70 Beetle - fenders ON or OFF for body filler work?
timdhawk
timdhawk is offline
PostPosted: Wed Jul 02, 2025 10:02 am    Post subject: 70 Beetle - fenders ON or OFF for body filler work? Reply with quote
All me fenders need a little body filler TLC. Given that they are so flimsy, would it be better to do all my body filler work (application and sanding) with them bolted to the car for stability and rigidity, or off the car? They do seem to be somewhat cumbersome to manage effectively resting on my body stands.
Any advice of tricks of the trade would be appreciated.
Thanx
wheel607
wheel607 is offline
PostPosted: Wed Jul 02, 2025 10:10 am    Post subject: Re: 70 Beetle - fenders ON or OFF for body filler work? Reply with quote
You will be "CHASING" those fenders off the car. It will be much easier to work with them on the car and take them off later to prime/paint. I know because I have done both!
Bobs67vwagen
Bobs67vwagen is offline
PostPosted: Thu Jul 03, 2025 5:52 pm    Post subject: Re: 70 Beetle - fenders ON or OFF for body filler work? Reply with quote
I have always worked them while on the car. You have good access from behind in almost all areas and the body keeps them from moving while you are doing hammer and dolly work , cheesegrating, or sanding. Good luck-Bob
Glenn Premium Member
Mr. 010
Glenn is offline
PostPosted: Thu Jul 03, 2025 6:39 pm    Post subject: Re: 70 Beetle - fenders ON or OFF for body filler work? Reply with quote
On the car.
Glenn
Member #1009
#BlueSquare
עַם יִשְׂרָאֵל חַי
timdhawk
timdhawk is offline
PostPosted: Fri Jul 04, 2025 9:07 am    Post subject: Re: 70 Beetle - fenders ON or OFF for body filler work? Reply with quote
Thank you all! On the car the go!
