My Bus' Rear End Is Sagging
beach_brada
beach_brada is offline
PostPosted: Thu Apr 06, 2006 1:44 am    Post subject: My Bus' Rear End Is Sagging Reply with quote
Quick question, what causes a bus' rear end to sag(sit lower to the ground than the front) and how do I fix it?
Kirwin
Kirwin is offline
PostPosted: Thu Apr 06, 2006 2:33 am    Post subject: Reply with quote
You should probably do a search on the topic first. That subject has been hit many times.
Hey, good luck, I have the same problem with my Bus.
CMK
1978 VW Transporter (DLNDBUS)
payton
payton is offline
PostPosted: Thu Apr 06, 2006 6:44 am    Post subject: Reply with quote
before you start looking into a torsion bar adjustment do yourself a favor and put on some new rear shocks. i know the shocks do not real raise the back end, but ater in put new shocks on i noticed a difference just from the rear view mirror. it may help just enough.
Mike Boyer-All American Crook
Randy in Maine
Randy in Maine is offline
PostPosted: Thu Apr 06, 2006 7:14 am    Post subject: Reply with quote
Suggestion:
First adjust the torsion bar and replace the worn bushings back there. It is a lot of work for you, but it doesn't cost much to do in parts. Then do the shocks.
The combo should really improve the steering and stability of the bus, especially in a crosswind.
MedicTed
MedicTed is offline
PostPosted: Thu Apr 06, 2006 7:55 am    Post subject: Reply with quote
Remember that the front normally sits high. It makes the back look like it's sagging, but it may not actually be sagging. Have two people sit in the cab and then look at it.
Ted Wojton
70 VW Bus Westfalia camper
2003 GMC Sierra
MHACK
MHACK is offline
PostPosted: Thu Apr 06, 2006 1:17 pm    Post subject: rear torsion bar adjustment Reply with quote
I recommend buying the torsion bar adjustment tool about 27.00 .It will
make the adjustment alot safer.
Randy in Maine
PostPosted: Thu Apr 06, 2006 1:22 pm    Post subject: Re: rear torsion bar adjustment Reply with quote
Where do you get that tool MHack? Got a link?
MHACK
MHACK is offline
PostPosted: Thu Apr 06, 2006 1:34 pm    Post subject: torsion tool Reply with quote
http://www2.cip1.com/ProductDetails.asp?ProductCode=ACC%2DC10%2D7047
there are a few places that sell this . pm me and I'll give you a few tricks to make it work better.
GeorgeL
GeorgeL is offline
PostPosted: Thu Apr 06, 2006 4:07 pm    Post subject: Reply with quote
The other thing is, in most years of bus, it is not possible to see the horizon in the inside rear view mirror. Some people think that this means the rear is sagging, but it is normal.
Find a level piece of ground, put 200 pounds in the front seat, and put a level on the sliding door sill. If it's close to level you're fine.
George
renobdarb
renobdarb is offline
PostPosted: Fri Apr 07, 2006 7:42 am    Post subject: Re: My Bus' Rear End Is Sagging Reply with quote
beach_brada wrote:
Quick question, what causes a bus' rear end to sag... and how do I fix it?
Change it's diaper...
1978 Campmobile, 2000cc w/hydro lifters, dual Weber 44 IDF carbs (50 idle jets, 115 main jets), SVDA distributor w/Compufire.
Chrispoage
Chrispoage is offline
PostPosted: Thu Aug 17, 2006 9:42 am    Post subject: Re: My Bus' Rear End Is Sagging Reply with quote
What about just using coil over shocks instead of doing the tortion thing? It seems like that would be way easier and less dangerous... has anyone done that as a solution to the soggy bottom bus?
_____________
CRASH N" BURN
_____________
static
static is offline
PostPosted: Thu Aug 17, 2006 9:55 am    Post subject: Reply with quote
I once paid my mechanic to adjust the bus up one notch. I hated the result.
Went back to the stock "sagging" position.
Really, most of the problem is how it looks when you are not in the bus.
GeorgeL
GeorgeL is offline
PostPosted: Thu Aug 17, 2006 11:16 am    Post subject: Reply with quote
One notch is way too much! with 44 notches, one notch is 360/44 = 8 degrees. At the end of a ~20 inch trailing arm, 8 degrees is 20sin8 = 3 inches! One notch will make the rear end ride stiff, top out on bumps, and handle rather oddly. You'll also get more tire and CV joint wear.
To do it right, you have to turn the bar one way on the inner end and then the other way on the outer end. The different number of splines on the inner and outer ends allow you to adjust in increments of less than a degree.
George
OB Bus
OB Bus is offline
PostPosted: Thu Aug 17, 2006 11:40 am    Post subject: Re: My Bus' Rear End Is Sagging Reply with quote
Yep, have the coil overs on my '69. This was a somewhat ghetto remedy to 15" wheels with too much offset and 205/75R15 Michelins. They work great. Ride and handling much better that the worn out gas-a-justs they replaced and the fender lips now clear the tires.
Larry in OB
69 Westfalia and 2002 Eurovan Camper.
People deserve the Government they voted for.
Tram
Samba Socialist
Tram is offline
PostPosted: Thu Aug 17, 2006 12:58 pm    Post subject: Re: My Bus' Rear End Is Sagging Reply with quote
Where did you get them? My '71 Westy DOES have a case of droopy drawers.
Bryan67 wrote:
Those who can- do.
Those who can't? Subaru.
nemobuscaptain
nemobuscaptain is offline
PostPosted: Thu Aug 17, 2006 2:08 pm    Post subject: Reply with quote
payton wrote:
before you start looking into a torsion bar adjustment do yourself a favor and put on some new rear shocks...
I think that is backwards thinkin'. Your torsions should handle the weight of the bus, not the shocks.
Ohio Valley Tribe, Full Moon Bus Club https://www.facebook.com/groups/294422277314227/
https://www.facebook.com/groups/FullMoonBusClub
RIP Bob Hoover https://www.thesamba.com/vw/forum/viewtopic.php?t=427791
Hoover Sermons: https://www.vwsage.com/images/vwsage/Bob%20Hoovers%20Sermons.pdf
GeorgeL
GeorgeL is offline
PostPosted: Thu Aug 17, 2006 2:27 pm    Post subject: Reply with quote
I agree, although VW actually had coil-over helper shocks in the parts book.
It's really important to make sure that the bus is really sagging. All buses sit nose-high without a driver in place!
George
OB Bus
OB Bus is offline
PostPosted: Thu Aug 17, 2006 4:20 pm    Post subject: Re: My Bus' Rear End Is Sagging Reply with quote
From CIP
http://www2.cip1.com/ProductDetails.asp?ProductCode=C26%2D513%2D001%2DLT
No the coil overs are not a perfect solution. In my case (due to the non-stock wheels) very necessary. The fact that they were a factory option is often overlooked by the stock zealots.
Larry in OB
steponmebbbboom
steponmebbbboom is offline
PostPosted: Thu Aug 17, 2006 4:21 pm    Post subject: Re: My Bus' Rear End Is Sagging Reply with quote
This is not the proper way to remedy the problem. The Bentley manual describes the proper procedure to adjust the torsion bars, the only thing they do not tell you is what a minute (*) means, which IIRC is a 20th of a degree? Last time I posted on this subject I had the manual in front of me.
IMO you do not need the tool to reposition your spring plates. If you put a jackstand under the torsion tube to support the bus and use your floor jack saddle on the end of the spring plate, you can easily remove and reinstall the plate, gently pry outward with a crowbar while the saddle is supporting the wheel end of the plate, and let it down when you are clear of the stop block. Pound with a rubber mallet on the bar end of the plate (I had to use the mallethead as a drift and hit it with a 4lb sledge) to install. Use new rubber bushings. I used this method and had full control of the spring plates at all times, it was completely safe.
Coil over shocks are a band-aid solution. Your bus was designed to use the torsion bars as springs, your back end will be disproportionately stiffer than the front, which will make the bus handle funny.
I suspect the factory coil-overs were part of a package deal that included other upgraded components to return the suspension to some sort of balance. In any case it's cheaper to just adjust the bars correctly, and you will get better results.
nemobuscaptain
PostPosted: Thu Aug 17, 2006 4:34 pm    Post subject: Re: My Bus' Rear End Is Sagging Reply with quote
No the coil overs are not a perfect solution. In my case (due to the non-stock wheels) very necessary. The fact that they were a factory option is often overlooked by the stock zealots.[/quote]
Apparently, you are talking to me. (???) If so:
1. I'm not a stock zealot. If you have seen my bus or my posts, you'd know that.
2. I know very well that coilovers were factory options and wouldn't mind putting them on my bus. However, my post was not in response to a coilover question, my post was in response to this:
To which, I again say, this is ass backwards. Adjust the torsion bars (assuming they are out of spec which may or may not be the case), then think about shocks.
