JealousJack Samba Member
Joined: August 10, 2016 Posts: 138 Location: Vancouver
Posted: Wed Jul 23, 2025 11:40 am Post subject: 1989 Auto trans fluid rising? |
Hey all,
My auto trans 89 Vanagon transmission started leaking recently from around the pan. I went to check the level of fluid- and it seems to be above the top dot cold, indicating that the fluid level is rising.
Is that indicative that the internal cooler is failing and pouring coolant into the transmission? Has anyone dealt with this before and how did you address it?
Thanks! |
MarkWard Samba Member
Joined: February 09, 2005 Posts: 19073 Location: Retired South Florida
Posted: Wed Jul 23, 2025 11:50 am Post subject: Re: 1989 Auto trans fluid rising? |
Coolant mixing with ATF would give you a milkshake looking mixture. I’d check the level in the differential first. Then set the level of the ATF to spec. Then see if it’s gaining.
There are 2 seals back to back that keep the ATF and Gear oil separate. They do fail. |
67rustavenger Samba Member
Joined: February 24, 2015 Posts: 11500 Location: Oregon
Posted: Wed Jul 23, 2025 12:08 pm Post subject: Re: 1989 Auto trans fluid rising? |
| MarkWard wrote: |
Mark, doesn't the diff lube have that distinctive sulfur aroma like a manual trans would?
If that's true, the ATF mixed with diff lube would stink to high heaven if, it were leaking into the trans. _________________ I have learned over the years.
Buy Once, Cry Once!
GFY's Xevin and VW_Jimbo!
2003 Astrovan? GFYS again, Xevin!
Don't let your bad ideas remain, ideas! |
Posted: Wed Jul 23, 2025 12:13 pm Post subject: Re: 1989 Auto trans fluid rising? |
Yeah I know that smell, and I definitely don’t smell that. The coolant itself looks pretty good- clear and not like milkshake- and the ATF on the dipstick is red and oily as notmal. I haven’t drained the ATF to see what that looks like though.
Was planning on driving a good 6 hours in it today- looks like we’re taking the car!
J |
Posted: Wed Jul 23, 2025 12:27 pm Post subject: Re: 1989 Auto trans fluid rising? |
| JealousJack wrote: |
J |
Gotcha! I was spit balling on what might be the issue.
I'm new to the auto transaxle game so, I don't know exactly how things are oriented. _________________ I have learned over the years.
Buy Once, Cry Once!
Posted: Wed Jul 23, 2025 12:45 pm Post subject: Re: 1989 Auto trans fluid rising? |
I’m not sure if this makes any different whatsoever but I replaced my water pump very recently- I’m not sure how that could impact a transmission, but prior to that, I had no leaks.
I suppose I could see a world in which the coolant system wasn’t bled properly, causing the oil cooler to break and leak into the transmission, compromising seals that may have been on their last legs?
I’m also new to the auto. I knew my way around my 86 manual pretty well- but the autos seem to have less documentation on the internet. |
clamay Samba Member
Posted: Wed Jul 23, 2025 1:07 pm Post subject: Re: 1989 Auto trans fluid rising? |
The only accurate way to check the level of the ATF is with the transmission fluid hot and at idle in park. _________________ 91 Carat, automatic, GW 2.2, GW EFI, Peloquin TBD
When you come to a fork in the road, take it. --Yogi Berra |
Posted: Wed Jul 23, 2025 1:17 pm Post subject: Re: 1989 Auto trans fluid rising? |
If you had coolant leaking into the transaxle, The dip stick would look like it had been dipped into a strawberry milkshake.
You stated that the fluid is clear.
Check the level as clamay has stated above. _________________ I have learned over the years.
Buy Once, Cry Once!
kamzcab86 Samba Moderator
Posted: Wed Jul 23, 2025 1:38 pm Post subject: Re: 1989 Auto trans fluid rising? |
Thanks guys, good to know! I guess I read somewhere that checking cold was the way. Glad to hear it.
Ok, so things so far aren’t looking as bad as I figured. Not sure I want to risk a trip today (we were about to drive 6 hours), but perhaps I start with gaskets, inspection, filter etc. when we get back.
The transmission seems to be functioning amazingly. Barely noticeable shifts! |
Posted: Wed Jul 23, 2025 2:00 pm Post subject: Re: 1989 Auto trans fluid rising? |
| If you fill to the mark cold, as it gets hot the fluid with expand the blow out wherever it can. |
SCM Samba Member
Joined: January 26, 2011 Posts: 3477 Location: Bozeman MT
Posted: Wed Jul 23, 2025 2:05 pm Post subject: Re: 1989 Auto trans fluid rising? |
| Thanks guys, good to know! I guess I read somewhere that checking cold was the way. |
Definately not. I think the spec is to drive it for 7 miles then check with the van parked in N with the motor running. _________________ '91 Westfalia GL Automatic (GTA "Turbo" Rebuild w/Peloquin) and 2.3L GoWesty Engine |
Posted: Wed Jul 23, 2025 11:16 pm Post subject: Re: 1989 Auto trans fluid rising? |
This was such an excellent quick resource thanks so much. I was reading some anecdotes and such, and after reading the stories, seeing nearly my exact problem- I kinda wish I hadn’t wimped out and just made the 400km trip with the van instead of taking a car.
I’ll replace those gaskets and the filter when I’m home. If that doesn’t fix the issue, I’ll take the transmission out this winter and change the large o-ring and seals etc.
What’s the verdict on best transmission external cooler these days? |
jlrftype7 Samba Member
Posted: Fri Jul 25, 2025 12:12 pm Post subject: Re: 1989 Auto trans fluid rising? |
here's Kourts fill/check sheet that I copied as a reference out of his thread. Straight from the Bentley.
_________________ '68 Westy- my first VW and vehicle/Bus- long gone.- sold it to a traveling Swiss couple....
‘84 Tin Top - Hilga....Auto |
Posted: Fri Jul 25, 2025 12:15 pm Post subject: Re: 1989 Auto trans fluid rising? |
As for Coolers, we're still running the GoWesty cooler set-up from a few years ago install. It didn't work for Kourt in his set-up, so he ran an aux fan assisted version to get better cooling and ditched the Gowesty version.
But, we're up in Chicago, so we don't see the temps Kourt was running into down in Texas day to day. _________________ '68 Westy- my first VW and vehicle/Bus- long gone.- sold it to a traveling Swiss couple....
SCM Samba Member
Posted: Fri Jul 25, 2025 2:29 pm Post subject: Re: 1989 Auto trans fluid rising? |
I would too.
When I had my trans rebuilt it seemed that the heat sink style was falling out of favor for the remote finned type and so that's what I got.
There's some opinions out there that there's not much reason for ANY kind of cooler on our auto transmissions. The old VWs never used 'em (do your own research on that though). I've had the hoses on my finned style cooler leak and it was actually easier/cheaper to order an entire new cooler system thing because just buying hoses turns out to be a confusing nightmare for a DIYer that tends to overthink things). _________________ '91 Westfalia GL Automatic (GTA "Turbo" Rebuild w/Peloquin) and 2.3L GoWesty Engine |
Shonandb  Samba Member
Joined: January 12, 2019 Posts: 2247 Location: Vancouver, BC
Posted: Fri Jul 25, 2025 2:40 pm Post subject: Re: 1989 Auto trans fluid rising? |
Regarding the trans fluid cooler, I went with a 2' aluminum finned cooler with a 180F thermo unit as I didn't want to have any issues using a fan dependent oil cooler. I have 40,000 km on my swap and regularly pull a sport trailer and drive in the mountains during the summer (90F - 100F) and haven't had any issues. I recently did a trans fluid change and the filter and pan were clean so the cooler has been effective but I didn't know the actual operating temps.
To get a better sense of actual temps, I installed a sensor and gauge for trans fluid temp and the output temp gets up to about 120C while pulling a long hill at 120 kph before the cooler and is around 100C after the cooler flowing back into the transmission. Normal driving is around 95C coming out of the trans and 75-80C after the cooler. flowing back into the trans. The normal stock cooler basically runs at the same temp as your engine coolant so I think my trans fluid is running a bit cooler than normal.
A pic from 2018 when I was installing.
_________________ *******************************
Previous 1973 Panel Bus:
Click to view image |
Posted: Mon Jul 28, 2025 9:53 pm Post subject: Re: 1989 Auto trans fluid rising? |
Ok, so what I’ve learned from those helpful links is mainly-
My oil is not fluctuating. What’s been happening is I’ve been checking the van OFF. It doesn’t explicitly say in the Bentley but the 20 degree mark, but it has to be running when you do that initial check. Then you warm it up and check again (driving 10 miles or so).
So everything is fine on that end. I still can’t quite figure out what fluid I’m leaking. I left for the weekend and put a piece of white thick paper under the van. When I came back, it was hard to tell which color and the smell isn’t really anything. I don’t smell ATF, or coolant. It’s definitely oil, or oily. I’ll drop an actual clear pan under it the next couple days. Fairly convinced it’s atf from the time I put my finger right up to it.
One thing I was inspired by in the literature provided was one member who didn’t want to cancel his trip but also didn’t have time to reseal the trans. He ended up driving 10,000 miles in the end and all was fine till he got to the repair. So I’m going to continue to monitor it and enjoy the rest of the summer. I’ll pull the transmission in the winter, install a few seals and the large o-ring and do the cooler at the same time.
Appreciate all the help guys.
Jeff |
Abscate Samba Member
Joined: October 05, 2014 Posts: 24363 Location: NYC/Upstate/ROW
Posted: Tue Jul 29, 2025 3:14 am Post subject: Re: 1989 Auto trans fluid rising? |
| Quote: |
| doesn’t explicitly say in the Bentley but the 20 degree mark, but it has to be running when you do that initial check. Then you warm it up and check again (driving 10 miles or so). |
Engine idling
The Bentley is not a DIY manual, it is a technical reference for a trained mechanic. Because most/all AT pump fluid through multiple functional parts, fluid levels are a function of temperature and operating conditions,so you have to follow the check procedures carefully _________________ 🇺🇸 🇺🇸 🇺🇸 🇺🇸 🇺🇸 🇺🇸 🇺🇸 🍊 🍊 🍊 |
