H80/31PICT rebuild
JohnWD
JohnWD is offline
PostPosted: Thu Jun 26, 2025 11:56 am    Post subject: H80/31PICT rebuild Reply with quote
I recently rebuilt my carb using a rebuild kit but the volume screw and o ring don't fit so I've reused the old one's. I get hardly and change in the tickover when adjusting the volume and bypass screws. I think the o ring might be leaking. I remember buying a rebuild kit a few years ago for the same carb and the volume screw in that kit were the wrong ones as well. Can anyone tell me the correct size of the o ring for this carb? It's got Bras under the type on the side of the carb so I assume it's not the original carb and I assume Bras is made in Brasil. My Campervan is a 1972 1600cc model.
heimlich Premium Member
VWNOS.com
heimlich is offline
PostPosted: Thu Jun 26, 2025 2:06 pm    Post subject: Re: H80/31PICT rebuild Reply with quote
Just to point out for you that's an H30/31.
borninabus Premium Member
Samba R&D Dept.
borninabus is offline
PostPosted: Sat Jun 28, 2025 1:06 pm    Post subject: Re: H80/31PICT rebuild Reply with quote
it appears your carb still needs some cleaning.....
non-responsive screws could be indicative of manifold vacuum leaks and/or clogged passages inside the carb.
how do you have the throttle stop adjusted?
where are your vacuum hoses going and is what they are going to holding vacuum?
88 Van WBX, A/T - 13 JSW TDI 6M/T - 2012 Touareg TDI Sport
