VDO Pressure Adaptor Hose Kit
agropic
agropic is offline
PostPosted: Fri Dec 10, 2004 8:08 am    Post subject: VDO Pressure Adaptor Hose Kit Reply with quote
Hi Everyone,
I will like to install a VDO-350040 Oil Press Gauge, 80psi, 12 Volt with theVDO-360006 Pressure Sender, Dual Contact. Since the adaptor kit is No Longer Available, Does any one have a suggestion for installation ??
Maybe an alternative kit or some kind of alteration to the engine tin ??
Thanks,
agropic
1965 Karmann Ghia (Sold)
1972 Super Beetle (Sold)
1978 Bus (Campmobile) (Sold)
1970 Standard Beetle
1974 Super Beetle (Sold)
1974 Standard Beetle (Sun Bug)
1973 Bus
1976 Double Cab
Hippie
Samba Tinner
Hippie is offline
PostPosted: Fri Dec 10, 2004 8:14 am    Post subject: Reply with quote
What exactly needs adapted to what? If you need just a tee fitting so you can sense pressure and still have your factory oil pressure warning light, I got mine at Auto Zone off the shelf.
Randy in Maine
Randy in Maine is offline
PostPosted: Fri Dec 10, 2004 8:25 am    Post subject: Reply with quote
You might want to read this post for some information on htis subject. I am in the same boat as my 12" extension needs to be replaced due to the fact that it is leaking after a "thermal problem" in the area.
http://www.thesamba.com/vw/forum/viewtopic.php?t=72880&highlight=vdo+oil+pressure
agropic
agropic is offline
PostPosted: Fri Dec 10, 2004 8:42 am    Post subject: Reply with quote
I just want to adapt the VDO dual sender to the engine case, aparently the only remedy is to install a preassure hose from the engine case to the dual sender.
1973 Bus
1976 Double Cab
agropic
agropic is offline
PostPosted: Fri Dec 10, 2004 8:46 am    Post subject: Reply with quote
Randy,
Do you think that the Kit that CIP1 (VDO-150-752 - VDO OIL PRESSURE SENDER ADAPTER KIT M10 X 1 - TYPE 4 ENGINES)
sells will do the job ? I read the linked discussion and Artwell doesn't recommended !!!
1973 Bus
1976 Double Cab
Randy in Maine
PostPosted: Fri Dec 10, 2004 8:59 am    Post subject: Reply with quote
Welll I am going to pass on it from CIP1 and just have a hose made at NAPA for less than $20. My extension hose is probably 10 years old and actually fits so I will use those fittings if required.
I think the extension is really worthwhile though for a pretty good install though.
Anyway, that is what I am going to do after the holidays.
Hippie
Samba Tinner
Hippie is offline
PostPosted: Fri Dec 10, 2004 9:29 am    Post subject: Reply with quote
I guess I'm not familiar with that product. ...Having trouble visualizing it. Mine is a mechanical gauge and just has a compression fitting that adapts to 1/8" nominal brass tee which has the oil pressure light switch screwed into the side of the tee, and all that then screws into the oil pressure light switch hole in the side of the crankcase.
Randy in Maine
PostPosted: Fri Dec 10, 2004 10:15 am    Post subject: Reply with quote
Mine in my type 4 engine, scres into the block and then runs to the firewall/gas tank shield where it mounts and then has a VDO sender that runs both the electrical gauge and the idiot light. Just easier to run it that way.
agropic
agropic is offline
PostPosted: Fri Dec 10, 2004 11:46 am    Post subject: Reply with quote
Randy,
That's exactlly the type of setting that I want to do in mine....Thanks for your help, talk you later..
1973 Bus
1976 Double Cab
ratwell
ratwell is offline
PostPosted: Fri Dec 10, 2004 1:56 pm    Post subject: Reply with quote
http://homepage.mac.com/ratwell/.Pictures/MoreParts6/235-VDOAdapter.jpg
The VDO adapter is not M10x1 as labelled. The original one piece hose was but this newer version is 1/8-NPT at both ends and will damage the threads on your case. Getting a hose made up is the best idea because it gives you 100% control over sender mounting.
Some people have reported success using an extension hose for a grease gun but everyone I've seen is 1/8-NPT with two male ends.
Autometer sells a M10x1 to 1/8-NPT adapter #2265. The descriptions are often backwards but they've assured me that the male end is M10x1 (it wouldn't make sense to adapt NPT to most foreign cars anyway).
'78 Westfalia CDN
'76 Doublecab Sweden
Read the Baywindow FAQ
