Type 4 engine research project
Page: 1, 2, 3  Next
888 is offline
PostPosted: Wed Aug 27, 2025 9:56 am    Post subject: Type 4 engine research project Reply with quote
Hi all,
I'm looking at buying a 73 bay window that has been sitting for a very long time with a seized engine (said to be original, very hard to see the engine code) and another free turning engine inside. That engine is a CD code which should be an automatic 73 from the references on here. Bus is a manual.
It will be the first Type 4 engine I've really gotten into, I usually work with Type 1 engines.
I've been doing some research on here and came up with the following threads to read through to get familiar with rebuilding a Type 4 engine.
https://www.thesamba.com/vw/forum/viewtopic.php?t=743948&highlight=
https://www.thesamba.com/vw/forum/viewtopic.php?t=503859
https://www.thesamba.com/vw/forum/viewtopic.php?t=538136&highlight=
Are there others that I should be reading?
Thanks!
92 Dodge Cummins D-350
1973 bay window project
timvw7476
timvw7476 is offline
PostPosted: Wed Aug 27, 2025 10:33 am    Post subject: Re: Type 4 engine research project Reply with quote
The Tom Wilson book ' How To Rebuild VW Engines' is The One . Hands Down.
But You've been working on Type I so you are 98% of the way there if your Type I stuff carried you around several years...... lol.
airschooled
Air-Schooled
airschooled is offline
PostPosted: Wed Aug 27, 2025 11:03 am    Post subject: Re: Type 4 engine research project Reply with quote
Doing yourself a disservice if you haven’t read Clatter’s threads- always great insight into the decision making process.
That’s the big one, along with project management. By the time you’re squirting sealant onto the case halves, you’ll have put it together and taken it apart so many times you won’t need the book anymore.
Robbie
www.airschooled.com
Road trip reports and tech blog:
SGKent Premium Member
SGKent is offline
PostPosted: Wed Aug 27, 2025 2:58 pm    Post subject: Re: Type 4 engine research project Reply with quote
if you can do type one you can do type two. A little different but doable. Here is a thread when I last did my 1977.
https://www.thesamba.com/vw/forum/viewtopic.php?t=724313&highlight=1977
George Carlin:
Skills@EuroCarsPlus:
my59
my59 is offline
PostPosted: Wed Aug 27, 2025 3:17 pm    Post subject: Re: Type 4 engine research project Reply with quote
When I rebuilt mine I reviewed the Wilson book and highlighted everything that pertained to the Type 4 engine before I got into it to remove as much confusion as I could before hand.
I read as many Type 4 rebuild threads as I could find here as well.
Finding a machine shop with Type 4 experience took some time.
my59: Well son, my grandfather died before I got to drive it, so does that answer your question?
Other:'12 Jetta, '77 Benz 300D, and a 74 MG Midget.
raygreenwood
raygreenwood is offline
PostPosted: Wed Aug 27, 2025 5:34 pm    Post subject: Re: Type 4 engine research project Reply with quote
Make sure you get and use a dial bore gauge for checking the case main bores. Even if it's a cheap Chinese one it will be fine.
DO NOT automatically align bore the case. I. My experience, 7 out of 10 type 4 cases do not need align bore. Measure it and post what you have.
For example, it's common on well used but not abused....type 4 engines to have kind of a dent in the main bores just off axis from the case centerline. It can be as deep as 0.002" and not be an issue.....as long as that 0.002" dent (usually put there from the combustion/ignition point in the rotation).....does not span more than about 20°....about 2/3 of the distance between say 1 and 2 or 2 and 3 on a clo k face the diameter of the crank bore......the new bearings will not even notice that tiny dip.
It's hard to get good and accurate align bores on type 4. Always has been. It's even harder to get new oversized OD bearings that are uniform. Ray
888
888 is offline
PostPosted: Thu Aug 28, 2025 2:23 am    Post subject: Re: Type 4 engine research project Reply with quote
Thanks for the responses, guys. I did have an aircooled Vanagon engine apart some years ago but I was rebuilding what was there, and not into heavy analysis. I have forgotten most of whatever I learned.
Ray, I read some of your responses in a few of the threads and I have quite a few measuring devices, mag base with .0005" resolution indicator. I have dial and digital calipers and manual micrometers of various sizes, and should have some manual bore gauges to use with micrometers. I think they should work for what I need to do, if not, I will find a set with a dial. Most are Mitutoyo or some other decent quality brand. I accumulated all of this when I had Type 1's that I sold when I decided I was done with beetles a year ago and started looking for a bus.
I didn't use them much on the beetles but I use them at work. I spent 35 years working with complex machinery...not a toolmaker, but pretty decent with metrology and figuring out things. Both of my sons are toolmakers so they should have whatever I don't.
I'll check into the recommended book. I have a Bentley and Haynes manual for every flavor of VW other than a 411.
The bus for sale is actually listed on here, it's an orange 73 in Ohio. I no longer do sight unseen buys due to so many disappointments and this is nearby so I can see it for myself and know what it is.
Being in Ohio, it's easier to deal with mechanicals than to fix rust and this one is pretty solid. It will never be a show vehicle but it has some character and isn't eaten up with rust so so I'm going to try to swing a deal.
More to come (and probably another build thread).
Thanks again.
888
888 is offline
PostPosted: Sat Aug 30, 2025 3:47 am    Post subject: Re: Type 4 engine research project Reply with quote
I bought the bus, will get it home this weekend or first of the week, more to come.
SGKent is offline
PostPosted: Sat Aug 30, 2025 3:55 pm    Post subject: Re: Type 4 engine research project Reply with quote
enjoy. Just remember that it is a journey and not a destination.
George Carlin:
TomWesty
TomWesty is offline
PostPosted: Sat Aug 30, 2025 9:10 pm    Post subject: Re: Type 4 engine research project Reply with quote
Hi Steve,
What engine is that in your avatar?
SGKent is offline
PostPosted: Sun Aug 31, 2025 12:04 am    Post subject: Re: Type 4 engine research project Reply with quote
TomWesty wrote:
Hi Steve,
Fiat 124 1608 crossflow overhead cam with Weber downdrafts used in Abarth rally cars. I built SCCA racing engines in my youth. Or drove my 124 around town with the top down enjoying the view. We had about the same road highways as we do today but like 2/3 less people. Now we have 3 times as many people, same highways and 10x the taxes to pay for all those who can't afford to pay their share of the taxes. Memories of the good times building the engines and watching them win is all I have left, other than my health and scotties.
1492 124 Spider (GP) that could out race the 1608 (FP) due to the shorter stroke that allowed higher RPM and quicker reving.
Blue and Green 124 spiders at turn 6 at the old Riverside International Raceway. 1492 cc took 1st (GP) that race, and 1608 took 2nd (FP). Both were my engines. About 145 - 150 HP. Weber progressives. I could never convince Leland he could go faster with a smaller displacement engine, but Charlie believed me so he won. Simple physics. Bigger is not always better. The smaller displacement engine had about a 400 pound weight advantage in the GP class but had the identical venturi size as the larger engine. Do the math. Smile
George Carlin:
888
888 is offline
PostPosted: Tue Sep 23, 2025 1:48 am    Post subject: Re: Type 4 engine research project Reply with quote
The bus is home, the spare engine that was inside is out and on a cart for disassembly.
I've soaked all of the engine fasteners down with a 50/50 mix of acetone and ATF to hopefully help loosen them up for disassembly.
I have a loft to build in the barn so I can get my floor space back but after that, I'll be ready to start seeing what surprises the engine has for me.
I've already discovered that it has oil in it so I guess that is a good thing.
More to follow
888
888 is offline
PostPosted: Thu Sep 25, 2025 2:34 am    Post subject: Re: Type 4 engine research project Reply with quote
As you can see in the photo in the previous post, the "good" engine in the back was an automatic so it still has the drive plate attached. I've never worked on an engine from a VW automatic before.
I have the triple square bit for the bolts to the crank but looking for a way to keep the crank from turning.
The Type 2 Bentley shows some sort of a fixture. Doing a search on here, I've found a reference to tool LR000133 from vwparts.net on an old thread but the link is dead.
Does anyone know where to find one, what they look like, or is making something from angle iron or bar stock to span two holes in the drive plate usually enough to get the drive plate off?
Thanks
orwell84
orwell84 is offline
PostPosted: Thu Sep 25, 2025 5:55 am    Post subject: Re: Type 4 engine research project Reply with quote
Goes well with an impact wrench. Engines are otherwise the same.
888
888 is offline
PostPosted: Mon Oct 06, 2025 4:51 pm    Post subject: Re: Type 4 engine research project Reply with quote
Well, those drive plate bolts have been putting up quite a fight.
So far, I've thrown all of this at them and they haven't budged.
Last effort will be recruiting my 6'7" son to help with a longer pipe on a breaker but then it becomes an issue if I'm strong enough to provide enough counterforce to keep it on the cart:)
Hopefully, I don't have to split the case and give up on the crankshaft.
More to come.
Abscate
Abscate is offline
PostPosted: Tue Oct 07, 2025 1:02 am    Post subject: Re: Type 4 engine research project Reply with quote
Heat cool heat cool heat cool and then impact with a good quality bit not bought at a junk store
Torque is not the answer to stuck bolts
888
888 is offline
PostPosted: Tue Oct 07, 2025 3:11 am    Post subject: Re: Type 4 engine research project Reply with quote
Thanks for the response. I will look for my propane torch.
I tried the Milwaukee impact with a good quality bit after dosing with acetone and ATF a few times and letting it soak. That combination has gotten absolutely everything else I've run into loose in the past, I'm really surprised it hasn't worked here.
The engine spins when I use the impact, thus the spanner bar. It's difficult to keep the impact in the bolt and hold the spanner by myself, thus recruiting my son for help.
I figured while he was here we would try the breaker bar and pipe.
Did VW happen use a threadlocker on these bolts?
raygreenwood
PostPosted: Tue Oct 07, 2025 5:40 am    Post subject: Re: Type 4 engine research project Reply with quote
As Abscate said....heat cool/heat cool...cycles.
Heat them up and when they are hot.....carefully....dribble the acetone/ATF mix on the bolt. The heat causes expansion. As the acetone/ATF hits it, in that split second it quenched and shocks the joint between bolt and crank and over a few cycles slowly wicks ATF into the microscopic surface texture.
Also as he noted....IMPACT is key. If you do not have a really gutsy Impact wrench, a hand Impact driver....1/2" drive in this case with a 5 lb sledge hand hammer has really worked well for getting these moving.
When doing that, get a stack of stout wood and blocks. Tilt the case up vertical so the drive plate is up in the air and horizontal. Block it securely. If you buy an Impact driver with that red nylon guard it's safer but the best brand of Impact driver I have ever had is the Lisle brand #30750 for the set. #30000 for just the driver.
https://shop.advanceautoparts.com/p/lisle-30750-ha...0zEALw_wcB
Ray
soissisc
soissisc is offline
PostPosted: Tue Oct 07, 2025 6:38 am    Post subject: Re: Type 4 engine research project Reply with quote
I like to have the engine on the floor, with the bar supported by the floor, and a pipe on the breaker bar also applying force down towards the floor. Before you try to break it free, tap on the bolt at least 50 times with the socket on the head of the bolt and hitting the socket with a good 2 or 5 lbs hammer. This method may twist the head of the bolt off though, buyer beware.
Mark
68 Westy
92 Jetta (oh it is retired)
99 Eurovan
05 NBC
06 Audi A3
72 Westy (I am going to fix it up)
lil-jinx
lil-jinx is offline
PostPosted: Tue Oct 07, 2025 8:50 am    Post subject: Re: Type 4 engine research project Reply with quote
those bolts probably has lock tite on them ,heating to about 700f will break the lock tite,it,s unlikely that the bolts are frozen from corrosion,
1968 Dune Buggy sold dec 2024
1974 parts bus
Page: 1, 2, 3  Next
