, 2025 6:05 pm Post subject: Trans whine coasting |
57bug. New to me today
PO installed 1641DP 12v and
Freeway flyer May’21
Used original (57?) axle tubes (assume axles) per receipt
Whines all gears off power-coasting
Looking for advice.
Do 57 axles match up to later trans?
Trans issue?
TIA! |
esde Samba Member
Joined: October 20, 2007 Posts: 6333 Location: central rust belt
Posted: Thu May 29, 2025 9:40 pm Post subject: Re: Trans whine coasting |
I assume it's a later tunnel style transmission, and not the earlier split case trans..
whines in all gears huh?
Does it whine in neutral coasting?
My first and second guess would be something is wrong with the ring and pinion _________________ modok wrote:
VW_Jimbo  Samba Member
Joined: May 22, 2016 Posts: 11161 Location: Huntington Beach, CA
Posted: Thu May 29, 2025 10:13 pm Post subject: Re: Trans whine coasting |
What happens when coasting in neutral, clutch not engaged?
Is one side louder than the other? During turns? _________________ Jimbo
TDCTDI wrote: |
67rustavenger wrote: |
GFY's Xevin and VW_Jimbo!  |
wagen19 Samba Member
Joined: November 16, 2007 Posts: 673 Location: germany
Posted: Thu May 29, 2025 10:28 pm Post subject: Re: Trans whine coasting |
esde wrote: |
My first and second guess would be something is wrong with the ring and pinion |
Check your rear brake drums and 36 mm nuts first. It´s quite possible, the drive shaft turns "free" inside one drum. (had that several times, when teething inside drums has wear, or nuts were not tighten properly)
With luck, it´s only one brake drum to replace, but the splines of drive shaft may also be damaged. Is there oil around the 36 mm nut? Are the nuts loose?
If a drum sits loose on drive shaft, you allways will get problems, even with 36 mm nuts torqued very properly! (overtorqued)
If not, think about a clutch issue. |
Bub Samba Member
Joined: June 10, 2004 Posts: 1300 Location: Central Washington
Posted: Fri May 30, 2025 7:27 am Post subject: Re: Trans whine coasting |
Check the gear oil obviously, but beyond that sounds like worn differential or incorrect backlash on ring/ pinion.
In 4th at regular speed going down the road if you let off the gas does it whine like that? If it does it’s worn ring gear. _________________
hitest wrote: |
Had a girlfriend once who shall we say, nearly arrived at the mere sight of a semaphore in action- easy to please she was... |
Posted: Sat May 31, 2025 3:41 am Post subject: Re: Trans whine coasting |
Bub wrote: |
In 4th at regular speed going down the road if you let off the gas does it whine like that? If it does it’s worn ring gear. |
You may be right.
But as long as we don´t know what kind of trans, split case or tunnel case is installed, imo it´s easier to remove just the wheel caps first, before inspecting the oil or the trans itself.
The main question in this stage is, is the issue inside or outside of the trans.
More input or response would be interesting. |
VW2024 Samba Member
Posted: Sat May 31, 2025 5:54 am Post subject: Re: Trans whine coasting |
Sorry for the delay in responding to all the responses.
Finally had good weather to drive again
Whines in all gears and in neutral
Louder coasting than under load
No change turning side to side
Tunnel trans
Very slight leak at axle tubes to tunnel connection left side
1 drop on left side outer
4 wheel Wilwood discs installed when engine and transmission were installed 5/21
Rear axle seals replaced 4/24 prior to being listed for sale. Minimum miles from then until I purchased 5/25. 1 drop may be residual from axles replacement.
Will be watching closely as it’s driven more. |
Posted: Sat May 31, 2025 7:31 am Post subject: Re: Trans whine coasting |
VW2024 wrote: |
Tunnel trans
Whines in neutral. Sitting still or moving? Clutch in or out? _________________ Jimbo
TDCTDI wrote: |
esde Samba Member
Posted: Sat May 31, 2025 9:13 am Post subject: Re: Trans whine coasting |
If it only happens when moving, it's most likely the ring and pinion.
There are a lot of shops using marginal parts on rebuilds, or maybe some wear was missed. Once when I was at Steedles shop getting advice on how to modify some gear hubs, he pointed out wear on the gears that I didn't know how to identify, and that led to a short course on inspecting gear teeth. What I learned, in short is that clean and shiny is not always good to use. _________________ modok wrote:
VW2024 Samba Member
Posted: Sat May 31, 2025 11:45 am Post subject: Re: Trans whine coasting |
Only when moving
Much louder coasting in or out of gear than while accelerating |
Posted: Sat May 31, 2025 11:00 pm Post subject: Re: Trans whine coasting |
Sounds like the carrier bearings. Time to rebuild it! _________________ Jimbo
TDCTDI wrote: |
VW2024 Samba Member
Posted: Sun Jun 01, 2025 5:37 am Post subject: Re: Trans whine coasting |
Thanks all for the help and advice!
Recommend a trans rebuilder?
Top 3?
Posted: Sun Jun 01, 2025 8:41 am Post subject: Re: Trans whine coasting |
I HIGHLY recommend Scott Sebastian at MCM. The shop is located in Sanger, California. He allows me to visit the shop and build along side him. When I helped rebuild the 54’s trans with his expertise in January this year. It’s is in my build thread. It is page 95, I think.
His info is, Metal Craft Motorsports, 559-313-3301.
Good luck and tell Scott "Jim says hi!" _________________ Jimbo
TDCTDI wrote: |
esde Samba Member
Posted: Sun Jun 01, 2025 3:45 pm Post subject: Re: Trans whine coasting |
Scott X's 2. The man really knows his stuff. If you're on the east coast, then Matt Steedle, PM for contact if needed.. _________________ modok wrote:
