Call for Webasto BBW 46 info and experiences
ragnarhairybreeks
ragnarhairybreeks is offline
PostPosted: Tue Dec 08, 2009 11:13 pm    Post subject: Call for Webasto BBW 46 info and experiences Reply with quote
Hi,
Starting to attempt to get my Webasto BBW 46 coolant heater up and running. Yeah, I know, it may well be a dead horse Smile
Anyway, I've started to post info on my blog (http://shufti.wordpress.com/). So far I have linked to Gary Lee's pics and install manual, a parts manual, and an excerpt from the German VW repair manual that actually has the scoop on the Vanagon install.
There were some posts on the UK Brickyard site, I'll link to them too.
If anyone out there has any more info please post.
thanks
Alistair
'86 7 passenger syncro, converted to westy pop top, project still in progress
https://shufti.blog/
Old address still works...
otiswesty
otiswesty is offline
PostPosted: Wed Dec 01, 2010 10:52 pm    Post subject: Reply with quote
The Bentley has a long writeup on the BBW46, check it out.
Also,
http://www.techwebasto.com/heater_archive.htm
1978 Sage Green P22 Westfalia
1988 T3 Syncro Single cab
Just a regular guy
goskiracer
goskiracer is offline
PostPosted: Sun Dec 02, 2018 10:31 am    Post subject: Re: Call for Webasto BBW 46 info and experiences Reply with quote
I have just bought a NOS Webasto BBW 46 here in Norway... santa came early this year Very Happy
I have a 2.2L WBX and I am contemplating installing the heater inline with the heater circuit as opposed to the thermostat controlled install on the factory equipped vans. The reason being that the monovalve seems NLA... and Webasto allows for the option of either thermostat (monovalve) controlled or in series with the heater circuit.
Am I missing something here? It seems like the series install is much simpler with fewer connections. As long as my heater valves are open while the motor warmer is in operation it should circulate warmed coolant to the engine block. I could even close the front heater valve to reduce the amount of coolant in circulation by the Webasto during initial warm-up.
Props to Telus for finding the troubleshooting manual,
http://www.telusplanet.net/public/gary2a/rack/bbw46/BBW46.htm
here is the Bently install (monovalve controlled)
[/img]
86' Syncro 2.2 Vanistan, WBXhaust, ski-pole shifter for +11hp
T3messie
T3messie is offline
PostPosted: Sun Dec 02, 2018 10:56 am    Post subject: Re: Call for Webasto BBW 46 info and experiences Reply with quote
The setup with the thermostat monovalve first warms the engine a little (55 C) and then delivers warm water to the heater.
Of course it is possible and more simple to install it witout the monovalve.
If the blower fan is not blowing cold air through the heater core there is enough heat to warm the engine to 87 C in half an hour.
Gordo_89
Gordo_89 is offline
PostPosted: Sun Dec 02, 2018 1:17 pm    Post subject: Re: Call for Webasto BBW 46 info and experiences Reply with quote
I bench tested mine and it heated the water up in a large gorilla tub in no time.
I thought the mono valve worked by heating the cooling system first then the engine?
I have found about 3 webasto manuals in total
Bentley version
Webasto installation manual
Fault finding manual
The inline and thermostat controlled are both detailed in the webasto manual. If that's any help?
1989 Vanagon 2.1L
Deadchemist
Deadchemist is offline
PostPosted: Mon Dec 03, 2018 9:26 am    Post subject: Re: Call for Webasto BBW 46 info and experiences Reply with quote
I'm also in abit of a fix regarding my webasto BBW46. I've so far been linked to the repair manual and a wiring loom. The display unit is working but if im honest i really dont understand how to get it going.
Can someone please explain it to me? When I press the clock and enter the time the yellow light comes on but no accompanying sound.
Gordo_89
Gordo_89 is offline
PostPosted: Mon Dec 03, 2018 11:22 am    Post subject: Re: Call for Webasto BBW 46 info and experiences Reply with quote
I use the flame symbol on the right hand side this should light up green when activated and stay illuminated while it runs
There is a switch built into the heater control leaver (hot and cold leaver) that needs to be on (hot position) for the time relay to be activated and power to be delivered to the heater unit
1989 Vanagon 2.1L
Sodo
Sodo is offline
PostPosted: Sun Nov 12, 2023 9:14 am    Post subject: Re: Call for Webasto BBW 46 info and experiences Reply with quote
I saw a Canadian Syncro16 a month ago that used this system to heat the floor of the van, the living space. It was a 16, Westified. The guy bought it in Abbotsford BC, was passing thru WA.
....KTMs, GasGas, SPOT mtb
rprsamba
rprsamba is offline
PostPosted: Tue Nov 28, 2023 10:55 am    Post subject: Re: Call for Webasto BBW 46 info and experiences Reply with quote
. I have a 89 Doka with a Webasto control panel. I’m not sure I’ve got the heater element and I’m looking for it. Does anybody know the location of the actual heater in doka? Also, it appears that some of the links are old and not working. Please post links for the Webasto manuals you found? I can’t seem to find them
Thank you
onefred
onefred is offline
PostPosted: Tue Dec 09, 2025 4:05 pm    Post subject: Re: Call for Webasto BBW 46 info and experiences Reply with quote
Hello,
I checked out your work on your blog, it's impressive, well done!
Could you help me with the question I asked here?
https://www.thesamba.com/vw/forum/viewtopic.php?p=10462036#10462036
Thanks.
onefred
onefred is offline
PostPosted: Tue Dec 09, 2025 4:11 pm    Post subject: Reply with quote
Also,
Hello, links is dead. Do you have new link please ?
thanks.
onefred
onefred is offline
PostPosted: Tue Dec 09, 2025 4:13 pm    Post subject: Re: Call for Webasto BBW 46 info and experiences Reply with quote
Hello, this link is dead, do you have other ?
thanks.
VicVan Premium Member
VicVan is offline
PostPosted: Tue Dec 09, 2025 6:47 pm    Post subject: Re: Call for Webasto BBW 46 info and experiences Reply with quote
Hi, a quick internet search gave me this:
https://www.fourbyfourclub.com/Manuals/BBW46RepairManual.pdf
'90 Little Blue Truck, 2WD auto, FAS GenV 2.0 NA (AVH)
onefred
onefred is offline
PostPosted: Wed Dec 10, 2025 4:17 pm    Post subject: Re: Call for Webasto BBW 46 info and experiences Reply with quote
Ok, thank you very much.
