OE cv axles fit across WBX years
Mckinleyvillian
Mckinleyvillian is offline
PostPosted: Fri Feb 10, 2023 12:18 pm    Post subject: OE cv axles fit across WBX years Reply with quote
Having trouble finding this info, but i'm needing to reboot and looks like PO had put some cheapo empis across the board.
my van is an 85 manual tin top and I've got access to OE axles and joints from an 86 manual westfalia. Any reason these won't work out?
thanks
so many roads i know
all i want is one to take me home
85 Vanagon GL 1.9 stick
djkeev
djkeev is offline
PostPosted: Fri Feb 10, 2023 3:58 pm    Post subject: Re: OE cv axles fit across WBX years Reply with quote
thanks
I don't have the exact details but I understand that there were minor axle changes during the production run. Air Cooled, Diesel, etc.
Automatic axles will NOT fit.
Ghia
Vanagon
Beetle
crazyvwvanman
crazyvwvanman is offline
PostPosted: Fri Feb 10, 2023 4:03 pm    Post subject: Re: OE cv axles fit across WBX years Reply with quote
The WBX axle length was unchanged over the WBX years.
Older vans had slightly longer axles.
The Bentley only gives the lengths for the early longer ones.
The difference between early and wbx is small, something like 1/4".
Mark
Mckinleyvillian
PostPosted: Fri Feb 10, 2023 4:24 pm    Post subject: Re: OE cv axles fit across WBX years Reply with quote
Awesome. This is in-line with what I was thinking. Wasn’t sure however if there were shifts between 1.9-2.1 transition. Thank you both.
ALIKA T3
ALIKA T3 is offline
PostPosted: Sat Feb 11, 2023 7:45 pm    Post subject: Re: OE cv axles fit across WBX years Reply with quote
I posted all axle lengths not too long ago here:
https://www.thesamba.com/vw/forum/viewtopic.php?p=9937643&highlight=axle+length#9937643
Driveshaft, axle lengths:
251501203 548mm, 091 transmission and superceded by 251501203G 094 Syncro, 548mm as well.
251501203D, 541mm 091/1+ 094 transmissions 2WD.
251501201G Syncro 16" (28 splines anyway vs 33splines)
251501203A 531mm 090 early (aircooled) Left side
251501203E 522mm 090 Left side
251501204 579mm 090 early (aircooled) Right side
251501204B 570mm 090 Right side
Mckinleyvillian
PostPosted: Sat Feb 11, 2023 8:48 pm    Post subject: Re: OE cv axles fit across WBX years Reply with quote
that's dope. thanks. you IG is pretty rad too Shocked
ALIKA T3
ALIKA T3 is offline
PostPosted: Sat Feb 11, 2023 9:35 pm    Post subject: Re: OE cv axles fit across WBX years Reply with quote
Mahalo Razz
What's your handle?
djkeev
djkeev is offline
PostPosted: Sun Feb 12, 2023 6:48 am    Post subject: Re: OE cv axles fit across WBX years Reply with quote
Great axle info!
I added this to the FAQ section Clutch & Transmission General Information.......
https://www.thesamba.com/vw/forum/viewtopic.php?p=6236053#6236053
Dave
Ghia
Vanagon
Beetle
