73 Beetle Trans CV boot Replacement -help
2381Buggy
2381Buggy is offline
PostPosted: Sun Jun 08, 2025 1:22 pm    Post subject: 73 Beetle Trans CV boot Replacement -help Reply with quote
In replacing my cv boots today, I am not sure which way a retainer goes back on the axle.
After installing the new boot, the next step is to reinstall the inside retainer/washer on the axle that the cv joint stops against once installed on the splines.
I found the retainer, which is a little concave, installed one way on one end of the axle and the opposite on the other before removal.
This is not the outer split circlip retainer, but a solid inner retainer. I can't find any info as to whether or not the flat side goes against the cv joint or the concave side.
After a good cleaning and then reassembly of the joints, I was very careful to make sure my joint orientation with regard to the flat and tapered sides of the cage and nut were correct-flats facing outward away from the axle for proper joint movement, but just don't know about this inside clip.
It appears to be called inner joint concave washer.
modok
modok is offline
PostPosted: Sun Jun 08, 2025 7:15 pm    Post subject: Re: 73 Beetle Trans CV boot Replacement -help Reply with quote
One would expect concave side of the washer to go against the part with the larger surface, so, the joint.
SGKent Premium Member
SGKent is offline
PostPosted: Mon Jun 09, 2025 12:19 am    Post subject: Re: 73 Beetle Trans CV boot Replacement -help Reply with quote
I don't know Beetles but in 1975 VW deleted those in buses, and said in the tech bulletin that when rebuilt they could be discarded. You might take a look for similar Beetle tech bulletins.
Bus:
... VW dropped the compression washers that used to go on the (Bus) shafts in 1975 https://www.vw-t2-bulli.de/michaelknappmann/tm_h/gross/TM_H_129-1.jpg
An allen Typ 2 Fahrezeugen entfallt mit Beginn des Modelljahares 1975 die Tellerfeder hinter dem Gleichlaufgelenk
translation: From the beginning of the 1975 model year, the diaphragm spring behind the constant velocity joint was eliminated on all Type 2 vehicles
Die Tellerfeder ist aucj bei Instandserzungen an bisherigen Gellenkwellen (nur Typ 2) nicht wieder einzubauen.
translation: The disc spring does not need to be reinstalled even when repairing existing drive shafts (type 2 only).
