waxie Samba Member
Joined: December 09, 2025 Posts: 3 Location: Phoenix, AZ
Posted: Sun Dec 14, 2025 5:40 pm Post subject: Ignition switch housing question |
Hey everyone!
So my ignition switch has been feeling like it’s going to go for awhile now. I finally decided to begin replacing it and when I started taking the old one out I noticed that this little pin/screw was missing.
Is this necessary to have when I reassemble it? If so, is it worth finding an older housing with that piece and popping it into my housing unit or is it fine without it. This picture isn’t of my exact housing and switch but a picture of one with the screw.
Thank you for any input.
busdaddy Samba Member
Joined: February 12, 2004 Posts: 53210 Location: Surrey B.C. Canada, but thinking of Ukraine
waxie Samba Member
Posted: Sun Dec 14, 2025 8:03 pm Post subject: Re: Ignition switch housing question |
Thank you!!! |
70bus  Samba Member
Posted: Mon Dec 15, 2025 6:36 pm Post subject: Re: Ignition switch housing question |
That thread mentions it is M3X.5
Did they mean M3x5 or is it really that tiny? _________________ Craig K
70 Neunsitzer
65 Pritschenwagen
Raoul the 65 singlecab
Karl the 70 nine-seater |
Posted: Mon Dec 15, 2025 9:16 pm Post subject: Re: Ignition switch housing question |
3mm dia, .5 threads per mm. _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
70bus  Samba Member
aeromech Samba Member
Joined: January 24, 2006 Posts: 17753 Location: San Diego, California
Posted: Mon Dec 15, 2025 11:00 pm Post subject: Re: Ignition switch housing question |
You can purchase that set screw. I have a few in stock. Otherwise you can use just about any m3x5 screw even if it sticks out _________________ Lead Mechanic: San Diego Air and Space Museum
Airbus A319,320,321
DC9/MD80
BAe146
Fokker F28/F100
VW type 1 1962,63,65,69,72
VW Jetta
VW Passat
kreemoweet Samba Member
Joined: March 13, 2008 Posts: 4149 Location: Seattle, WA
Posted: Tue Dec 16, 2025 9:36 am Post subject: Re: Ignition switch housing question |
| busdaddy wrote: |
| 3mm dia, .5 threads per mm. |
I guess you meant .5 mm per thread.
.5 threads per mm would be a M3x2 screw.
Metric screw thread designations are not very consistent in common use, sometimes the second number indicates thread pitch, and sometimes the length of the screw shank. _________________ '67 bug: seized by the authorities
