found a transmission shop in Los Angeles that fixed my Auto
therastavan
therastavan is offline
PostPosted: Wed Aug 26, 2020 5:32 pm    Post subject: found a transmission shop in Los Angeles that fixed my Auto Reply with quote
I searched all around Los Angeles for a reliable and trusted transmission rebuilder for my VW Vanagon. Lomita Transmission came highly recommended by Randy from AutoMeister which is the Vanagon guru around here. Decided to give Marco a shot and wanted folks here to know since it is hard to find a Vanagon transmission expert in LA.
Marco is so knowledgeable about VW transmissions and all transmissions really. He knows every part, every bushing, every gear and simply gets it. He even sent me high resolution photos of all the tear down process as well as the rebuild process. I have never had a shop send me such detailed photos and keep me so well informed during the process. Most shops don't do rebuilding in house they send your transmission to some shady place that only replaces basic items in it and calls it a day. Lomita is unique in that they rebuild on site. They inspect and measure every component, tell you what they recommend with no pressure and accept what you can afford or want to do without hassle. Prices are honest and the work is fully transparent with the customer being informed of everything along the way. My Vanagon drives and shifts smoother than ever. FYI I used Royal Purple MAX ATF synthetic transmission fluid and Royal Purple synthetic differential oil.[/img]
schuetter
schuetter is offline
PostPosted: Wed Jun 16, 2021 5:05 pm    Post subject: Re: found a transmission shop in Los Angeles that fixed my Auto Reply with quote
Thanks for the tip! My 90 auto tranny just bit the dust and trying to find an affordable rebuild mechanic. Mind sharing how much you spent for the rebuild?
skills@eurocarsplus
Samba Peckerhead
PostPosted: Wed Jun 16, 2021 8:07 pm    Post subject: Re: found a transmission shop in Los Angeles that fixed my Auto Reply with quote
a real deal rebuild (both sections, auto and differential) with quality parts is going to be in the 2-2500 range.
anything less and you're just getting bands and clutches imho
gprudenciop wrote:
[email protected] wrote:
Jake Raby wrote:
Brian wrote:
Chootrain470
Chootrain470 is offline
PostPosted: Fri Oct 17, 2025 11:22 am    Post subject: Re: found a transmission shop in Los Angeles that fixed my Auto Reply with quote
I'm going to give this place a try to repair by torque converter issues & fluid change. I'll update my experience. I'm not sure what the exact issue is, but I hope to fix the wobble my torque converter has had for 25k miles since my rebuild.
dart330
dart330 is offline
PostPosted: Fri Oct 17, 2025 11:51 am    Post subject: Re: found a transmission shop in Los Angeles that fixed my Auto Reply with quote
I just went through the torque converter wobble issue. Had to swap to a different torque converter and they are becoming hard to come by. It is a gamble on the rebuilt units if the center bushing is still round.
Driving a 90 Carat since 2014
Previous Buses: 59 Westy, 60 Westy, 74 Bus, 82 Westy, 85 Westy, 87 Syncro
Checkout my Syncro Video: https://www.youtube.com/watch?v=0JSWhLS7jLY
View user's profile Send private message Send e-mail Twitter Gallery Classifieds Feedback
Chootrain470
PostPosted: Fri Oct 24, 2025 11:06 am    Post subject: Re: found a transmission shop in Los Angeles that fixed my Auto Reply with quote
Here is an update so far:
I dropped my van off on Wednesday and Marco seems to be a very good and knowledgeable guy. He asked me a lot of questions about the car and we took it for a test drive.
I got a call from him this morning along with photos of the issues. The transmission is leaking, along with the engine rear main seal. The whole transmission assembly is tweaked and hitting against the transmission mount. Other issues too. He seemed very bothered with the work another shop did 2 years ago.
Anyways, he will be dropping the transmission today to get a better look and inspect it. So far, I feel that I am good hands, but I am wary due to my past experiences at other shops.
Chootrain470
PostPosted: Fri Oct 24, 2025 1:07 pm    Post subject: Re: found a transmission shop in Los Angeles that fixed my Auto Reply with quote
Here are a few photos from the mechanic. I was told that the entire drivetrain is screwed and that is causing the transmission mount to whack and make noise. The engine to bell housing is also not mounted properly.He also sent some other pictures of leaks.
Chootrain470
PostPosted: Fri Oct 24, 2025 4:02 pm    Post subject: Re: found a transmission shop in Los Angeles that fixed my Auto Reply with quote
I am getting a full transmission rebuild, Gowesty cooler, and regreased CV and boots.
I was told that some clutch packs are bad, the splines on the forward planetary are bad, and bad rear crankshaft seal. The whole drivetrain was skewed so that is being addressed too. Those guys at Al's VW shop did a really poor job 2 years ago.
On top of that, the CV boots are dry so they are getting refreshed. Are Rockford boots still the best?
jlrftype7
jlrftype7 is offline
PostPosted: Fri Oct 24, 2025 6:11 pm    Post subject: Re: found a transmission shop in Los Angeles that fixed my Auto Reply with quote
I would get T3’s CV boot kits. While our Rockford boots did great by us, others with later production boots had lots and lots of premature failures.
So, viewing all that here on Samba, we went with T3 boots this time while servicing the CVs recently.
‘84 Tin Top - Hilga....Auto
ALIKA T3
ALIKA T3 is offline
PostPosted: Fri Oct 24, 2025 11:32 pm    Post subject: Re: found a transmission shop in Los Angeles that fixed my Auto Reply with quote
Chootrain470 wrote:
Stud is too long bc your engine came from a manual transmission van. They didn' cut the stud or replace them, just got lazy when they found out upon assembly.
Your transmission mount is prolly mounted in the wrong set of holes on the chassis, there's 2 sets/loctions: one for manual, one for automatic. Easy fix.
Chootrain470
PostPosted: Thu Oct 30, 2025 1:32 pm    Post subject: Re: found a transmission shop in Los Angeles that fixed my Auto Reply with quote
My van is in the process of getting the transmission rebuilt. From what I am seeing and have discussed with the shop, this rebuild is extensive and should last a long time.
They also sent pictures of broken parts they found. The shop spent a lot of time looking for good quality used parts where needed.
ALIKA T3
ALIKA T3 is offline
PostPosted: Fri Oct 31, 2025 1:41 am    Post subject: Re: found a transmission shop in Los Angeles that fixed my Auto Reply with quote
That evil washer!
I had the same thing happened to me on a customer's transmission I rebuilt.
I was pissed!
I brazed it back together and filed it down. Jewelry work...
I sell valve body separation plates in the classifieds.
If you need one, don't wait too long, I'm leaving next thursday in vacation Wink
https://www.thesamba.com/vw/classifieds/detail.php?id=2186917
Chootrain470
PostPosted: Fri Oct 31, 2025 9:20 am    Post subject: Re: found a transmission shop in Los Angeles that fixed my Auto Reply with quote
ALIKA T3 wrote:
That evil washer!
I was pissed!
Thanks, my shop said they found all used or new quality parts already. I'm just excited to get the van back soon.
Chootrain470
PostPosted: Fri Nov 07, 2025 12:12 pm    Post subject: Re: found a transmission shop in Los Angeles that fixed my Auto Reply with quote
Another update from this morning: the transmission is complete and ready to install. Looks nice!
GoWesty cooler and new CV boots:
I’m excited to get the van back. Hopefully next week!
Chootrain470
PostPosted: Mon Nov 17, 2025 12:20 pm    Post subject: Re: found a transmission shop in Los Angeles that fixed my Auto Reply with quote
The transmission is now installed. However, a few other issues are being fixed.
The prior shop installed the engine and transmission skewed. This destroyed my CV joints and the new engine mounts are now also damaged. They are now replacing the CVs, engine mounts, and aligning the drivetrain. I'm crossing my fingers I get the van back on Wednesday.
KTPhil Premium Member
KTPhil is offline
PostPosted: Mon Nov 17, 2025 1:54 pm    Post subject: Re: found a transmission shop in Los Angeles that fixed my Auto Reply with quote
I have a VW jig for checking drivetrain centering Type 3 and 4 cars, but I've never ween the equivalent for Vanagons. But I only used it once.
The poor boy check is to drive on a level surface and then stop gently. Grab the half shafts, and push inward and outward on each one and take measure of how far they move in total (in and out).
This should be equal on the two halfshafts, or else at full suspension movement, the car will force the drivetrain to move left or right, wearing out CVs and mounts.
Adjust on the mounts until this is equal. That should be close enough.
Current Fleet:
- '71 Fastback
- '69 Westfalia
Retired:
- '67 Beetle
- '65 Beetle (x2)
- '65 Bus
- '71 Squareback
Chootrain470
PostPosted: Mon Nov 17, 2025 2:19 pm    Post subject: Re: found a transmission shop in Los Angeles that fixed my Auto Reply with quote
The prior shop did such a poor job that I guess when the transmission was recently removed, the entire engine lurched back into position. I think they just rushed the job and botched it all.
Chootrain470
PostPosted: Thu Nov 20, 2025 11:38 am    Post subject: Re: found a transmission shop in Los Angeles that fixed my Auto Reply with quote
I got the van back yesterday and I could immediately tell that it is running much better. Very smooth shifts and although the idle is still somewhat rough, it is improved. No more clunking, scraping, grating noises or lurches at a stop. Lomita Transmission did a great job.
The plan is to drive the van for ~1000 miles and bring it back for a transmission fluid change. I'm excited to put some miles on it.
Chootrain470
PostPosted: Thu Nov 20, 2025 11:42 am    Post subject: Re: found a transmission shop in Los Angeles that fixed my Auto Reply with quote
dobryan Premium Member
dobryan is offline
PostPosted: Thu Nov 20, 2025 11:45 am    Post subject: Re: found a transmission shop in Los Angeles that fixed my Auto Reply with quote
Glad you are back on the road. Dancing
Dave O
The Western Syncro build
