New front shocks for my buggy needed
Turbopaul
Turbopaul is offline
PostPosted: Wed Jul 16, 2025 1:32 pm    Post subject: New front shocks for my buggy needed Reply with quote
Can you folks make some recommendations on different shocks for the front on my fiberglass dune buggy. I currently have kyb gas shocks but they are way too stiff. I can't even push the suspension down with them on, with them off I can at least bounce the suspension. They are longer than stock bc of my jacked up front end. I'm thinking maybe some cheaper hydraulic ones. What do ya think?
Paul
Turbopaul
PostPosted: Wed Jul 16, 2025 1:33 pm    Post subject: Re: New front shocks for my buggy needed Reply with quote
Sorry guys the front suspension is a 68 ball joint design.
slalombuggy
slalombuggy is offline
PostPosted: Wed Jul 16, 2025 1:57 pm    Post subject: Re: New front shocks for my buggy needed Reply with quote
Cheap oil shocks are fine for street cars
Turbopaul
PostPosted: Fri Jul 18, 2025 11:52 am    Post subject: Re: New front shocks for my buggy needed Reply with quote
Ok so who makes a cheap oil filled shock? I have been looking and can't find anything. I tried fcs but they are all oil filled. Thanks
halfassleatherworks
PostPosted: Fri Jul 18, 2025 1:29 pm    Post subject: Re: New front shocks for my buggy needed Reply with quote
Rock auto 12.73 each https://www.rockauto.com/en/moreinfo.php?pk=163067...gfb5QhM%3D
jspbtown
jspbtown is offline
PostPosted: Fri Jul 18, 2025 3:05 pm    Post subject: Re: New front shocks for my buggy needed Reply with quote
I assume you mean "gas filled"? Laughing
Turbopaul
PostPosted: Fri Jul 18, 2025 5:25 pm    Post subject: Re: New front shocks for my buggy needed Reply with quote
As salombuggy stated oil filled shocks? Don't they make them without the gas on top?
I had those same shocks on order today from Rock Auto bc I was told they were gas shocks, not oil filled.
Thanks guys
Turbopaul
PostPosted: Sat Jul 19, 2025 9:45 am    Post subject: Re: New front shocks for my buggy needed Reply with quote
So are the fcs shocks listed above from Rock Auto oil filled like the cofap brand? Those are the ones that are listed on all the vw parts houses.
EVfun Premium Member
EVfun is offline
PostPosted: Sat Jul 19, 2025 2:59 pm    Post subject: Re: New front shocks for my buggy needed Reply with quote
Take a couple drives without front shocks and see how it feels. The VW beam suspension has a fair amount of friction. You might find it acceptable, but it will at least give you a reference point. I found the faster front end dive when hitting the brakes helped transfer some weight up front and never had much bounce. My buggies have been king and link pin front end (1965 and older frames) but most of the friction is in the beam bearings, and they are similar for all year Bug frames. My current buggy is a Berry Mini-T and there isn’t room for the king pin beam shock towers.
As far as finding old school oil filled shocks, my first thought would be a street rod shop. I have a real short pair intended for a T-bucket, to see if I could tuck them into Mini-T fenders, but no dice. These have the bushing eyes at both ends as that style was used on K&L Bugs. A rod shop should at least understand shop types and needs, as well as extended and compressed lengths. You might look over at Speedway Motors. I’ve bought plenty of parts from them, they have a more owner-designer perspective.
Some VW parts house should be promoting proper non-charged front shocks, but a quick search didn’t turn one up. Confused
Wildthings wrote:
Turbopaul
PostPosted: Sat Jul 19, 2025 3:58 pm    Post subject: Re: New front shocks for my buggy needed Reply with quote
Ok thanks for the advice. I will try it w/o shocks and see how it drives. I will go from there.
jsturtlebuggy
jsturtlebuggy is offline
PostPosted: Wed Jul 23, 2025 11:16 am    Post subject: Re: New front shocks for my buggy needed Reply with quote
Wolfsburg West in Corona,CA has shocks that are just like the stock oil filled shocks VW Bugs came with.
The have both for King&link and Ball Joint front suspensions.
Also rear shocks too.
Joseph
Fair Oaks/Orangevale, CA
Elrod Motorsports
Motion Tire Motorsports
Into Volkswagens since 1960
