Converting Back to Fuel Injection
61 BUS Premium Member
61 BUS is offline
PostPosted: Sun Jan 15, 2023 7:41 am    Post subject: Converting Back to Fuel Injection Reply with quote
I bought my '76 standard beetle a few years ago. One of the previous owners had converted it to a carburetor and I've been driving it that way. I've collected two complete sets of fuel injection parts over the last couple of years and was intending to do the conversion myself, but never had the time. It's now time for an engine rebuild, which I'm having my mechanic do. He's familiar with the FI system and is going to convert it back for me. I've owned two previous '76 beetles before, one of which I bought brand new from the dealer, and loved the way they ran and drove. I'm looking forward to having the car back to original.
61 Bus, 2001 Eurovan GLS, 2013 Fiat 500 Abarth, 47 Plymouth Business Coupe, 58 BMW Isetta 300
Buggeee Premium Member
Buggeee is offline
PostPosted: Sun Jan 15, 2023 9:07 am    Post subject: Re: Converting Back to Fuel Injection Reply with quote
I had an aircooled vanagon with the same basic FI system and, once it was sorted out, I loved it. It started right up in the deep of winter, with a healthy idle under any circumstances cold or hot, throttle response was crisp (for the dog it was), etc., etc.
Big Time 1988 Vanagon Westy
Dr. Kompressor 72 Super Duper
61 Turkis Pile (adopted out)
Lost69Convertible
Lost69Convertible is offline
PostPosted: Sun Jan 15, 2023 10:10 am    Post subject: Re: Converting Back to Fuel Injection Reply with quote
Most mechanics today are the #1 enemy of the Bosch L-Jet system. The P.O. of my Beetle took it to a highly regarded Fuel Injection mechanic in this area. Highly regarded and very expensive for older cars of all types: BMW, Jaguar, Porsche etc. That mechanic butchered the FI in my car.
Here’s my best advice: make sure your mechanic intends to install the L-Jet system in stock configuration. Install all of it. The only exception to this rule is the EGR (most here will agree).
1956 Beetle Ragtop: My Father's car
1969 Beetle Convertible: My first car. I loved it, I lost it, and I never got over it.
1979 Super Beetle Convertible
VW_Jimbo Premium Member
VW_Jimbo is offline
When that injection system is performing as designed, it is the smoothest running one I know of! There is always a slight hesitation on a hard launch, off the line. But in normal driving, that flat spot does not show itself.
The best part is the lack of tuning! No more dicking around with a carburetor twisting screws! No more resetting a choke or checking the accelerator pump stream. It is all being controlled. Makes for some straight forward easy driving. Best running Bug I have driven was that 77 I refurbished. Wish that I was able to have kept it.
Have fun in it!
Jimbo
TDCTDI wrote:
61 BUS is offline
PostPosted: Sun Jan 15, 2023 2:01 pm    Post subject: Re: Converting Back to Fuel Injection Reply with quote
We're installing the correct L-Jetronic system and the engine will go back to 100% factory stock. I have supplied him with two complete original late Beetle FI systems that I purchased on The Samba from folks that went the other way.
vamram Premium Member
vamram is offline
PostPosted: Sun Jan 15, 2023 5:22 pm    Post subject: Re: Converting Back to Fuel Injection Reply with quote
Would be a nice extra if you could get your mechanic to document his build back to FI!
'75 Super Le Grande...we hardly knew ye. Sold 2025 for peanuts.
Click to view image
Save the Supers!!
Franklinstower
Franklinstower is offline
PostPosted: Sun Jan 15, 2023 8:28 pm    Post subject: Re: Converting Back to Fuel Injection Reply with quote
Question: have you sourced a gasket kit for the FI system? I thought most of the FI gaskets are not available anymore.
I'd love to rebuild my '75 fi bug engine, but I'm worried about getting it back together with a lack of the gaskets. As others have said, it's such a smooth running engine. So I might do nothing but enjoy it as is.
'89 Westy - EJ25/22 Frank 4.44 5mt
'75 Miami Blue Sunroof FI Standard Bug
YITB
MuzzcoVW
MuzzcoVW is offline
PostPosted: Wed Jan 18, 2023 5:47 am    Post subject: Re: Converting Back to Fuel Injection Reply with quote
There aren't many that are too FI specific and can be easily reproduced. The only place I've ever found the plenum gasket is BugCity in CT. He has other gaskets too...sometimes he's not cheap though
MuzzcoVW
MuzzcoVW is offline
PostPosted: Wed Jan 18, 2023 5:53 am    Post subject: Re: Converting Back to Fuel Injection Reply with quote
Have fun in it!
VW Jimbo, and 61 Bus I totally agree. When sorted it is THE best system. I love my '75. As far as that slight hesitation, I made a small mod to my distributor. I originally did it to clean up the idle with my 2280 cam. (excellent with the FI) A side benefit seems to be the elimination of that hesitation, or flat spot. The way it is now I run 10 degrees at idle and a max of 32. I believe it's the cam that allows me to run up to 32 with no detonation.
VW_Jimbo is offline
PostPosted: Wed Jan 18, 2023 9:37 am    Post subject: Re: Converting Back to Fuel Injection Reply with quote
Have fun in it!
Sounds like a great bandaid! The issue is the long intake tubes. As it was taught to me. The rush of air takes a few seconds to travel to fill the cylinders on the very onset, from the AFM. Not a big deal, but enough of one to cause that slight hesitation. It is one of many things that makes these cars so fun!
Let me know how the cam reacts. Every cam that was tried, high lighted that flat spot. I am not sure why. Really wishing I had become a mechanical engineer! Damn it!
Jimbo
61 BUS is offline
PostPosted: Sun Jan 22, 2023 8:11 am    Post subject: Re: Converting Back to Fuel Injection Reply with quote
For the gaskets that are no longer available, my mechanic was able to reproduce the necessary gaskets in the shop by cutting gasket stock to the correct profile.
Lost69Convertible
PostPosted: Sun Jan 22, 2023 10:10 am    Post subject: Re: Converting Back to Fuel Injection Reply with quote
Hi 61 Bus - I’d like to suggest you take a few pictures of the engine compartment now and as the work progresses. You can post them here for comments.
61 BUS is offline
PostPosted: Sun Jan 29, 2023 3:54 pm    Post subject: Re: Converting Back to Fuel Injection Reply with quote
The engine has been out of the car as it's being rebuilt, and that's almost done. Once it's installed, I'll post some pictures.
61 BUS is offline
PostPosted: Thu Feb 02, 2023 9:40 pm    Post subject: Re: Converting Back to Fuel Injection Reply with quote
Just drove the car back home today with the (original to the car) engine rebuilt. It's back to fuel injection!
DesignBuild
DesignBuild is offline
PostPosted: Fri Feb 03, 2023 12:37 am    Post subject: Re: Converting Back to Fuel Injection Reply with quote
If I were you I would get those wires near the belt tied down. If you don't they will get wrapped around the alternator or crankshaft pulley.
Another route to go is to install the Mexican Beetle fuel injection. The only thing in the manifold is air. The fuel is injected at the intake valve. Modern fuel injection systems have dry intake manifolds (no fuel and air mixture).
I am working on a system adapting the Ford EEC-IV sequential fuel injection to my 1972 Super. I may have to use a chip to change the Ford firing order to that of the VW.
busdaddy
busdaddy is offline
PostPosted: Fri Feb 03, 2023 9:12 am    Post subject: Re: Converting Back to Fuel Injection Reply with quote
Slick! Cool You won't be sorry.
Слава Україні!
busdaddy
busdaddy is offline
PostPosted: Fri Feb 03, 2023 9:14 am    Post subject: Re: Converting Back to Fuel Injection Reply with quote
Those wires are usually pretty stiff, and not really long enough to get under the belt, you have to try pretty hard to F them up.
And L-jet's injectors are at the ports, the only time there's fuel in the manifold is during cold starts.
Слава Україні!
DesignBuild
PostPosted: Fri Feb 03, 2023 1:09 pm    Post subject: Re: Converting Back to Fuel Injection Reply with quote
Is this the same system that was used in the early American Rabbits where there is continuous injection?
What were some folks referring to when they were talking about hesitation?
MTT3107
MTT3107 is offline
PostPosted: Fri Feb 03, 2023 3:49 pm    Post subject: Re: Converting Back to Fuel Injection Reply with quote
Glad that you are happy with your once again fuel injected bug !
But that engine compartment is the stuff of nightmares ! Very Happy Very Happy
busdaddy
busdaddy is offline
PostPosted: Fri Feb 03, 2023 6:01 pm    Post subject: Re: Converting Back to Fuel Injection Reply with quote
No, the Rabbit CIS is basically K-jet, apples and oranges compared to L-jet. Injection pulse length is determined by air flow, RPM and temperature, vacuum levels manipulate fuel pressure to richen or lean with load variations. It's batch fire so each cylinder gets 1/2 of what it needs onto the intake valve each revolution, two revs make a cycle.
It's dirt simple and almost bulletproof, most issues result from vacuum leaks or old corroded wire terminals, or dumbshit mechanics who think it's witchcraft and don't make an effort to understand it. Once you open up your mind and realise how it thinks it's easier to adjust than a carb.
Слава Україні!
