Aluminum "bubble" case with T3 engine tin
Mike313
Mike313 is offline
PostPosted: Tue Dec 02, 2025 10:10 am    Post subject: Aluminum "bubble" case with T3 engine tin Reply with quote
Anyone using an aluminum case in their T3? Any issues with the factory tins? I've read that the cases are a bit bigger than magnesium. I'm planning a long block for my fastback and don't want to start hacking up my engine tin but I've read that aluminum cases are more durable than aftermarket magnesium options. Any thoughts?
Thanks!
Mike
Glenn Premium Member
Mr. 010
Glenn is offline
PostPosted: Tue Dec 02, 2025 10:15 am    Post subject: Re: Aluminum "bubble" case with T3 engine tin Reply with quote
Thanks!
Mike
Unless you're building a monster engine, the stock Mag case is fine.
Glenn
Member #1009
#BlueSquare
עַם יִשְׂרָאֵל חַי
Mike313
Mike313 is offline
PostPosted: Tue Dec 02, 2025 11:15 am    Post subject: Re: Aluminum "bubble" case with T3 engine tin Reply with quote
Thanks Glen! It's going to be a mild 1600 or maybe 1776.
Bobnotch
Bobnotch is offline
PostPosted: Tue Dec 02, 2025 12:43 pm    Post subject: Re: Aluminum "bubble" case with T3 engine tin Reply with quote
I don't think you'd need a "raised roof" case (bubble case) for a small engine (1600-1776). I've had a standard all aluminum case 1600 in my Notch for the last 19 years, and no issues with it, other than vapor locking the mechanical fuel pump. I've since gone to an electric low pressure fuel pump.
Bob 65 Notch S with Sunroof
Tram wrote:
Mr. 010
Glenn is offline
PostPosted: Tue Dec 02, 2025 12:53 pm    Post subject: Re: Aluminum "bubble" case with T3 engine tin Reply with quote
2180 with 9.5:1cr in my Beetle with a stock VW case. I think you'll be fine, don't make headaches for yourself by over thinking.
Glenn
Member #1009
#BlueSquare
עַם יִשְׂרָאֵל חַי
Mike313
Mike313 is offline
PostPosted: Tue Dec 02, 2025 1:05 pm    Post subject: Re: Aluminum "bubble" case with T3 engine tin Reply with quote
Thanks all! Appreciate the input!
Bobnotch
Bobnotch is offline
PostPosted: Wed Dec 03, 2025 12:06 pm    Post subject: Re: Aluminum "bubble" case with T3 engine tin Reply with quote
That engine looks great Glenn. I went with a new all aluminum case because I wanted an unused new case for my engine. And other than vapor locking mechanical fuel pumps, I haven't had an issue with it. And yes, I've driven it on long road trips too. Cool
Tram wrote:
Mr. 010
Glenn is offline
PostPosted: Wed Dec 03, 2025 12:25 pm    Post subject: Re: Aluminum "bubble" case with T3 engine tin Reply with quote
I'm not against aluminum cases, you just have to make sure there's no casting flash.
New magnesium cases are still available.
Glenn
Member #1009
#BlueSquare
עַם יִשְׂרָאֵל חַי
Mike313
Mike313 is offline
PostPosted: Thu Dec 04, 2025 7:46 pm    Post subject: Re: Aluminum "bubble" case with T3 engine tin Reply with quote
Well, despite the general dislike for Empi around hereI decided to take a chance on their 1776 longblock with mag case. Once I get it swapped in and broke in I'll report my experience with it.
Mike
Mr. 010
Glenn is offline
PostPosted: Thu Dec 04, 2025 7:49 pm    Post subject: Re: Aluminum "bubble" case with T3 engine tin Reply with quote
Don't expect anything more that a mild build with parts fresh out of the boxes they come in.
FTI
ENGINE CASE- AutoLinea-EMPI, H.D. “Bubble Top” Engine Case
Available in three standard configurations for Type 1 or 2 applications.
FLYWHEEL- Stock Style, 4 Dowel Pin, 200mm
Glenn
Member #1009
#BlueSquare
עַם יִשְׂרָאֵל חַי
Mike313
Mike313 is offline
PostPosted: Thu Dec 04, 2025 8:28 pm    Post subject: Re: Aluminum "bubble" case with T3 engine tin Reply with quote
I think my expectations are realistic. The car will be a weekend cruiser. Not looking for performance.
Mike
