Washer Bottle Cap
Michaellatini
Michaellatini is offline
PostPosted: Mon Jul 21, 2025 12:22 pm    Post subject: Washer Bottle Cap Reply with quote
Hello,
Put the entire washer system together outside the car including the wiper switch. Filled the bottle with water and push the button and it works. Installed it all back into the car and now, no air is getting into the bottle.
Is there something missing from the inside of the bottle? See pic.
Second pic shows the tooth that is supposed to get pressed down when screwed into the bottle. Even pressing it with a large flat screwdriver blade nothing.
Thank you in advance.
M
jeffrey8164
jeffrey8164 is offline
PostPosted: Mon Jul 21, 2025 3:07 pm    Post subject: Re: Washer Bottle Cap Reply with quote
Talking out of my rear end here but I remember reading on another thread that you need something like 40psi in the spare tire for the washer to work. The valve is designed to not work below 25-27 psi so your spare won’t go flat. I also remember that it’s a fine line as the switch doesn’t handle a bunch of pressure and the squirters will dribble if there is too much pressure.
Volkswagen!
(Compression 8.7:1)
Michaellatini
PostPosted: Mon Jul 21, 2025 3:15 pm    Post subject: Re: Washer Bottle Cap Reply with quote
Thank you, Jeffery. I put 35psi in the tire and it worked outside the car and checked it in the car and bumped it to 36psi. No air is getting into the bottle. I am thinking there may be a pc missing but, have no idea. Rolling Eyes
sputnick60
sputnick60 is offline
PostPosted: Tue Jul 22, 2025 2:53 am    Post subject: Re: Washer Bottle Cap Reply with quote
There are some notes on the Samba about the Helphos Wash bottle system.
https://www.thesamba.com/vw/archives/manuals/helphos_washer_bottle_german.php
Not sure if that is much of a guide for you in German, but the text has been translated.
Nicholas
'66 Karmann Ghia Cabriolet...
'65 Porsche 356C Coupe...
Michaellatini
PostPosted: Tue Jul 22, 2025 11:53 am    Post subject: Re: Washer Bottle Cap Reply with quote
Thanks Nicolas. I will go over it.
M
Michaellatini
PostPosted: Wed Jul 23, 2025 1:54 pm    Post subject: Re: Washer Bottle Cap Reply with quote
I read in the owners manual, 35psi and just saw another person's post that said 42psi. I'll try the 42 this weekend.
