CME__ Samba Member
Joined: February 07, 2025 Posts: 5 Location: Seattle, WA
Posted: Fri Jul 11, 2025 9:20 pm Post subject: Need help with 5 rib manual transmission |
Hello,
I have been unable to find any helpful resources with this problem due to how niche it is, so I am reaching out to the VW wizards on the Internet as a last resort before I call the shop.
The transmission (manual 5 rib from mid-‘74 Baywindow) suddenly had issues shifting out of nowhere. No grinding or growls. Shift pattern just went from an H-pattern to a O-pattern when I went through an intersection. I managed to limp it home in third gear. (R.I.P. clutch)
My first thought was the shift linkage. Everything was looking good, motion was getting all the way back to the coupler (as much motion as possible, considering the circumstances) and I knew I was in for a journey. I disconnected the shift rod at the end of the hockey stick and tried to move it around. Completely stuck, zero movement inside the nose cone.
So here’s where I’m stuck: I’ve pulled all the bolts off the nosecone, and I pulled the reverse switch out, and I drained the gear oil, but I still can’t get the dang thing off. I’ve seen videos of guys working on these transmissions, but they just whack it with a mallet after pulling all that stuff and it pops right off. It’s definitely not a stuck gasket, it’s way too stubborn for that. It feels like I missed a bolt, but I’m certain I did not.
I know it’s a long shot, so any help is appreciated. How do people get inside the 5 rib nose cone? |
GS Samba Member
Joined: October 16, 2018 Posts: 23 Location: Middelburg, Netherlands
Posted: Sat Jul 12, 2025 5:48 am Post subject: Re: Need help with 5 rib manual transmission |
Could be the ball inside the nosecone.
Got pictures of the situation? _________________ 1971 Baywindow westy m-plate
1972 Bug |
RLFD213 Samba Member
Posted: Sat Jul 12, 2025 7:03 am Post subject: Re: Need help with 5 rib manual transmission |
Sounds like maybe the hockey stick came out and is jammed against something. You can try and tap and pry the nose cone off of worst case take a dremel and cut it in half. Either way you’re gonna have to get in there and see what happened. |
lil-jinx Samba Member
Joined: August 14, 2013 Posts: 1569 Location: New Brunswick,Canada
timvw7476 Samba Member
Posted: Sat Jul 12, 2025 1:22 pm Post subject: Re: Need help with 5 rib manual transmission |
if it is stuck it is the stick loose, the ball socket or bracket . The bracket likes to crack after the third decade of use. Right at one of the bolt holes.
It might mean pulling it all to get access. |
CME__ Samba Member
Posted: Sun Jul 13, 2025 6:33 pm Post subject: Re: Need help with 5 rib manual transmission |
All right, y’all were right once again. I looked and, sure enough, there was a nut hiding beneath the crapload of gunk on the nose cone still holding it on. Also, as one of you pointed out, the bracket holding the gear selector pin was in fact broken. (It’s well past it’s “third decade” best-by date ) here’s a photo of the situation inside the nose cone:
Are these brackets easy to find online, or will I have to spend a day at the junkyard? |
Posted: Mon Jul 14, 2025 3:36 pm Post subject: Re: Need help with 5 rib manual transmission |
As far as brackets I would use a fab shop & weld up yours.
Or have them fabricate one for you.
Finding one in the junkyard means it is bolted to a transaxle with a $2,000 core charge. As in you'd buy the whole trans if you were to come across one out there..... boy that would be N I C E . But its 2025. : l |
