72 Superbeetle sedan, flipping horn doesn't work...again!
72VWSB
72VWSB is offline
PostPosted: Sat Jul 12, 2025 10:56 am    Post subject: 72 Superbeetle sedan, flipping horn doesn't work...again! Reply with quote
SOLVED:
Hello again,
72 Superbeetle horn not working again. I have a fuse diagram that shows the horn is connected to #3 fuse but then I go on youtube that shows it going to the left headlight? Does anyone out there have an accurate fuse diagram because I am confused...like always. This was working fine about a week ago and I'm trying to find which fuse actually controls the horn. Thank you in advance...
72 VW Super Beetle
baldessariclan
baldessariclan is offline
PostPosted: Sat Jul 12, 2025 12:19 pm    Post subject: Re: 72 Superbeetle sedan, flipping horn doesn't work...again! Reply with quote
Recommend that you read through this post first, to understand how the horn system wiring and related components work: https://www.thesamba.com/vw/forum/viewtopic.php?p=10175381
Then refer to the factory wiring diagram for 1972 model year:
Cusser
Cusser is offline
PostPosted: Sat Jul 12, 2025 12:33 pm    Post subject: Re: 72 Superbeetle sedan, flipping horn doesn't work...again! Reply with quote
72VWSB wrote:
72 Superbeetle horn not working again. I have a fuse diagram that shows the horn is connected to #3 fuse. This was working fine about a week ago and I'm trying to find which fuse actually controls the horn. Thank you in advance...
The fuse diagram from the Tech Section (posted above by baldessariclan) shows the fuse #11 (from the left/driver side) for the horn and for the brake light switches/brakes.
I'd turn the key to "run" position and see if one of the two wires at the horn itself is getting voltage, and/or check the brake light operation. If it's truly fuse #11 blowing, then you'll need to isolate whether horn or brake circuit is the reason.
72VWSB
72VWSB is offline
PostPosted: Sat Jul 12, 2025 2:27 pm    Post subject: Re: 72 Superbeetle sedan, flipping horn doesn't work...again! Reply with quote
Don't have any burned out fuses...took out #3 and #11, fuses look good, put the dialectric grease on the tabs, still nothing. I am getting 12v at #11 with the key on, nothing on #3...
72 VW Super Beetle
72VWSB
72VWSB is offline
PostPosted: Sun Jul 13, 2025 10:17 am    Post subject: Re: 72 Superbeetle sedan, flipping horn doesn't work...again! Reply with quote
SOLVED:
I have discovered that the fuse in #12 position controls the horn, Instrument lights, fuel gauge, turn signals and brake lights. So, out of two different Fuse diagrams, neither one is actually correct! And, while I was driving the car today, the fuel gauge, turn signals, instrument lights decided to go out...which led me to fuse #12. Now the horn works also. When restoring my 72, I never did rewire the car, it still has original wires...
72 VW Super Beetle
baldessariclan
PostPosted: Mon Jul 14, 2025 7:48 am    Post subject: Re: 72 Superbeetle sedan, flipping horn doesn't work...again! Reply with quote
Excellent - glad you got it working! Smile
Your setup as described does still seem a bit odd, though -- e.g. I've never seen factory wiring where the instrument lights are protected by one of the fuses - ? They normally get their power directly via connection to the headlight switch. Thus am a bit suspicious that a PO may have gotten a bit "creative" with the wiring at some point, before you got the car. That's just a SWAG on my part, though -- I've been wrong before... Smile
ashman40
ashman40 is offline
PostPosted: Mon Jul 14, 2025 10:48 am    Post subject: Re: 72 Superbeetle sedan, flipping horn doesn't work...again! Reply with quote
Some of the '71 & '72 fuse box diagram from VW are wrong. When VW switched to the 12-fuse fuse box the parking lights were moved to fuse #1 & #2. Any diagrams that indicate these fuses are for anything other than parking lights is wrong. When wrong, the labels are almost reversed but not quite.
Here is the '71 Owner Manual page that is wrong:
This page from the '72 Owner Manual is correct:
Here is the '71-'72 12-fuse box diagram which is wrong:
Here is a corrected fuse box diagram from a user:
AshMan40
