Redfox2020 Samba Member
Posted: Thu Jun 05, 2025 11:12 am Post subject: Brazilian Split 4 stud wheels |
I've bought a Brazilian split window bus. It's been lowered and is riding on 14 inch 4 stud wheels. My understanding is that the buses ran 5 stud wheels. Any ideas what the set up is that's allowed a 4 stud wheel to be used. It's discs front drums on the back.
Clara  Samba Member
Posted: Thu Jun 05, 2025 11:43 am Post subject: Re: Brazilian Split 4 stud wheels |
Yes, split buses came new with wide five bolt pattern, so yours has some mods.
post pics of your suspension, what the wheels were bolted to. _________________ The Obsolete Air-Cooled Documentation Project http://oacdp.org/ |
Posted: Thu Jun 05, 2025 1:14 pm Post subject: Re: Brazilian Split 4 stud wheels |
[img] this is the beam.
[/img] |
Clara  Samba Member
Posted: Thu Jun 05, 2025 3:36 pm Post subject: Re: Brazilian Split 4 stud wheels |
Redfox2020 wrote: |
[/img] |
I see a king/link spindle, but not what the front wheels bolts to.
Does it have 4 lug wheels in back as well? Could be a beetle tranny in back.
From the angle of the trailing arms, could be a turned beam. But that doesn't mean how the wheels bolt on. _________________ The Obsolete Air-Cooled Documentation Project http://oacdp.org/ |
panel Samba Member
Joined: December 02, 2001 Posts: 1189 Location: Victoria B.C. Canada
Posted: Thu Jun 05, 2025 5:57 pm Post subject: Re: Brazilian Split 4 stud wheels |
Can you post a pic of the spindle with the brakes etc ? And the same for the rear....brake area where the wheel bolts to. _________________ My '65-Subaru EJ20 Turbo conversion |
Posted: Fri Jun 06, 2025 12:20 am Post subject: Re: Brazilian Split 4 stud wheels |
Hi, I'll try and get the wheels off tomorrow and some pics of the set up. It's 14 inch 4 stud wheels all round, adjustable spring plates and drums on the back. It's too low for the roads here, speed bumps everywhere. _________________ 71 Karman Ghia
73 Split Bus |
Malokin Martin Samba Member
Posted: Fri Jun 06, 2025 12:42 pm Post subject: Re: Brazilian Split 4 stud wheels |
panel wrote: |
Can you post a pic of the spindle with the brakes etc ? And the same for the rear....brake area where the wheel bolts to. |
I have a feeling this is going to be good… |
Posted: Sat Jun 07, 2025 12:39 am Post subject: Re: Brazilian Split 4 stud wheels |
Thanks everyone. I got the wheels off today. The front is using spacers and looks like discs have been drilled to accept the 4 stud pattern? Rear is this a beetle transaxle? No engine in at the moment so back is sitting higher than it usually does.
73 Split Bus |
Posted: Sat Jun 07, 2025 12:59 am Post subject: Re: Brazilian Split 4 stud wheels |
Rear drum set up _________________ 71 Karman Ghia
73 Split Bus |
pondoras box Samba Member
Joined: March 22, 2004 Posts: 1604 Location: Eerie PA
Posted: Sat Jun 07, 2025 4:41 am Post subject: Re: Brazilian Split 4 stud wheels |
I don’t know what that is but I do know I would be terrified to drive that. Please just get stock brakes back on it and ditch that mess. Wheels look cool but not at the cost of your safety. _________________ Looking for anything from Hal Casey Motors out of Hamburg New York, from license plate surrounds to matchbooks.
1961 23 Window (Bobo)
1965 13 Window (Lucas)
1957 Oval ragtop
1960 hardtop
1964 hardtop
1965 hardtop
1973 standard bug
https://www.thesamba.com/vw/forum/viewtopic.php?t=804912
1988 Cabriolet VR6 conversion
Plus a lot of other rusty junk |
Stocknazi Samba Member
Posted: Sat Jun 07, 2025 5:14 am Post subject: Re: Brazilian Split 4 stud wheels |
What the bubba???
Someone just got on about it with this one. I'm diggin' the front shock.
Yeah, ditch all that crap and start over with the proper parts. _________________ WANTED:
Thomas Jefferson |
Posted: Sat Jun 07, 2025 12:29 pm Post subject: Re: Brazilian Split 4 stud wheels |
Yes quite shocking. I'd intended to overhaul the brakes and suspension but not sure if it's worth salvaging that front beam or starting from scratch?
Any thoughts on the rear setup? Scrap it and start again? Ideally would like to convert to disc brakes. _________________ 71 Karman Ghia
73 Split Bus |
