beetleman217 Samba Member
Posted: Wed Sep 17, 2025 9:12 pm Post subject: Engine coughing and losing power after driving in heavy rain |
Camping in our 1977 Westy (stock 2L fuel injection) was fine until we drove through a thunderstorm with torrential rain. The bus ran fine in the rain, but after an hour's stop for lunch, as soon as we started driving again it started to sputter and lose power. Upon inspection there was absolutely no water in the engine bay. Everything looked normal.
We had it towed to a garage. The next morning it started fine and drove perfectly! So whatever got wet simply dried up overnight.
Now I'm trying to figure out what got wet, so maybe I can shroud it somehow to prevent this from happening again. The fuel pump and filter are the only components that sit outside the engine bay, but they're tucked neatly and the fuel pump connectors are insulated.
Could this have been water getting inside the fuel tank (through the gas cap)? Would that have resolved overnight?
Thoughts and ideas would be greatly appreciated.
_________________ If all else fails, stop using all else
1977 Westfalia
1961 Beetle |
Bnanwel Samba Member
Joined: November 10, 2022 Posts: 323 Location: Ft Lauderdale
Posted: Wed Sep 17, 2025 9:33 pm Post subject: Re: Engine coughing and losing power after driving in heavy rain |
Maybe condensation in the distributor cap? Water in the fuel would not have resolved itself. _________________ ‘72 Karmann Ghia Conv.
‘73 Karmann Ghia Coupe
‘74 Karmann Ghia Coupe
‘70 Deluxe
‘72 Deluxe |
Posted: Wed Sep 17, 2025 10:31 pm Post subject: Re: Engine coughing and losing power after driving in heavy rain |
Bnanwel wrote: |
Maybe condensation in the distributor cap? Water in the fuel would not have resolved itself. |
How would condensation there occur? It's a relatively sealed space inside the engine bay which is also relatively sealed. _________________ If all else fails, stop using all else
1977 Westfalia
1961 Beetle |
KTPhil  Samba Member
Joined: April 06, 2006 Posts: 36046 Location: Conejo Valley, CA
Posted: Wed Sep 17, 2025 11:03 pm Post subject: Re: Engine coughing and losing power after driving in heavy rain |
Not sealed at all. Good enough to keep too much cooling air from leaking but nothing that will stop moisture in the air from migrating from wet to dry. This is in the bay and under the cap, which is also not sealed.
I would suspect old SP wires or connectors that are arcing. Then I'd swap distributor cap and rotor with the spares you should be carrying anyway. _________________ Current Fleet:
- '71 Fastback
- '69 Westfalia
Retired:
- '67 Beetle
- '65 Beetle (x2)
- '65 Bus
- '71 Squareback
Posted: Wed Sep 17, 2025 11:31 pm Post subject: Re: Engine coughing and losing power after driving in heavy rain |
KTPhil wrote: |
Not sealed at all. Good enough to keep too much air form leaking but nothing that will stop moisture in the air from migrating from wet to dry. This is in the bay and under the cap, which is also not sealed.
I would suspect old SP wires or connectors that are arcing. Then I'd swap distributor cap and rotor with the spares you should be carrying anyway. |
So in theory, while stranded on the side of the road, if I had removed the dist cap and let it dry or even used a hair dryer on it, this would have solved the problem? Cause I would've been more than happy to have done that than call the tow truck! _________________ If all else fails, stop using all else
1977 Westfalia
1961 Beetle |
Abscate  Samba Member
Joined: October 05, 2014 Posts: 24127 Location: NYC/Upstate/ROW
Posted: Thu Sep 18, 2025 3:02 am Post subject: Re: Engine coughing and losing power after driving in heavy rain |
Wiping it out with a dry paper towel will usually fix it. A trace of moisture will rob the high voltage, low current discharge and stop your Bus , cold. _________________ 🇺🇸 🇺🇸 🇺🇸 🇺🇸 🇺🇸 🇺🇸 🇺🇸 🍊 🍊 🍊 |
vwmaniaman Samba Member
Joined: June 07, 2005 Posts: 605 Location: Grand Rivers,KY
Posted: Thu Sep 18, 2025 5:29 am Post subject: Re: Engine coughing and losing power after driving in heavy rain |
Spray inside the cap with some WD40 and wipe it out. Water Displacement 40. Be sure to wipe it after spraying because it is flammable. _________________ Working on a VW is like fun with a friend!
65 Beetle
75 Westy "Pumpkin Van"
86 Westy "Brown Betty"
87 Cabrio |
aeromech Samba Member
Joined: January 24, 2006 Posts: 17674 Location: San Diego, California
Posted: Thu Sep 18, 2025 9:07 am Post subject: Re: Engine coughing and losing power after driving in heavy rain |
Electronic points solved the problem for me. _________________ Lead Mechanic: San Diego Air and Space Museum
Airbus A319,320,321
DC9/MD80
BAe146
Fokker F28/F100
VW type 1 1962,63,65,69,72
VW Jetta
VW Passat
mikedjames Samba Member
Joined: July 02, 2012 Posts: 3372 Location: Hamble, Hampshire, UK
Posted: Thu Sep 18, 2025 9:56 am Post subject: Re: Engine coughing and losing power after driving in heavy rain |
I once had water end up over the cap of the distributor and even managed to get into the HT sockets on top.. We were driving for about 20 minutes past a French town that was having a medieval fair .. but it was raining so hard the roads were like streams and rivers. So we decided to give it a miss.
We stopped in a car park, in a "creative" space bumped up on a kerb where we were at least not blocking the roadway.. This meant the left hand side of the bus was higher and so the rain poured in.
It would not start immediately but the sun came out, we went to a nearby supermarket and did some shoppjng. And after that we continued our journey as it started once it dried out by itself. _________________ Ancient vehicles and vessels
SGKent  Samba Member
Joined: October 30, 2007 Posts: 42807 Location: at the beach
Posted: Thu Sep 18, 2025 1:01 pm Post subject: Re: Engine coughing and losing power after driving in heavy rain |
ignition wires grounding out is a possibility. Next time you have 10 minutes in the eve, with the bus running at idle, being extra careful of the moving fan belt in the dark - long hair, long sleeves etc., use a mist bottle to mist the ignition wires. If that is it, the engine should start acting up, and you might see a halo or sparks between wires or to ground. Common issue when the wire jacket begins to fail. If so it will eventually get to the point that fog or a day with high humidity will cause it. _________________ George Carlin:
Skills@EuroCarsPlus:
"never time to do it right but always time to do it twice"  |
wagen19 Samba Member
Joined: November 16, 2007 Posts: 774 Location: germany
Posted: Thu Sep 18, 2025 2:01 pm Post subject: Re: Engine coughing and losing power after driving in heavy rain |
SGKent wrote: |
ignition wires grounding out is a possibility. Next time you have 10 minutes in the eve, with the bus running at idle, being extra careful of the moving fan belt in the dark - long hair, long sleeves etc., use a mist bottle to mist the ignition wires. If that is it, the engine should start acting up, and you might see a halo or sparks between wires or to ground. Common issue when the wire jacket begins to fail. If so it will eventually get to the point that fog or a day with high humidity will cause it. |
2 ideas:
a) old spark plug connectors can make problems, getting shorts when getting humid
b) is it possible that water went into paper airfilter, has reduced or blocked air flow and has dried out later? Is there water in air box? |
my59 Samba Member
Joined: August 13, 2003 Posts: 3985 Location: connecting the dots
Posted: Thu Sep 18, 2025 5:39 pm Post subject: Re: Engine coughing and losing power after driving in heavy rain |
Years back i sailed my dad's Chevy wagon thru a super deep puddle and the car ran like crap after. Turned out the distributor cap cracked. _________________ my59: Well son, my grandfather died before I got to drive it, so does that answer your question?
Other:'12 Jetta, '77 Benz 300D, and a 74 MG Midget.
Xevin  Samba Member
Posted: Thu Sep 18, 2025 7:20 pm Post subject: Re: Engine coughing and losing power after driving in heavy rain |
SGKent wrote: |
_________________ Keep on Busin'
67rustavenger wrote: |
GFY's Xevin and VW_Jimbo! |
Clatter wrote: |
Damn that Xevin...  |
skills@eurocarsplus wrote: |
SGKent wrote: |
Posted: Fri Sep 19, 2025 3:32 am Post subject: Re: Engine coughing and losing power after driving in heavy rain |
Eventually, if the engine sheets are not complete, has holes, or the seal around is bad, from the bottom front side to trans, there can water from the street go inside engine compartment and into air box, air filter element (paper).
(rusted battery floor, holes there?) |
lil-jinx Samba Member
Joined: August 14, 2013 Posts: 1667 Location: New Brunswick,Canada
Posted: Fri Sep 19, 2025 6:35 am Post subject: Re: Engine coughing and losing power after driving in heavy rain |
friend of mine once had a k car ,it was running rough ,he blamed it on damp ignition wires, and decided to use wd40 to dry the wires ,with the engine running,it was a wonderful fire. _________________ https://www.thesamba.com/vw/forum/viewtopic.php?t=620186
1968 Dune Buggy sold dec 2024
1974 parts bus
A smart man learns from his mistakes,a very smart man learns from other's mistakes. |
Posted: Fri Sep 19, 2025 11:37 pm Post subject: Re: Engine coughing and losing power after driving in heavy rain |
I did have another water related issue where condensation occurred almost immediately after hitting a section of flooded road about 6 inches deep water for 50 feet of road under a railway bridge.. . The steam around the engine got into the home made ECU and for about 30 seconds after the puddle the ECU shut down and the EDIS-4 went into limp mode (it drops to 10 degrees timing advance) . Eventually the ECU rebooted successfully and the engine picked up by itself. Some silicone round the die cast box lid to create a seal and the problem has not reappeared.
There were definite signs of light corrosion inside the ECU box.
Next time the RusEFI ECU is going in a sealed box. _________________ Ancient vehicles and vessels
orwell84 Samba Member
Joined: May 14, 2007 Posts: 2786 Location: Plattsburgh, New York
Posted: Sat Sep 20, 2025 8:32 am Post subject: Re: Engine coughing and losing power after driving in heavy rain |
I think any kind of extreme condition like torrential rains, extreme heat, extended heat soak and vibration has the potential to cull the sick or weak components in the electrical system. Likewise for rubber vacuum hose boots or connectors. Sort of the same way the first cold snap kills a car battery. You realize that battery has been there longer than you thought.
I think the best way to prevent these kinds of breakdowns is to go through all those things thoroughly during tune ups. Electrical connections get loose or oxidize. The cap, wires or coil I thought I replaced a few years ago turns out to be 10 years old. The long periods of time my bus doesn’t get used put me out of the loop. |
Posted: Sat Sep 20, 2025 8:03 pm Post subject: Re: Engine coughing and losing power after driving in heavy rain |
Thank you all for the input. I see the wisdom of the crowd points toward condensation interfering with electrics. It sucks that the otherwise perfectly running-like-a-german-sewing-machine bus can't handle a little rain  _________________ If all else fails, stop using all else
1977 Westfalia
1961 Beetle |
Posted: Sun Sep 21, 2025 3:02 am Post subject: Re: Engine coughing and losing power after driving in heavy rain |
beetleman217 wrote: |
Thank you all for the input. I see the wisdom of the crowd points toward condensation interfering with electrics. It sucks that the otherwise perfectly running-like-a-german-sewing-machine bus can't handle a little rain  |
Ha! Do you have a bus or a submarine? OK, suggest a full tune up service and think about tight seal around engine to body. But asking myself, where all the water goes (out?), that came along the air ducts in. (and not inside of airfilter) Normally there is a cover on top of battery, but that part is very often missing on older busses. |
