I bought a project... Need some motor advice. (73 914 w/ 1.8L)
10degnorth
10degnorth is offline
PostPosted: Mon May 13, 2024 6:36 pm    Post subject: I bought a project... Need some motor advice. (73 914 w/ 1.8L) Reply with quote
Hello all, I recently picked up a rough but seemingly complete 73 914-4. It has a salvage title, been repainted, and allegedly swapped to a 1.8l (haven't pulled off the tin to check the numbers on top yet). It currently has an 009 and a pair of Weber 34 ICT's. It was apparently the previous owner's daily driver but was parked 6 years ago when the doors got stuck shut.
I have been working on getting it running for the last couple weeks without success. It took me longer than I would like to admit to figure out the timing. Currently I can crank the car and it will fire but not take off.
I finally did a compression test (open throttle, plugs out, but not warmed up since it doesn't start.) and found that I had 90, 100, 30, and 0 compression. The no compression didn't register on the gauge at all, I performed it a couple times on this cylinder to confirm the results weren't due to the gauge. I pulled the valve cover off and it seemed like both valves for the offending cylinder were moving. I went back and looked at the plugs from each cylinder and the 3 with compression all showed evidence of combustion and were black (I had previously cleaned them up) while the no-compression spark plug was wet with fuel. There are no other obvious leaks, my next step is to borrow a bore scope and check out the back side of the intake valve. My working theory is that maybe the seat collapsed. Alternative, I know that the PO was not a VW guy so I doubt he every adjusted the valves so an adjustment may be able to bring back that one cylinder if it is just really out of adjustment. Any thoughts on this?
I have the opportunity to pick up a 2.0 bus motor from a friend, he recently went through it and put about 15,000 miles on it before putting a Subaru in his 76 bus. I am aware that this motor would be a dog in the Porsche, not the mention having the dipstick in the wrong location. But would it make any sense to get it for the sake of making a franken motor between the 1.8L and the 2.0? Somewhere I read that the factory 2.0 pistons don't match up with the 66mm stoke rods, can anyone verify this?
My goal for this car would be to just get it moving as a driver and something to have fun with. I like how these cars are put together, I don't care about value, just happy to have one to work on. I have big dreams of a Subaru swap (better on a basket case than a show car right?) and mostly am just looking forward to a lot of learning, I know I have some rust repair in my future for sure as I removed the remains of the battery tray and have been investigating the hell hole.
I have more time and tools than sense and money.
1984 Wolfsburg Vanagon (Daily): https://www.thesamba.com/vw/forum/viewtopic.php?t=773912&highlight=
1988 Microsquirted, Wolfsburg Vanagon (Sold): https://www.thesamba.com/vw/forum/viewtopic.php?t=708000&highlight=
Microsquirt Conversion Guide (Work now Discontinued): https://docs.google.com/document/d/1laXykNPbRYS8MT...2imqd2pnx7
10degnorth
PostPosted: Mon May 13, 2024 6:42 pm    Post subject: Re: I bought a project... Need some motor advice. (73 914 w/ 1.8L) Reply with quote
Root_Werks
Root_Werks is offline
PostPosted: Thu May 16, 2024 2:44 pm    Post subject: Re: I bought a project... Need some motor advice. (73 914 w/ 1.8L) Reply with quote
You certainly have a dead cylinder. What's the valve lash like on the offending cylinder? Is one really loose like the valve is hanging up or bent (won't close)?
If the valve lash seems good, then it's likely engine pull time, pull the heads and see what things look like inside.
Bus motors can run in 914's, but they are typically stump pullers. I'd rather have a stock 1.7 FI than any version of a Bus 2.0 in a 914.
BUT, if it gets it on the road and the price is right, go for it!
-Dan
When I set my timing, why do I flush, then take a pee?
10degnorth
PostPosted: Thu May 16, 2024 3:04 pm    Post subject: Re: I bought a project... Need some motor advice. (73 914 w/ 1.8L) Reply with quote
-Dan
I got the bore scope out and it looks like the valve is getting pushed down and opening, but it doesn't pull all the way shut like there isn't enough (or any) spring pressure. Also most seems like the piston is pushing it up on its stroke. I haven't run the motor like this, just off the starter a little and hand cranking over.
Looking like I'll have to pull the motor and head to see what is really going on . What would be the main causes of a valve no returning to the close position besides a toasted spring? Maybe some grime in the valve guide making it sticky?
Wolfgangdieter
Wolfgangdieter is offline
PostPosted: Thu May 16, 2024 7:58 pm    Post subject: Re: I bought a project... Need some motor advice. (73 914 w/ 1.8L) Reply with quote
Dropped valve seat due to cracked head?
That is a lot of rust where the longitudinal "were". I'd do a close rust examination before putting any money in it. Repaint could be hiding a lot of bondo rust repairs! Your issue with stuck doors could be caused by this. I hate the tin worm.
CMC '57 Porsche Speedster Replica and Dolphin boat tailed full pan VW MOD-T Street Buggy
[email protected]
dr914@autoatlanta.com is offline
PostPosted: Fri May 17, 2024 8:49 am    Post subject: Re: I bought a project... Need some motor advice. (73 914 w/ 1.8L) Reply with quote
I DEARLY love 914s but you would be much better off spending money on a better car, this one has had heavy mistreatment, poor metal patching, and poor paintwork.
10degnorth
PostPosted: Wed May 29, 2024 2:07 pm    Post subject: Re: I bought a project... Need some motor advice. (73 914 w/ 1.8L) Reply with quote
I hear what you all are saying. I have been lurking on 914World for the last couple months as well as taking a deep dive into the lengthy rustorations untaken there and on Youtube.
I am graduating college next month and don't have a money to throw at another tub and my goal here is to learn more than anything. I feel that any time that I put into this body learning to do rust repair is time well spent in my own skill set. Why not learn on a lost cause right? Like I said before, I have more time than money and a desire to learn on what I have sitting in front of me.
The external skin of the car seems to be in great shape, I have gone around it with a magnet and knocking and none of the panels seem bondo'ed up. The passenger front fender is blue on the bottom side while the rest of the car was originally yellow. It has a salvage title and I would guess that this is because of a front passenger impact. The PO claims to have daily driven the car 7 years ago and the tires don't show any unusual tread wear, but PO's claim don't mean much.
I think I am going to move ahead with the project, I have two loose lines on parts cars and I will see if the tubs are any better on those, but I am having trouble getting in contact with the owners. I also just had a 98 Subaru drop into my lap. My daily driver is a Subaru swapped 84 Vanagon and I would be interested in doing the same to the Porsche (I know it's blasphemy).
Anyway... wish me luck, I'll return with some bore-scope shots of the longs.
wagen19
wagen19 is offline
PostPosted: Thu May 30, 2024 5:19 am    Post subject: Re: I bought a project... Need some motor advice. (73 914 w/ 1.8L) Reply with quote
Good luck with you.
Although I admit, thinking in technical and financial ways in the same direction as dr914. Here on samba is a really good thread, showing what is, or can be lying ahead of a restauration of a 914 with many good insights. Why not compare and calculate before. If buying alone all the metal sheet, it´s really not cheap. Solving all sorts of engine-problems is a children´s play, when once the body is finished, including interior, paint and electric. With luck, a good engine comes along too.
Check your sources. If ever possible, go ahead. The scene needs offspring!
https://www.thesamba.com/vw/forum/viewtopic.php?t=758341&highlight=
[email protected]
PostPosted: Thu May 30, 2024 12:14 pm    Post subject: Re: I bought a project... Need some motor advice. (73 914 w/ 1.8L) Reply with quote
if fuel injected I would remove the air flow meter, set the points dwell to 50 and see if you could light it off with a toot of starting fluid
[email protected]
PostPosted: Thu May 30, 2024 12:15 pm    Post subject: Re: I bought a project... Need some motor advice. (73 914 w/ 1.8L) Reply with quote
the starting fluid is so volatile that it will blow excess buildup off of the valves, and maybe restore the compression
Root_Werks
PostPosted: Thu Jun 06, 2024 9:52 am    Post subject: Re: I bought a project... Need some motor advice. (73 914 w/ 1.8L) Reply with quote
-Dan
Probably a bent valve, you're on it though. Pulling the engine and heads will tell the complete story.
Backtotheeightiesagain
Backtotheeightiesagain is offline
PostPosted: Wed Jan 01, 2025 1:55 pm    Post subject: Re: I bought a project... Need some motor advice. (73 914 w/ 1.8L) Reply with quote
The bus motor seems a good way of controlling the budget and saving time. If it is all good.
The original motor can be worked on at a leisurely pace. Finding the right original parts to add value.
Bus motors are hard worked but starting with more Cubic inches is never bad, any mods have greater effect.
They do rev with the right carbs etc but torque means response without changing down.
justjoelagain
justjoelagain is offline
PostPosted: Thu Oct 30, 2025 10:39 am    Post subject: Re: I bought a project... Need some motor advice. (73 914 w/ 1.8L) Reply with quote
Hey, my project looked very similar when I picked mine up. The rust was bad when I inspected it but it was WAY worse when I cut the quarter panel back and started fixing it. Don't lose hope. They sell most of the sheet metal needed to repair this and some cutting, grinding and welding should have you fixed up. Take your time and measure before cutting out the rot, build jigs and fixtures to locate your suspension mounting locations and cut, grind, weld.
I had such a bad time with the fuel injection system (mine was D-jet) that I carb swapped it. Now I'm having an issue with cylinder #1 and #3 being dead even though they have compression and spark. Chasing down valve adjustments.
Moral of the story... don't give up. It's not too far gone. Similar to you I'm shooting for driver quality.
