Unusual case cracks
Chunky_t
Chunky_t is offline
PostPosted: Fri Jul 11, 2025 9:25 pm    Post subject: Unusual case cracks Reply with quote
Hey guys,
Just cleaning up my engine for a 65 beetle (F case) and noticed what looks like a rather large crack stemming from the casting mark on the top of the case at cylinder 1.
What's got me stumped is the marks around it, is it an old repair? Casting flaw? Doesn't leak to my knowledge.
Photos for reference. Possibly a devastating find as it's not a huge budget build.
Anyone have any ideas or seen cracks here before?
modok
modok is offline
PostPosted: Fri Jul 11, 2025 9:35 pm    Post subject: Re: Unusual case cracks Reply with quote
I doubt those are cracks
Chunky_t
Chunky_t is offline
PostPosted: Fri Jul 11, 2025 9:38 pm    Post subject: Re: Unusual case cracks Reply with quote
The one in the photos looks very crack like, not sure what else it is. Seems odd however.
modok
modok is offline
PostPosted: Fri Jul 11, 2025 11:15 pm    Post subject: Re: Unusual case cracks Reply with quote
Take a 1/2 ball or oval carbide burr and grind until it's smooth, then check again.
You don't need to do the whole thing, just pick the spot that you are most sure is a crack and hit that.
Soak with wd40, wipe it off, Pass a torch over it.
Or just fully degreasing with any aggressive detergent (12ph jetwash detergent) also tends to make cracks visible.
74 Thing
74 Thing is offline
PostPosted: Fri Jul 11, 2025 11:44 pm    Post subject: Re: Unusual case cracks Reply with quote
Put a torch on it like suggested above and if there is a crack you should see it with the heat and case expansion.
mikedjames
mikedjames is offline
PostPosted: Fri Jul 11, 2025 11:49 pm    Post subject: Re: Unusual case cracks Reply with quote
Looks like a casting flaw where metal flows into the mold but cooled before filling it fully. It has always been there.
Yes it is potentially a weakness in the case but because of its location (maybe over a thick part of the case) it has not leaked or done anything else for well over 50 years.
I would ignore it. Or if you like put JB Weld in the depression to make you feel better about it.
Ancient vehicles and vessels
RWK
RWK is offline
PostPosted: Sat Jul 12, 2025 5:19 am    Post subject: Re: Unusual case cracks Reply with quote
Yes, casting flaws, we call them knit lines in the plastic molding business. same thing happens in the die casting industry.
73 Type 181
63 Type 113
63 Type 261- 428 071
62 Type 241-378 025 178 530
