Type 3 Tow Bar?
Chaznsc
Chaznsc is offline
PostPosted: Wed Aug 08, 2012 2:14 pm    Post subject: Type 3 Tow Bar? Reply with quote
Anyone know if a tow bar is available for the Type III?
Erik G
Erik G is offline
PostPosted: Wed Aug 08, 2012 2:37 pm    Post subject: Reply with quote
Not commercially available. I have been meaning to ask Jeremy (jeremyrockjock) I'm sure he can make them for us, or modify his existing bus ones
http://www.thesamba.com/vw/classifieds/detail.php?id=280516
I think ours just need to be longer bug ones really.
blankmange
Type 3 Darksider
blankmange is offline
PostPosted: Wed Aug 08, 2012 2:45 pm    Post subject: Reply with quote
I have asked Jeremy about them in the past, he said that he wouldn't be making them for us....
póg mo thóin
Certified DHS Technician
Samba Member # 24517
Bobnotch
Bobnotch is offline
PostPosted: Wed Aug 08, 2012 5:06 pm    Post subject: Modified Super Beetle to Type 3 Towbar Reply with quote
Secretary Sue here,
I'm writing this under Bob's name, cuz the pics are all in his name, in T3 parts and accessories. These pics are from 2008, when Bob needed to make up another Type 3 Tow Bar, cuz our other one that he made was still down in Texas.
I've included the caption, and the pics in hopes that it'll make searching for it here in the Type 3 forum easier.
(quote)
Since this question comes up quite regularly, here's how to modify a Super Beetle towbar for use as a Type 3 towbar.
After I cut off the "ears" on the Super bug towbar, I welded on 24" long, 2" diameter tubes to extend the total length and then welded the "ears" back on to each tube end. I also added a 21 inch long , 1 1/2" X 1 1/2 " piece of angle as a crossbar for extra support.
(end quote)
Bob 65 Notch S with Sunroof
Tram wrote:
Tram wrote:
pedro sainz
pedro sainz is offline
PostPosted: Wed Aug 08, 2012 5:47 pm    Post subject: Re: Type 3 Tow Bar? Reply with quote
http://www.thesamba.com/vw/forum/viewtopic.php?t=364117&highlight=towbar
68 T34 1600 Automatic
62 T34 Cabriolet Prototype
N.O.N.A member #3
The Truth is Out There
Shakey
Shakey is offline
PostPosted: Thu Aug 09, 2012 2:23 am    Post subject: Reply with quote
I went the other direction and built a mount on the car. Then use a bug tow bar to hook up to the mount. Towed from Boise to Spokane a few times, Boise to Omaha once and the 2012 Invasion and back to Omaha never had a issue. All at Interstate speeds +5-10 mph. The mount protects the spare tire well also.
71 DD Squareback
Type 3 The VW with the "bugs" worked out
Bill Jacobs
Bill Jacobs is offline
PostPosted: Thu Aug 09, 2012 8:13 am    Post subject: Reply with quote
Here is a picture of the one I had made. Uses a bug tow bar. You have to remove the spare tire well while it is mounted
Erik G
Erik G is offline
PostPosted: Thu Aug 09, 2012 1:55 pm    Post subject: Reply with quote
Jeremy hit me up that he would like to, but does not have access to a Type 3 to do the R&D work. Do we have any T3 Peeps in Richmond Virginia?
hilton
hilton is offline
PostPosted: Fri Aug 10, 2012 6:06 pm    Post subject: Reply with quote
I'm in Danville, about 2 hrs from Richmond depending on where he's at.
hilton
hilton is offline
PostPosted: Sat Aug 11, 2012 7:52 pm    Post subject: Reply with quote
BTW, its not running so he'll have to come here lol
Bobnotch
Bobnotch is offline
PostPosted: Sun Aug 12, 2012 6:54 am    Post subject: Reply with quote
I really like the "modified super beetle" tow bar, as it was easy to convert, can still be used on a super beetle, fits both early and late t-3s (even clears the OE fuel pump location). The pics above that Sue posted, show what is needed to modify one. Once I had the extra length tubes, and the "U" bolts, it took about 1.5 hours to set and weld everything up. The mounting plate can even stay attached to the beam, IF you're not too low in front (no more than a 2 inner spline drop). Wink
I also built one like Bill Jacobs did. This was back in 2000 though. I even did a write up for building one on both STF, and here, as Richard Green needed something to move his t-3, and didn't have the extra cash laying around to rent a trailer or tow dolly. And yes, it works pretty good too, but I found that you had to remove the spare tire and it's tray to use it. That's something that you don't have to do with the modified super bug tow bar. Cool
Tram wrote:
Tram wrote:
reay
reay is offline
PostPosted: Sun Aug 12, 2012 1:56 pm    Post subject: Reply with quote
I kind of figured out a design( with Dave Whitaker, another T34 owner) for a T34 tow bar based on Jeremy's design and the clearances we need. Jeremy said he would give it a shot, but again he needed a T34 to make sure it would work.
If anyone wants the AutoCadd drawing, let me know.
Tom Reay
Nothing is standard o a Standard!
68 Karmann Ghia Sunroof / auto T345
66 Standard Microbus T221
66 1200a Standard 115 with factory ragtop
heavyfoot23
heavyfoot23 is offline
PostPosted: Mon Mar 11, 2013 12:38 pm    Post subject: Reply with quote
I would LOVE a copy of the AutoCAD drawing for the tow bar.
[email protected]
I'll do what I can to get it built and let you know if it works on my T34.
- Steve
--1964 VW Type 34
--1965 VW Type 34
--1964 VW Type 34 Sunroof
jeremyrockjock
Samba Towbar Builder
jeremyrockjock is offline
PostPosted: Sat Feb 04, 2023 4:24 pm    Post subject: Re: Type 3 Tow Bar? Reply with quote
I have finally come out with a Type 3 tow bar. It is a bracket that attaches to the opening of the front beam and the two lower beam bracket bolts. It stays attached to the car and then the tow bar attaches when needed.
Why buy what you can build.
Erik G
Erik G is offline
PostPosted: Sun Feb 05, 2023 7:16 am    Post subject: Re: Type 3 Tow Bar? Reply with quote
Awesome!
Bobnotch
Bobnotch is offline
PostPosted: Mon Feb 06, 2023 3:37 pm    Post subject: Re: Type 3 Tow Bar? Reply with quote
The only problem I see with that plate set up, is that some of us who use the Airtex E2000 electric fuel pump move our pumps to that middle opening, versus keeping the fuel pump in the stock opening and kinking the fuel hose.
That's not taking into account that some of the guys who want to get even lower are relocating that lower beam clamp bolt and hole (on each side). Just a few thoughts.
It looks like for a stock height non FI car it would be a great solution.
Tram wrote:
Tram wrote:
old_man
old_man is offline
PostPosted: Mon Feb 06, 2023 5:39 pm    Post subject: Re: Type 3 Tow Bar? Reply with quote
Interesting design for the hook up. Sort of similar to what I did once. Yours probably has a bit more ground clearance though.
https://www.thesamba.com/vw/forum/viewtopic.php?t=737257&highlight=
jeremyrockjock
PostPosted: Tue Feb 07, 2023 4:40 pm    Post subject: Re: Type 3 Tow Bar? Reply with quote
Thanks for the feedback Bobnotch. I know next to nothing about type 3s so any feedback is appreciated. Is the pump relocation something I could add a bracket for?
Yeah old_man I saw your design and I do like it Thumbs Up I was trying to make it all in one piece for easier installation.
Again any feedback is appreciated.
Bobnotch
Bobnotch is offline
PostPosted: Wed Feb 08, 2023 2:15 pm    Post subject: Re: Type 3 Tow Bar? Reply with quote
I think an FI type3 owner who has already converted to the Airtex style pump, would probably zip tie the pump out of the way while using the tow bar plate. Keep in mind that the pump bracket uses 2 pieces of steel trapping the lip (sandwiched) with 2 M-6 studs on rubber bushings. The pump normally resides in the far right opening (LHD cars), hence why the hose from the tank to pump has a tendency to kink, and why we relocate the pump to the middle due to it's length (the pump itself). If an FI owner still uses the stock pump, then there's no problem with the plate mount set up. Same applies to the carb cars, as there's nothing attached to the beam in that area.
I hope this helps.
Tram wrote:
Tram wrote:
Multi69s
Multi69s is offline
PostPosted: Sat Feb 18, 2023 2:53 pm    Post subject: Re: Type 3 Tow Bar? Reply with quote
Jeremy,
I really like the look / design of your tow bar. However, I would recommend making it a little heaver duty, especially where the bar attaches to the frame head unit. My family has been into Volkswagens my whole life, and we had many adventures where we would flat tow a VW. Thus I have seen many scary moments when flat towing. From the towed car having a blowout, to an attachment pin breaking or falling out. When you see a car that is being towed slewing across the lane, it is a very scary moment.
This is especially true if you plan to sell them. You never know what a person may do or forget to do when hooking up, and they could try and hold you liable.
69 road Bug 2110
73 Squareback - 2L, T4, Automatic W/ AC
Gone, but many fond memories 69 Baja Bug 2010 - 5 Rib Bus Transaxle
Gone but not forgotten 72 Baja Bug 2010
My builds
T4 into Squareback http://www.thesamba.com/vw/forum/viewtopic.php?t=458944&highlight=
Auto Trans Rebuild http://www.thesamba.com/vw/forum/viewtopic.php?t=516066&highlight=
AC in Squareback https://www.thesamba.com/vw/forum/viewtopic.php?t=...highlight=
