bigwormskidoo Samba Member
Joined: January 28, 2025 Posts: 6 Location: Highland MI
Posted: Thu Jun 19, 2025 2:16 pm Post subject: late 3rd-4th synchro rings removable? |
has anyone had any luck removing the synchro rings from late type 1 3-4 gears to be use on early 3-4 gears like weddle has? |
modok Samba Member
Joined: October 30, 2009 Posts: 27667 Location: Colorado Springs
Posted: Thu Jun 19, 2025 3:46 pm Post subject: Re: late 3rd-4th synchro rings removable? |
I'm not understanding why you would do that. |
NJ John Samba Member
Joined: September 21, 2007 Posts: 2884 Location: HdG, MD & NJ
Posted: Thu Jun 19, 2025 4:10 pm Post subject: Re: late 3rd-4th synchro rings removable? |
I’ve heard late synchro hubs are factory welded. But, not sure that’s what your talking about. I don’t know much about transaxles. _________________ 1973 standard, yellow, lowered, 3” narrowed front, 1600 blo-thru turbo w/single dell 15.4@86, so far
11.41 et buggy. Long gone
Let’s go O’s! Let’s go O’s!
https://www.youtube.com/@AirSpooledGarage |
mcmscott Samba Member
Joined: March 12, 2010 Posts: 4929 Location: sanger ca
Posted: Sat Jun 21, 2025 7:46 am Post subject: Re: late 3rd-4th synchro rings removable? |
The earlier versions were furnaced brazed and can be removed. They have a larger bore than the 113 style tho. And you are refering to the hubs not synchro rings. _________________ There are no stupid questions, only stupid people,
68 Ghia
67 T-1
65 Notch
02 Mexican beetle
74 Thing
15 Long travel rail
07 Nomad
05 f-250 |
modok Samba Member
Posted: Sat Jun 21, 2025 12:42 pm Post subject: Re: late 3rd-4th synchro rings removable? |
AH! I thought they looked bigger, but what do I know
thanks for confirming that. |
esde Samba Member
Joined: October 20, 2007 Posts: 6333 Location: central rust belt
Posted: Sat Jun 21, 2025 7:36 pm Post subject: Re: late 3rd-4th synchro rings removable? |
Depends on what you mean exactly by late and early, maybe this?
You can use z3/4 hubs and synchros from a tunnel trans (late) in a split case trans (early) if you modify the early 3/4 clutch gear. This gets you the thicker and easier to find synchros, and back cut hub/ slider _________________ modok wrote:
