gregoryulrich Samba Member
Joined: December 07, 2006 Posts: 192 Location: Venice, CA
Posted: Tue Feb 05, 2013 11:46 am Post subject: FIXED: Help with Voltage Regulator test results |
My alternator light has always glowed dimly with the engine running but until a few weeks back I've never had a problem charging. I chalked the light up to the dual battery setup slightly taxing the stock 55 amp alt. During a recent road trip i had no problems though the engine was running 5-7 hours a day. Short trips around town quickly drain my juice. ::edit, the battery is brand new::
I ran the test on the voltage regulator per Ratwell's site http://www.ratwell.com/technical/ChargingSystem.html and came up with the following results:
Ignition off
D+ =0V, DF=0V, D-=0v
Ignition on, engine off
D+=1.47V, DF=.78V, D- =0V
Ignition on, enging idle
D+=9-11V, DF=~10.3V, D-=0V
Ignition on, fast idle
D+=14V DF=~5V D-=0V
The light glows dimly all the time. It glows slightly brighter but not fully on under load(lights, radio on).
Can someone help me interpret these results or do I need to do further testing? Thank you! _________________ 1979 California Edition Riviera
Last edited by gregoryulrich on Tue Feb 12, 2013 3:13 pm; edited 1 time in total |
SGKent  Samba Member
Joined: October 30, 2007 Posts: 42788 Location: at the beach
Posted: Tue Feb 05, 2013 12:05 pm Post subject: |
It means that at idle your system is not charging.
(1) What is your idle speed?
(2) With engine off, have you tested the belt to be sure it is the correct tension?
(3) How many electronic accessories were turned on when these tests were run? _________________ George Carlin:
Skills@EuroCarsPlus:
"never time to do it right but always time to do it twice"  |
Posted: Tue Feb 05, 2013 12:21 pm Post subject: |
The belt tension is ok, a little loose but not overly so. It deflects about an inch and it's at its maximum adjustment. I do need to buy a new belt but the light has been doing this even with a new belt.
The radio was the only accessory switched on when I performed the test.
Idle speed is 900-1000 _________________ 1979 California Edition Riviera |
SGKent  Samba Member
Posted: Tue Feb 05, 2013 12:30 pm Post subject: |
I would try cleaning all connections and if that does not fix the issue, replace the VR with a new Bosch one. I see 12.5V at idle with my 1977 and 14.5V - 14.9V at cruise unless running fogs, lights and the radio. _________________ George Carlin:
Posted: Tue Feb 05, 2013 12:59 pm Post subject: |
Is there any reason the alternator light would be on at highway speeds? It's hardly noticeable during the day but at night it is. _________________ 1979 California Edition Riviera |
SGKent  Samba Member
Posted: Tue Feb 05, 2013 2:01 pm Post subject: |
One side of the light hooks up to D+, since it is showing 14V at fast idle that side of the bulb should be above everything else in the system. You probably need to get Telford involved as he reads circuits better than myself but I see a couple possibilities.
1) There is a ground fault of some kind involved. Are any other lights glowing or not working right? Do the hazards work right and is the top secure on it? They do come off.
2) you may have a a bad diode in the alternator on the exciter side which is allowing a little AC into the system and the bulb is seeing the AC leakage which cause it to glow.
3) Did you measure the voltage for D+ at the blue wire headed forward to the bulb? It should be the same as D+. If it is not then there may be a fault in the regulator.
4) Light from another source like the EGR/CAT light etc is getting into the alternator warning light - maybe it has fallen out and is lying along side it. _________________ George Carlin:
telford dorr Samba Member
Joined: March 11, 2009 Posts: 3627 Location: San Diego (Encinitas)
Posted: Tue Feb 05, 2013 3:44 pm Post subject: Re: Help with Voltage Regulator test results |
gregoryulrich wrote: |
Ignition off
D+=14V DF=~5V D-=0V
Can someone help me interpret these results or do I need to do further testing? Thank you! |
Those numbers look OK. The last one shows the alternator is putting out approximately the correct voltage (D+) and the regulator is working (Df). The battery should be charging up just fine. We can't tell much about the diodes on the alternator output, however. That requires disconnecting the alternator to test (with an ohmmeter which has a 'diode' range.) If you're having a charging problem, they should be checked.
Aside: don't forget to check the integrity of the tranny ground strap.
Quote: |
The light glows dimly all the time. It glows slightly brighter but not fully on under load(lights, radio on). |
OK, need to make a couple more measurements:
(1) B+ terminal at the alternator (tough, I know - measure somewhere along the big red wire if needed). Should be the same as the battery '+' terminal.
(2) +12 volt feeder going to the instrument cluster idiot lights
You should find that those are different, if the light's glowing. The side with the lower voltage is the problem side. I'll bet it's on the +12 volt feeder to the dash lights.
There was another recent topic on this over in the Splittie section, with drawings and test suggestions. Check it out:
http://www.thesamba.com/vw/forum/viewtopic.php?t=543360
[Yeah, I know, it's a different bus type and it's a generator, not an alternator, but the battery side of the idiot light discussion is applicable.] _________________ '71 panel, now with FI
More VW electrical at http://telforddorr.com/ (available 9am to 9pm PST) |
Posted: Tue Feb 05, 2013 8:29 pm Post subject: |
B+ should have very close to the same voltage as D+ but because the light is on this is probably not the case, at least not as you move forward in the circuit. With the engine revved enough to show 14V at the battery with the headldights on, read the B+ circuit voltage to ground at the starter, the fuse box, and the ignition switch. |
Posted: Wed Feb 06, 2013 12:31 am Post subject: |
Telford:
On the Ratwell site the numbers for engine idle should read the same for fast idle i.e. D+=14V, DF=5V. Would the change in DF voltage indicate a bad diode on the alternator?
SGKent:
1) none of the other lights are a problem. The hazards don't work because there is a hazard switch from a Ghia or something hooked up. I tried switching it to the correct switch but I lost both hazards and turn signals. At least now I have turn signals. That is a project for another day.
2),3) I need to check this out.
4) there is zero chance the bulb fell out. I visually checked.
Wildthings & Telford:
These tests should be performed with the engine running? _________________ 1979 California Edition Riviera |
Posted: Wed Feb 06, 2013 12:39 am Post subject: |
These tests should be performed with the engine running? |
Yes the engine needs to be running. You should rev it up once to make sure the alternator has been energized.
If any of your diodes are bad, the alternator will not be able to make normal voltage lower engine speeds. |
SGKent  Samba Member
Posted: Wed Feb 06, 2013 8:52 am Post subject: |
I could be wrong but I think that hazard switch is a potential path for that circuit so a ground fault there could cause trouble. Best to check all the wiring in that area. E3 is the hazard switch. K2 is your alt bulb
mikedjames Samba Member
Joined: July 02, 2012 Posts: 3358 Location: Hamble, Hampshire, UK
Posted: Wed Feb 06, 2013 12:12 pm Post subject: Re: Help with Voltage Regulator test results |
Ignition off
D+=14V DF=~5V D-=0V
I had a similar problem a couple of months back.
Turned out the wire connected to D+ out of the alternator was loose. It would arc across enough to run the bus on long trips but the battery went flat in the end.
The roadside assistance guy saw the sparks from the loose wire when he jump started it. A quick tighten and all was well. But the battery was down to half capacity so I had to change it. |
Posted: Wed Feb 06, 2013 12:21 pm Post subject: Re: Help with Voltage Regulator test results |
Ignition off
D+=14V DF=~5V D-=0V
Posted: Fri Feb 08, 2013 11:27 am Post subject: Older but not much wiser... |
What I should have done:
Cleaned the transmission ground strap.
Cleaned the connections at the starter
Measured the voltage at the fuse block, hazard switch and alternator bulb including the D+
Checked for a ground fault
What I actually did:
I bought a new alternator (Bosch) and belt. I installed them and now the ALT light glows fully even with the engine revved. At idle I get ~12V at the battery. Strangely the oxygen sensor light glows now too. I'll need to check that connection.
In my defense I went with that strategy based on the alternator not charging at idle which was said to be bad diodes. Although that was probably true it's obvious there's something else going on here. _________________ 1979 California Edition Riviera |
Posted: Fri Feb 08, 2013 11:29 am Post subject: |
I should also probably check the battery isolator... _________________ 1979 California Edition Riviera |
Amskeptic Samba Member
Joined: October 18, 2002 Posts: 8586 Location: All Across The Country
Posted: Fri Feb 08, 2013 1:52 pm Post subject: |
Is there any reason the alternator light would be on at highway speeds? It's hardly noticeable during the day but at night it is. |
Yes, these alternators are known for blowing an excitor diode which causes a leak to ground and discharges the battery in a matter of days.
I tested this at night.
Remove ground terminal from (-) post of battery. Touch to post lightly. See spark?
Remove all fuses. Test again. See spark?
(No? You have a leak somewhere in a fused circuit)
Yes, remove alternator main wire to starter solenoid 13mm post, resecure the nut with the battery cable but leave alternator charge wire off. Spark at negative terminal will be gone if it is a bad diode. Alternator will work, but at about 66% efficiency.
Colin _________________ www.itinerant-air-cooled.com
www.facebook.com/groups/324780910972038/ |
SGKent  Samba Member
Posted: Fri Feb 08, 2013 2:15 pm Post subject: |
electrical problems can be hard to troubleshoot when multple circuits are involved. Sometimes the only way to find a problem is to isolate circuits.
Understanding this will help. In order for that bulb to flow electricity has to be flowing at a high enough rate that it causes the bulb to glow. Even though the car is DC voltage - flows one way - the alternator puts out AC which flows both ways, back and forth. The diodes in the alternator block the flow so it only goes one way. If the diodes are bad than the current can flow back and forth even though nothing else is wrong in the circuit. Likewise, if there is an electrical fault then power can find a new way to ground and the bulb can glow as electricity flows past it on the way to ground.
Since we KNOW that the PO tampered with the wiring at the hazard switch, and we know that the alternator bulb circuit ties into that hazard switch, I would at least make sure everything in that area is wired like it is supposed to be. Doesn't mean the fault it there, it just means you want to eliminate anything the PO did as a possible cause. All it takes is one wire in the wrong place to create a path to ground that allows the bulb to light.
Also if the wiring is tampered with, it does not mean the new alternator is bad. It could be it is good and therefore it behaves differently than the old one. On our 1977 bus we had some issues too. I resolved them by checking each wire, fixing the bad hazard switch, putting wires back in the right place and replacing a bad relay. You can do it too, just print a big copy of the wiring for your bus from the technical section here and start checking each circuit. They are color coded to that makes it easier. _________________ George Carlin:
Posted: Tue Feb 12, 2013 11:53 am Post subject: |
This may sound like a dumb question but I'm a bit lost and I'm not even sure which wiring diagram to refer to. In the Bentley it looks like I should be referring to index K page 1 of 3 (. I was tempted to bypass the battery isolator by connecting the positive battery lead directly to the positive lead coming off the starter. Right now they are on different terminals on the battery isolator. Well, I connected them together onto one terminal on the battery isolator and there was a pretty good spark when I went to connect the battery ground strap.
To check for a ground fault I would set my multimeter to ohm resistance and check the positive leads against ground? _________________ 1979 California Edition Riviera |
Posted: Tue Feb 12, 2013 3:12 pm Post subject: FIXED |
The problem was a combination of a bad battery isolator and there were 2 + wires coming off the alternator going to the same isolator terminal, one of which was grounding slightly. I also fixed the hazard switch. The PO in his infinite wisdom hacked into the wires coming off the fuse block so nearly every wire changed color as it passed through the cocoon of black electrical tape. The wire going to the fuse block was not connected.  _________________ 1979 California Edition Riviera |
Manfreds78bay Samba Member
Posted: Mon Jul 14, 2014 7:52 am Post subject: |
Hello so I've had the same issues that Gregoryulich had but slightly different results.
Did 500 miles in one day. At the end of the trip my alternator light came one. I checked the battery, 11.5v. I used this neat little tester I bought online that plugs into a cigarette lighter and determines if your charging system is working. It told me the battery was not being charged.
When I got home. I performed the voltage regulators tests on Ratwell's site and here are my results. I had zero issues with the charging system before this. Newer battery, rebuilt original VW alternator 7k miles, new wire harness. The only thing that is not new was the regulator.
Ignition off
D+=6.5V, DF=1.25V, D- =0V
D+=10V, DF= 3V, D-=0V
Based on these results, I thought the regulator was bad. So I switched it out for another I had in my parts box. It's not a known good regulator but what are the changes of them being both bad. I got the same readings. Based on the fact I'm getting identical results, my guess is the alternator.
Thoughts? _________________ 1985 VANAGON GL Digijet
There is no spoon. |
