pig-pen Samba Member
Joined: December 04, 2012 Posts: 587 Location: United Kingdom
Posted: Sun Jun 01, 2025 1:02 pm Post subject: Urgent help needed with gearbox fitment issues... |
He all.
Hoping someone here can help with some experience.
A long rambling story, apologies in advance.
So I have a '55 beetle with a tuned 36hp motor, which also has a doghouse fan conversion.
everything was going great, running the OG split-case trans, motor all good.
then one morning the trans decided to go into reverse and forward gear at the same time and I took out the engine and box to reset the hockey stick. At that time I put in a kennedy stage 1 clutch.
Again, it seemed like the problem was fixed. I drove it a few miles after missing most of last summer, and parked it up in storage for the winter. This spring i went to wake her up, and the trans was totally locked. I had driven it into the spot and it wasn't touched... but the shifter just would not move. I have no clue why this happened.
It is at this point I now realise I should have spent the money and had that box rebuilt. But I didn't. Stupid!
So my buddy had a 1300 box, good and shifts nice... so I put that in. I used a solid mount at the front, to avoid the low slung problem that happens with a bus nose cone... That all went really well, fit nice.
But then, putting the engine in was a real struggle. Its in but there are problems. It is sitting much higher than before, and if I were to guess, its also closer to the firewall than before. A bit of cutting and welding got the exhaust to fit again, but my problem is that the front engine tin is all out of shape because its being distorted by the engine position, and the doghouse exhaust tin will not fit at all. It used to just slide in and bolt up.
Also, my set up was VERY tight to the engine lid, and now it wont shut due to the engine sitting in a new high position.
does anyone have any experience of this?
How did you fix it?
I am now thinking that the bus nose cone would have been a good idea if it makes the engine sit lower... cos this is way too high right now.
Could I put a rubber pad between the front hard mount and the body? what about customising the gearbox cradle to make it sit a little bit lower??? slot the holes?
Please help!!!
thanks! _________________ 1954 L227 Type 113
1964 L31 Type 265 |
EVfun  Samba Member
Posted: Sun Jun 01, 2025 2:50 pm Post subject: Re: Urgent help needed with gearbox fitment issues... |
You fix this by putting the Bus nosecone on the tunnel type transaxle. The frame was changed in 1960 so that the transaxle was mounted at an angle to reduce the rear camber. The "low slung problem that happens with a bus nose cone" only applies to the 1960 frame. The location of the shift rod on the transaxle changed on Bug (but not on the Bus.) The Bus retained the lower shift rod location used on 1959 and older Bugs.
I thought I would toss in a picture of the one year only 1960 Bug splitcase transaxle nose cone. Note the raised position of the shift rod used, in part, to lower the transaxle in the frame. This one sits in my garage, an extra from a parts swap.
EDIT: the Bus shift rod location is lower. _________________
| Wildthings wrote: |
| As a general rule, cheap parts are the most expensive parts you can buy. |
esde Samba Member
Joined: October 20, 2007 Posts: 6392 Location: central rust belt
Posted: Sun Jun 01, 2025 3:53 pm Post subject: Re: Urgent help needed with gearbox fitment issues... |
I've used a bus nose cone on a half dozen cars and never had the low slung problem you are having. And, as noted, a 60 car is a PITA as it's different than all the rest.. but your 55 should be easy.
I'm super curious as to how the split case trans is locked up.. _________________ modok wrote:
Posted: Sun Jun 01, 2025 5:01 pm Post subject: Re: Urgent help needed with gearbox fitment issues... |
| esde wrote: |
I'm super curious as to how the split case trans is locked up.. |
ME TOO!!! _________________ 1954 L227 Type 113
1964 L31 Type 265 |
EVfun  Samba Member
Posted: Sun Jun 01, 2025 5:15 pm Post subject: Re: Urgent help needed with gearbox fitment issues... |
That mount fixes the problem that the transaxle mounting point is closer to the shift rod point for 1959 and older Bug transaxles. It does not fix the problem that the shift rod point was moved up on Bug transaxles from 1960 onward.
I posted a picture of the tunnel transaxle nose cone for the Bus and for the Bug. Notice how the shift rod point is different between the two. That shift rod has to poke into the hole above the rear torsion housing. That location on the Bug frame didn't move. It moved on the transaxle in 1960, so the transaxle would mount lower in the frame to reduce rear camber.
BTW - I have one of those mounts and I have considered using it to mount the 1960 Bug split case transaxle I have into a tunnel chassis frame (it would be my '64 frame beach buggy, if I choose to do it.) I would mount it up-side-down compared to how you used it. _________________
| Wildthings wrote: |
esde Samba Member
Posted: Sun Jun 01, 2025 9:28 pm Post subject: Re: Urgent help needed with gearbox fitment issues... |
| EVfun wrote: |
I think you have described it exactly.
It's an Empi part, and while to does solve the "transmission into the chassis" issue, of course it doesn't address any of the issues that arise subsequently
Maybe it's fine for Dune buggies and Baja bugs.. but not when the engine needs to fit some sheet metal..
And, just to touch on the 1960 split case transmission as it was brought up..
While it is a split case trans and shares many parts with the earlier split case transmissions (back to 1952) the case, nose cone, and all the shift rails and forks are 1960 only. Pretty sure the 1960 front mount is specific, a 1 year part too _________________ modok wrote:
Posted: Mon Jun 02, 2025 12:04 am Post subject: Re: Urgent help needed with gearbox fitment issues... |
so really annoying... I had my doubts but was told by a highly reputable vw transmission specialist here in the uk that this was the way to go. I even had a bus nose cone sitting on the bench.
so... trans out again then. and now its at home on my drive.
this sucks.
so not withstanding a few perspective issues this diagram explains what is happening? and basically the nose of my trans is sitting low as a result?
do I have that right? and so making my engine sit abnormally high... _________________ 1954 L227 Type 113
1964 L31 Type 265 |
EVfun  Samba Member
Posted: Mon Jun 02, 2025 7:46 am Post subject: Re: Urgent help needed with gearbox fitment issues... |
| pig-pen wrote: |
do I have that right? and so making my engine sit abnormally high... |
That is correct. People making Baja Bugs liked that EMPI adapter nose cone because moving the engine up a little helps with ground clearance.
Here is VW documenting the change as a part of shop process for replacing a frame on a pre-1960 Bug. (Link points to the 8 page document.)
| Wildthings wrote: |
KOMBI NIKO Samba Member
Joined: February 03, 2013 Posts: 323 Location: Australia
Posted: Thu Jun 12, 2025 2:57 am Post subject: Re: Urgent help needed with gearbox fitment issues... |
| pig-pen wrote: |
this sucks.
Using the bus nose cone still might give you problems, my 57 Oval chassis has the bus nose cone on a type 3 box and I'm having alignment issues between the shift rod and box shifter. _________________ https://www.instagram.com/demop_vw_garage/
https://www.facebook.com/Demopgarage/
https://www.youtube.com/@Demop_VW_garage
61 Microbus
63 Aussie single cab
52 factory ambulance
57 beetle |
VW_Jimbo  Samba Member
Joined: May 22, 2016 Posts: 11448 Location: Huntington Beach, CA
Posted: Thu Jun 12, 2025 3:25 pm Post subject: Re: Urgent help needed with gearbox fitment issues... |
What do the rear transmission mounts look like? They can be adjusted a little bit to help get the nose cone pointed in a better direction. Are you using the rear stock crosspiece? Or an aftermarket unit? _________________ Jimbo
| TDCTDI wrote: |
| Basically, a whole bunch of fuckery to achieve a look. |
| 67rustavenger wrote: |
GFY's Xevin and VW_Jimbo!  |
Posted: Wed Jun 18, 2025 3:15 pm Post subject: Re: Urgent help needed with gearbox fitment issues... |
So to report, bus nose cone fitted and motor went straight in no fighting. everything is much better, although engine is still higher than before. but not as insanely high as with that dumb plate adaptor thingy. _________________ 1954 L227 Type 113
1964 L31 Type 265 |
