Camber Compensator hardware size - small bolt too small?
70bus Premium Member
70bus is offline
PostPosted: Tue Oct 28, 2025 1:01 pm    Post subject: Camber Compensator hardware size - small bolt too small? Reply with quote
I was going to mount my EMPI camber compensator on the truck, but I have questions about the hardware. This version mounts to horn, not trans by the way. Red one in this pic
The rubber bushing and attachment bolt just seem small for the stresses involved. Or is it merely a cushion that mostly sees up/down?
Craig K
70 Neunsitzer
65 Pritschenwagen
Raoul the 65 singlecab
Karl the 70 nine-seater
PostPosted: Tue Oct 28, 2025 3:10 pm    Post subject: Re: Camber Compensator hardware size - small bolt too small? Reply with quote
I think it's just a rubber interface to hold the 2 things together - it doesn't touch anything on the vehicle and I don't think the bolt is under much stress.
I've had a few of those and I don't recall the bolt ever being bent or anything
The bushing gets worn out though
70bus is offline
PostPosted: Tue Oct 28, 2025 7:32 pm    Post subject: Re: Camber Compensator hardware size - small bolt too small? Reply with quote
Thanks Everett; the bolt on one saddle I have was bent, but it was far longer so might have had some things bump into it. Will try it out this weekend.
Craig K
70 Neunsitzer
65 Pritschenwagen
