Turn signal flasher relay images and part numbers
70bus Premium Member
70bus is offline
PostPosted: Wed Jun 18, 2025 7:35 pm    Post subject: Turn signal flasher relay images and part numbers Reply with quote
As part of something I've been digging into, I've acquired a number of t/s relays, images of them, and some wiring diagrams. Many are from classifieds or internet sites, and may disappear, so i thought I'd gather them. Why? Partially so you can see what some VW parts look like in the flesh, rather than just a line in a parts manual. You can then be at a swap, and spy JUST the relay you need! Second, so that you can see the terminal designations, and sometimes wiring diagrams - on unit or on paper. This may enable you to swap out a relay if an electrically-similar one you have isn't working. Many relays that have 31 (ground), 15 and 54 will swap out for relays with 31, 49 and 49a. Oddly, some don't. Honestly I assume those have an issue, but ya never know. And while most indicator terminals marked P, R, REP, C send power to a circuit, K or KBL usually grounds it, but not consistently, so testing is required. Many of these units look exactly the same in every way, but have different manufacturer's numbers, meaning SOMEthing is different!
I rely on "OG in the box" relays actually being originally IN the box pictured, but there's at least one I suspect was stashed in the wrong box... but it may be the later replacement unit, put in earlier one? That's the sort of thing I would appreciate feedback on. In any case, I hope this is of use to someone. Please add more, especially later years, as I don't have any. I know a lot are in the gallery, so just a part number and the pic link are all that is needed.
It will take a few days to complete this - I have several hundred images of around 50 different relays to type up. Perfectly happy if you beat me to the punch.
As for the project this sprang from: US buses with emergency flashers came with t/s relays having +, S and KBL; I'm specifically looking for the 12v versions, Mcodes 620 and 621. VW lists MANY part numbers for these buses over the years, but so far each one I have purchased or found an image of has 31, 49, and 49a. Some of these I purchased hoping they would at least function the same as +,s,KBL and ya never know until you test. Anyways, if you have one, or a pic of one, post it!
Turn signal relay 111953185B flasher
Hella 91ESJ2x18W-6v. 4NB001826-03
Unknown, probably SWF BGC-51a, 6v
SWF in VW box BGC/51a6v
SBG 334 6v 2x18
Uroparts 9800 12 v - replacement part for 12v conversion
Turn signal relay 111953185C flasher
Hella 91ES5J2x18W-6v 4NB001827-011
SWF BGC 200428 6v 2x18W
Bosch 0336251001 6v 2x18w
Craig K
70 Neunsitzer
65 Pritschenwagen
Raul the 65 singlecab
Karl the 70 nine-seater
70bus is offline
PostPosted: Wed Jun 18, 2025 9:39 pm    Post subject: Re: Turn signal flasher relay images and part numbers Reply with quote
Turn signal relay 113953183B flasher
Hella 91ES4J2x18W-6v
Turn signal relay 141953185C flasher
Hella 91MS1J2x18W 6v
Turn signal relay 211953183 flasher
Stribel SBG 220 6V2x18W
I have one of these in a box marked 141953185D as well.
Bosch 0336251003
Stribel SBG 3355 12V2x21W
Turn signal relay 211953183A flasher
Hella 91WSJ52x21W-12V 4NB001812-03 1
Bosch 0336256002 12v 2x21w
Stribel SBG 335 12v 2x21w
Mera unknown part # 12v 2x21w
Carto 113953227.1 possible replacement unit?
Craig K
70 Neunsitzer
65 Pritschenwagen
70bus is offline
PostPosted: Mon Jun 23, 2025 3:30 pm    Post subject: Re: Turn signal flasher relay images and part numbers Reply with quote
411953183 and possibly 211953183A
Bosch 0336256004
Wrong relay in box. Could be a later part, stuffed into existing box at factory to cover both bases, but doubtful. Same functions however - +, S and 31 vs. 40, 49a and 31.
Craig K
70 Neunsitzer
65 Pritschenwagen
70bus is offline
PostPosted: Mon Jun 23, 2025 3:38 pm    Post subject: Re: Turn signal flasher relay images and part numbers Reply with quote
Autotec 85 c/m 12v
49 49a 31 KBL
Replaces 211953215C in 12 volt 4 prong - beetle 68-70 - ghia 68-71 - bus 68-70 - type-3 68-70
Can also be used in 63 - 65 US bus w/ emergency flashers
Craig K
70 Neunsitzer
65 Pritschenwagen
70bus is offline
PostPosted: Mon Jun 23, 2025 3:42 pm    Post subject: Re: Turn signal flasher relay images and part numbers Reply with quote
Bosch 0336200046
12v 3x18W
'universal' replacement for cars with 49/49a or 15/54 terminals.
this schematic is for many other Bosch flashers:
0336102..
0336200045
0336200046
0336200047
0336200..
0336206004
Craig K
70 Neunsitzer
65 Pritschenwagen
70bus is offline
PostPosted: Mon Jun 23, 2025 3:44 pm    Post subject: Re: Turn signal flasher relay images and part numbers Reply with quote
Bosch 0336102022
12v (1+1)x18W
Craig K
70 Neunsitzer
65 Pritschenwagen
70bus is offline
PostPosted: Mon Jun 23, 2025 3:59 pm    Post subject: Re: Turn signal flasher relay images and part numbers Reply with quote
Bosch 0336207001
12v 2x21+18/21W
Craig K
70 Neunsitzer
65 Pritschenwagen
70bus is offline
PostPosted: Mon Jun 23, 2025 4:02 pm    Post subject: Re: Turn signal flasher relay images and part numbers Reply with quote
Bosch 0336210001
12v 2(4)x21W
Craig K
70 Neunsitzer
65 Pritschenwagen
70bus is offline
PostPosted: Mon Jun 23, 2025 4:31 pm    Post subject: Re: Turn signal flasher relay images and part numbers Reply with quote
Bosch 0336150010
6v 2x18W
Craig K
70 Neunsitzer
65 Pritschenwagen
70bus is offline
PostPosted: Mon Jun 23, 2025 4:41 pm    Post subject: Re: Turn signal flasher relay images and part numbers Reply with quote
Bosch SH/BVD 6/1
6v 15+15/20W
Craig K
70 Neunsitzer
65 Pritschenwagen
70bus is offline
PostPosted: Mon Jun 23, 2025 4:45 pm    Post subject: Re: Turn signal flasher relay images and part numbers Reply with quote
Bosch SH/BV B1/6/5
6v 2x18W
Craig K
70 Neunsitzer
65 Pritschenwagen
70bus is offline
PostPosted: Mon Jun 23, 2025 4:51 pm    Post subject: Re: Turn signal flasher relay images and part numbers Reply with quote
Bosch 0336203006
Bosch 0336203005
6 and 12v units; 'universal' replacement for cars with 49/49a or 15/54 terminals. Unsure why Bosch gave 12v part a lower number!
6v 2x18W
12v 2x18W
Craig K
70 Neunsitzer
65 Pritschenwagen
70bus is offline
PostPosted: Mon Jun 23, 2025 5:03 pm    Post subject: Re: Turn signal flasher relay images and part numbers Reply with quote
Hella 91MS1J
6v 2x18W
Craig K
70 Neunsitzer
65 Pritschenwagen
70bus is offline
PostPosted: Mon Jun 23, 2025 6:04 pm    Post subject: Re: Turn signal flasher relay images and part numbers Reply with quote
Hella 91P3V
6v and 12v
2xX watts
Multiple bulb ratings, 'universal' terminals. Appears K-P-C terminal is proper 'to ground' but unknown until tested. May work in 63 - 65 US buses with hazard lights.
Craig K
70 Neunsitzer
65 Pritschenwagen
70bus is offline
PostPosted: Mon Jun 23, 2025 6:32 pm    Post subject: Re: Turn signal flasher relay images and part numbers Reply with quote
Ideal 568
Ideal 569
569 replaces 211953215A 211953215D 111953227A
Craig K
70 Neunsitzer
65 Pritschenwagen
70bus is offline
PostPosted: Mon Jun 23, 2025 6:35 pm    Post subject: Re: Turn signal flasher relay images and part numbers Reply with quote
SWF BGC 10a
12v 15+20W
Craig K
70 Neunsitzer
65 Pritschenwagen
70bus is offline
PostPosted: Mon Jun 23, 2025 6:38 pm    Post subject: Re: Turn signal flasher relay images and part numbers Reply with quote
SWF BGC 200 06
6v 2x18W
Craig K
70 Neunsitzer
65 Pritschenwagen
70bus is offline
PostPosted: Mon Jun 23, 2025 6:46 pm    Post subject: Re: Turn signal flasher relay images and part numbers Reply with quote
SWF BGC 20092 200093
Craig K
70 Neunsitzer
65 Pritschenwagen
70bus is offline
PostPosted: Mon Jun 23, 2025 6:49 pm    Post subject: Re: Turn signal flasher relay images and part numbers Reply with quote
SWF BGC 200678
12v 2x21W
Craig K
70 Neunsitzer
65 Pritschenwagen
70bus is offline
PostPosted: Mon Jun 23, 2025 6:56 pm    Post subject: Re: Turn signal flasher relay images and part numbers Reply with quote
SWF BGC 200433
Craig K
70 Neunsitzer
65 Pritschenwagen
