m3456y Samba Member
Posted: Mon Jun 30, 2025 4:53 am Post subject: Need help solving brake issue… |
I’m tying to help a guy solve an issue with his 1984 Brazilian T2 bus. It has power assisted front disc brakes and everything worked perfectly until the right rear brake cylinder failed as he was driving it. He was able to make it home and after replacing the brake cylinder, bleeding all the brake lines several times we took it out to test it. The brakes all worked, but the pedal was low and it pulled hard to the left under braking. We re-bled the brakes again, no air bubbles in fluid - took it back out and found the same thing. Any ideas on what the issue may be? |
lil-jinx Samba Member
Joined: August 14, 2013 Posts: 1586 Location: New Brunswick,Canada
m3456y Samba Member
Posted: Mon Jun 30, 2025 7:34 am Post subject: Re: Need help solving brake issue… |
lil-jinx wrote: |
the pulling could be brake fluid from the failed wheel cylinder soaked into the brake shoes. |
I thought that too, but it feels like a front braking issue as it’s very pronounced. |
timvw7476 Samba Member
Posted: Mon Jun 30, 2025 3:56 pm Post subject: Re: Need help solving brake issue… |
Are you bleeding on a flat surface?
The pressure regulator to the rear cylinders will stay somewhat closed if you even tilt the vehicle slightly. Best way to bypass that issue is to do it flat. And it doesn't hurt to gravity bleed it as well. |
m3456y Samba Member
Posted: Mon Jun 30, 2025 4:01 pm Post subject: Re: Need help solving brake issue… |
timvw7476 wrote: |
Bled on flat surface. Started with gravity bleeding, then went from wheel to wheel starting with longest brake line. |
SGKent  Samba Member
Joined: October 30, 2007 Posts: 42558 Location: at the beach
Posted: Mon Jun 30, 2025 4:08 pm Post subject: Re: Need help solving brake issue… |
what ever side it pulls to is working fine, the problem is on the weak side. If the right rear wheel cylinder failed, you had to pull it apart to repair it. Go over the work again including adjusting the rear brakes. The right rear is likely where something is wrong. If the linings got soaked with brake fluid, both sides should be replaced. _________________ "Most people don't know what they're doing, and a lot of them are really good at it." - George Carlin
RLFD213 Samba Member
Posted: Mon Jun 30, 2025 4:44 pm Post subject: Re: Need help solving brake issue… |
Bleed the front brakes first. Make sure you get all the air out, then bleed the rears. Make sure you adjust the rears as you’re bleeding them: bleed, adjust, bleed, adjust. Also how old are the soft lines? Maybe you have another problem. |
dodger tom  Samba Member
Joined: March 25, 2013 Posts: 1918 Location: Central Coast, CA, but we're all still Ukrainian and Californian
Posted: Mon Jun 30, 2025 4:54 pm Post subject: Re: Need help solving brake issue… |
i changed my fluid, and it started pulling to the right. my mechanic drove it around, then shot both rotors with an infrared temperature gauge. the left was much cooler. his diagnosis was a sticky left caliper. dirt in the lines caught during the fluid change? _________________ 1978 Champaign Edition 2 Westfalia
Would never find the time to keep up another classic air-cooled. |
Abscate  Samba Member
Joined: October 05, 2014 Posts: 23884 Location: NYC/Upstate/ROW
Posted: Mon Jun 30, 2025 6:53 pm Post subject: Re: Need help solving brake issue… |
Clarify, Tom. Is it pulling to the right all the time or just on braking?
All the time, sticking right caliper
Just on braking, sticking left caliper
Usually a sticking caliper will run really hot though. Don’t touch rotor to check , thst will hurt.
Possible swelling of brake lines? Are the soft hoses less than ten years old? _________________ 🇺🇸 🇺🇸 🇺🇸 🇺🇸 🇺🇸 🇺🇸 🇺🇸 🍊 🍊 🍊 |
Posted: Mon Jun 30, 2025 8:01 pm Post subject: Re: Need help solving brake issue… |
m3456y wrote: |
So you also bled the front brakes? Did you get normal flow from the right caliper? Do your calipers have two bleeders? If so you need to be using the upper bleeder. |
Posted: Mon Jun 30, 2025 9:09 pm Post subject: Re: Need help solving brake issue… |
Abscate wrote: |
Possible swelling of brake lines? Are the soft hoses less than ten years old? |
hey steve,
only on braking.
won’t touch nothin.
but, it was the rotor he shot with the temp gun. no friction, no heat, right?
but, don’t mean to hijack the thread. just offering my experience as a possible explanation for the op. _________________ 1978 Champaign Edition 2 Westfalia
Posted: Tue Jul 01, 2025 12:38 am Post subject: Re: Need help solving brake issue… |
I don’t think I’ve ever had a caliper freeze cold, they always end up with the pad not fully retracting and ergo run really hot. That would point me to cold caliper good, if anything.
The Right way to sort out is caliper removal and confirming piston motion under thumb pressure on both sides. Don’t guess with brakes _________________ 🇺🇸 🇺🇸 🇺🇸 🇺🇸 🇺🇸 🇺🇸 🇺🇸 🍊 🍊 🍊 |
m3456y Samba Member
Posted: Tue Jul 01, 2025 3:39 am Post subject: Re: Need help solving brake issue… |
Wildthings wrote: |
m3456y wrote: |
Bled all brakes several times starting with longest line first. Used only the upper bleeders on the front. The front brake hoses looked to be relatively new as the complete front beam was replaced, brakes and calipers new, etc. Also, the pedal while hard and solid is now lower than it originally was. Wondering if it could be a master cylinder issue. I’m not new at this - I’ve done it many times on various vehicles, but have never run into this after replacing a brake cylinder. |
jtauxe  Samba Member
Joined: September 30, 2004 Posts: 5975 Location: Los Alamos, New Mexico, USA
Posted: Thu Jul 03, 2025 8:50 pm Post subject: Re: Need help solving brake issue… |
m3456y wrote: |
I'm not sure how much it matters, but the manual specifies the order in which to bleed the brakes, and it is not "longest line first."
Hoses may "look" fine, but be rotten or softening inside.
Don't rule out the booster. After a long hard fight diagnosing my brakes after replacing the front calipers, it turned out that the booster had failed during the bleeding process. _________________ John
http://vw.tauxe.net
1979 Champagne Sunroof, 1974 Westfalia Automatic, 1979 Transporter, 1972 Sportsmobile, 1973 Transporter Wild Westerner, 1974 Westfalia parts bus, 1975 Mexican single cab *FOR SALE*, 1978 Irish 4-door double cab RHD
