Mrorangecrush77 Samba Member
Posted: Fri Jun 27, 2025 1:18 pm Post subject: Trailer lighting within the VW? |
Hi, curiosity has gotten the best of me and I’m thinking I could tie directly into my buggies existing wiring harness and utilize the cars own lights rather than those silly magnetic tow lights. I’m curious if this is feasible or if I may run into electrical problems along the way? I’d guess it would work from my truck as the trailer harness is already fused. So long as the wiring is off in the buggy or battery disconnected? Any ideas? |
Dale M. Samba Member
Joined: April 12, 2006 Posts: 20833 Location: Just a tiny bit west of Yosemite Valley
Posted: Fri Jun 27, 2025 2:09 pm Post subject: Re: Trailer lighting within the VW? |
YEs it is.... I uses a umbilical from PU 7 pin plug to 4 pin plug on front of buggy....
Used isolation diodes onto buggy wiring to keep feedback from illuminating front of buggy lights...
Diodes....
https://www.etrailer.com/Accessories-and-Parts/Hopkins/48955.html
Also "typical" wiring instructions at above link... _________________ “Fear The Government That Wants To Take Your Guns"
rayjay Samba Member
Joined: March 26, 2008 Posts: 1634 Location: Buford GA
Posted: Fri Jun 27, 2025 5:53 pm Post subject: Re: Trailer lighting within the VW? |
I would install connectors in the existing wiring harness up in the trunk just after the fuse box. Then I would make a towing lights wiring harness that would go from the connector at the hitch up to the trunk. Unplug the first connector and then plug the towing wiring harness to the male connector that leads back to the tail lights. Voila. Super simple tow light arrangement. When you get where you are going you disconnect the tow light harness and reconnect the original tail light wiring and you have normal brake and tail lights again.
I was also going to use trailer harness connectors back at the engine so that instead of disconnecting a bunch of wires I could just disconnect one large connector and then remove the engine. |
Posted: Sat Jun 28, 2025 7:24 pm Post subject: Re: Trailer lighting within the VW? |
rayjay wrote: |
So long as the connections hold up, that’s a great idea!!! |
Posted: Sat Jun 28, 2025 7:25 pm Post subject: Re: Trailer lighting within the VW? |
I like the idea of the isolation diodes! I don’t think I would have thought of that, do I need to disconnect the vehicle in tow battery? I think all of this will come to fruition when the “full rewire” commences. Building up the guts and trying to find time to tear it all apart |
rayjay Samba Member
Posted: Sun Jun 29, 2025 6:44 am Post subject: Re: Trailer lighting within the VW? |
Mrorangecrush77 wrote: |
Buy a ratcheting terminal crimper and an automatic wire stripper and a heat gun and a variety of heat shrink tubing and high quality non-insulated connectors and suddenly wiring is a joy instead of a chore. You will no longer worry about connections holding up.
For my idea on the tow harness you would be using butt connectors.
https://imgur.com/a/0wNPZ3e
https://imgur.com/a/XEEnebm
https://imgur.com/a/FbHrYWn |
Posted: Sun Jun 29, 2025 6:46 am Post subject: Re: Trailer lighting within the VW? |
NO need to disconnect towed vehicle battery.... IN my application the umbilical stays ZIP tied to tow bar.... Install tow bar, plug in both ends of umbilical and we are off.... Technically the towed vehicle battery should be isolated by the switches that controls the lights... _________________ “Fear The Government That Wants To Take Your Guns"
Posted: Sun Jun 29, 2025 10:49 am Post subject: Re: Trailer lighting within the VW? |
rayjay wrote: |
I own just about all of that. Yet wiring still isn’t a joy. I still encounter faulty connections. I’d venture to say corrosion plays a large part in that frustration. Butt connectors are my go-to |
EVfun  Samba Member
Posted: Sun Jun 29, 2025 1:12 pm Post subject: Re: Trailer lighting within the VW? |
Just a couple of thoughts...
If you are using bare terminals and heat shrink tubing (which I recommend) instead of pre-insulated terminals then I recommend the Klein 1005 crimper. Don't get a cheap substitute, the real thing works and lasts and is only around $30.
The other thought is that if the car is wired normally and working correctly you shouldn't actually need the isolating diodes. That said, I have them on the brake/turn signal wires in my current buggy as a safety measure (a power backfeed will happen if you accidentally leave the turn signal switch on or your brake light switch sticks on). I don't have a blocking diode on the tail light line. On the current buggy the front parking lights are separate from the tail lights (front parking lights go out when the headlights are on) but on my first buggy not having the blocking diodes meant that the front parking lights and tail lights were on when the towing vehicle had its lights on. That was less than 1 amp of extra load. _________________
Wildthings wrote: |
VOLKSWAGNUT Fastest VW Belt Changer
Joined: October 14, 2007 Posts: 11181 Location: Flippin' a Belt........ .... Off-n-On ... NC USA
Posted: Sat Aug 16, 2025 10:13 am Post subject: Re: Trailer lighting within the VW? |
VOLKSWAGNUT wrote: |
I simply built in and tied in a trailer harness into the buggy's turn signals (alternative stop/brake) and tail/park lamps.
I just tuck the plug under the front hood when not in use. An umbilical from the buggy to the tow vehicle is used when needed.
No diodes.. no convertor.
Works flawless...
The open circuits of the turn and headlamp switches keep the buggy main electrical and truck electrical seperate.
My main towing truck has built in trailer circuit fuses as well.
Our buggy uses 62-67 taillamps with Euro lenses...(most of the time)..... and 68-69 front turns/parks.
I carry solid red (US spec) tail lamp lenses for those states that dont "allow" amber stop lamps.
IMO the amber top rear Euro lenses are noticed much sooner.. both day and night.
When the park/headlamps are activated, the park/tail lamps at all 4 corners of the buggy illuminate.
When the turns are activated, the front and rear (upper) turns both flash.
When the stops are applied all 4 "turns" illuminate. (So yes... front "stop" lamps").
If the turn is activated while the stop lamp is on... it cancels the stop lamp and activates the turn per side selected.
I personally like the benefit of seeing the front corners in the dark as park/turns, using dual filament 68-69 front lamps as sort of side markers.
IMO.. the fronts ON and or Flashing helps spotting in the rear view mirror a breeze and it may also help the jackasses that decide to dart in behind the truck.... actually see it BEFORE crashing into it..
The alternative... and if you are OCD...splice to tail and stop/brake only. This way all the lights are in the rear.
So...pretty much like a trailer.. |
_________________ aka Ken {o\!/o}
Rebuilt to drive not decorate
Usually and often edited |
