Hirschmann antenna mounting tips
splitpartsunlimited
splitpartsunlimited is offline
PostPosted: Tue Apr 03, 2007 7:48 am    Post subject: Hirschmann antenna mounting tips Reply with quote
I am next to install this antenna in my split
https://www.thesamba.com/vw/gallery/pix/320763.jpg
but i don`t know how far from the hood or from the windshield seal ....could anybody give me the correct position of it ??
thank you !!
Ricardo
in my Garage:
1951 crotch cooler split
1958 convertible
1971 1302 convertible
1981 Mercedes Benz 230 military "Gelandewagen"
2010 Mercedes Benz c200 kompressor touring
Last edited by splitpartsunlimited on Wed Apr 04, 2007 4:11 pm; edited 1 time in total
Erik G
Erik G is offline
PostPosted: Tue Apr 03, 2007 12:45 pm    Post subject: Reply with quote
I am no expert, but I would trial fit the top piece that goes on the roof first, and then find where the bottom is by aligning parallel with your windshield.
Seb67
Seb67 is offline
PostPosted: Tue Apr 03, 2007 2:59 pm    Post subject: Reply with quote
Just make sure you take a couple of shots of whiskey before you drill holes into your split Very Happy
1964 Type 1
steven wood
steven wood is offline
PostPosted: Wed Apr 04, 2007 12:49 pm    Post subject: Reply with quote
I copied this from Kabriolett.com a year or two ago when I had my split,
This isn't the same antenna as yours but hopefully it will help.
"ok guys, hope you can help with some pics. will be installing an NOS Hirschmann red tip center mount antenna and need some close up pics of the antenna where it mounts near the hood area. i believe this is the same antenna that was installed on the Andy's '51 (when he owned it that is).
as previously mentioned the antenna is NOS and will need to be "bent" to have the correct curve of the car to get mounted on the roof standoff.
if you could post some pics here or send them to my email address i would be most grateful.
In that I bought a center mount antenna from Andy some time back, I was also needful of knowing it's mounting location. This info was taken from Andy's '51.
If you measure back from the edge of the cowl at the hood, it is 2 3/8 inches to the front edge of the Hirschmann antenna's base.
I do hope this will be a helpful reference to you, sorry I don't have any photos to offer though."
splitpartsunlimited
PostPosted: Wed Apr 04, 2007 1:07 pm    Post subject: Reply with quote
i will try to do it that way , thank you steven !
Ricardo
in my Garage:
1958 convertible
splitpartsunlimited
PostPosted: Mon Apr 09, 2007 6:17 pm    Post subject: Reply with quote
i have been inspecting the car before drilling holes , and my next dumb question is : is the antenna hole centered between the 2 windshield wiper holes ?? should i take the 2 holes as a reference ??
i know that windshield wiper holes on later cars are not centered ...how about early ones ??
thanks a lot
Ricardo
in my Garage:
1958 convertible
PedalWerks
PedalWerks is offline
PostPosted: Mon Jul 28, 2025 5:15 pm    Post subject: Re: Hirschmann antenna monting tips Reply with quote
Hello, does anybody have the measurement for the center of the mounting hole. I do not have the antenna yet, but going to paint soon.
Thank you. Scott.
my3bugs
my3bugs is offline
PostPosted: Mon Jul 28, 2025 6:36 pm    Post subject: Re: Hirschmann antenna monting tips Reply with quote
most of these Hirschmanns i have seen are not exactly specific to any car , but more one size fits all , by using about a 1 inch section at the base that is bendable , that part or portion of of the antenna is solid metal not hollow like the actual antenna its made to bend , this solid part you bend to fit your car ..i clicked on your antenna pic , i couldnt be sure but it looks like it have that bendable lower portion ?????
Bosch and Hirschman did similar in this way , you have to bend to fit your windshield angle .
PedalWerks
PostPosted: Mon Jul 28, 2025 6:45 pm    Post subject: Re: Hirschmann antenna monting tips Reply with quote
Thank you, that helps,
my3bugs
my3bugs is offline
PostPosted: Mon Jul 28, 2025 7:32 pm    Post subject: Re: Hirschmann antenna monting tips Reply with quote
this is a Bosch one but a clear example of the part you bend .
Oh here is a NOS Hirschmann as well , look close you can see the bendable portion .
my3bugs
my3bugs is offline
PostPosted: Mon Jul 28, 2025 7:42 pm    Post subject: Re: Hirschmann antenna monting tips Reply with quote
now this is not my bug but a pic i have showing the Bosch blue tip mounted up , showing the bend . i have similar here but not good pics .
ya , its nerve wracking bending your expensive NOS antenna , but it bends pretty easy and isnt that hard . its deciding where to drill the hole in the cowel that is hard . once you do that your committed to that bend ... ill try n find a pic of my bug that i did a while back now
my3bugs
my3bugs is offline
PostPosted: Mon Jul 28, 2025 7:50 pm    Post subject: Re: Hirschmann antenna monting tips Reply with quote
not a great pic but here is my Bosch installed . i kinda remember the directions were in German so i kinda had to wing it Smile i tried to sorta have the antennea at the same angle as the windshield , its kinda tight as you need to make sure the wipers dont interfere with it .
i have seen long n short stand offs .......i think only the short ones are aplicable here for split bugs .
Envious
Envious is offline
PostPosted: Sat Nov 08, 2025 7:27 pm    Post subject: Re: Hirschmann antenna monting tips Reply with quote
Anyone have a source for the roof stand-off piece?
71 Type 1302 Custom
64 Type 151
63 Type 117 L469 Anthracite
64 Type 361 L575 Nutria
64 Porsche 356c
56 Type 113 L227 Strato Silver
52 BSA C11G
59 Heilite Single Wheel Camping Trailer
56 Allstate Single Wheel
84 Vanagon Westfalia
http://www.thesamba.com/vw/forum/viewtopic.php?t=388225
Suboval
Suboval is offline
PostPosted: Sun Nov 09, 2025 12:25 pm    Post subject: Re: Hirschmann antenna monting tips Reply with quote
Looking for this?
https://www.thesamba.com/vw/classifieds/detail.php?id=462530
It all works on paper.
There's two things we learn from history:
1.) History repeats itself.
2.) We don't learn from history.
