Any interest in Honda K-swap motor mount kit? |
Yes |
36% |
[ 34 ] |
Yes - if there was a full kit |
50% |
[ 47 ] |
Intriguing but No |
7% |
[ 7 ] |
No way |
5% |
[ 5 ] |
Total Votes : 93 |
kguarnotta Samba Member
Joined: April 01, 2004 Posts: 1207 Location: Woodstock, NH
Posted: Tue Jan 17, 2023 10:02 am Post subject: Re: Any interest in Honda K-swap motor mount kit? |
count me as a supporter...
I've got an EJ22 in mine now. It is pretty tired, and I've been trying to think of the future - and what I would do if it needed a serious rebuild or overhaul. I've been ok with the power this provides, not loving it on the hills/mtns of NH.
From what I can tell these engines are getting a bit harder to find, so some system that is based on a newer engine sounds good to me.
I'll go check out your thread...
thanks for your work investigating this. _________________ -Kevin
Lincoln, MA
2001 Eurovan
'86 Triple Knob Syncro w/EJ22
'78 Westy
'69 Single Cab
'65 Kombi - EZ-Camper |
Bradgt74 Samba Member
Joined: May 04, 2009 Posts: 251 Location: Minneapolis
Pchill2 Samba Member
Joined: November 19, 2021 Posts: 410 Location: Georgia
Posted: Sat Feb 04, 2023 9:52 am Post subject: Re: Any interest in Honda K-swap motor mount kit? |
Bradgt74 wrote: |
In MN, we tend to work on our VWs over the winter and enjoy them in the summer. My WBX will be in a good place for the 2023 season, but a Honda swap could be a good project to implement next winter! |
We do the same thing down south but for different reasons. Too hot and humid to work on it during the summer! _________________ 87 Syncro Westy
Honda K24 swap |
markswagen Samba Member
Joined: January 28, 2018 Posts: 1555 Location: san diego
Posted: Sun Feb 05, 2023 12:59 pm Post subject: Re: Any interest in Honda K-swap motor mount kit? |
l think if it were CARB compliant, you'll be finding more inquiries.
obviously California, now Colorado, l suspect other states will follow.
getting subaru stuff, is getting more difficult. _________________ markswagen {mobile mechanic} san diego area all early VW's cared for.
619 201 0310 |
Posted: Fri Feb 10, 2023 2:33 pm Post subject: Re: Any interest in Honda K-swap motor mount kit? |
Got some mock-ups completed for some testing. What I like about this setup is the additional clearance around the engine as opposed to the cradle design.
Lots of space cleared up for the exhaust routing and is likely compatible with some performance headers on the market. Also space to run a turbo outlet under the engine near the transmission rather than routing around the rear of the vehicle.
The 3/16” plate basically maxes out my welder but I’ll probably be picking up a new tig machine now that I have a shop.
Fully bolt on setup:
This is just the first pass proof of concept though so it will be changing significantly from this design. _________________ 87 Syncro Westy
Honda K24 swap |
Silverghost500 Samba Member
Joined: August 01, 2018 Posts: 1198 Location: Atlanta, GA
Posted: Sat Feb 11, 2023 5:35 am Post subject: Re: Any interest in Honda K-swap motor mount kit? |
I like it! Much cleaner design than a mid-mount cradle system. This also keeps the engine at the 15 degree tilt, correct?
Should still have plenty of room to replace the accessories belt if needed. _________________ 1986 Volkswagen Vanagon Westfalia "Von Westy"
Honda K24A conversion
3-Speed Automatic
Von Westy YouTube Channel
https://www.youtube.com/channel/UCbhyZYxJEQrUuLnMbLleeIA |
Posted: Sat Feb 11, 2023 7:52 am Post subject: Re: Any interest in Honda K-swap motor mount kit? |
Silverghost500 wrote: |
Should still have plenty of room to replace the accessories belt if needed. |
The engine is still at the same tilt angle. Also the belt can be serviced easily.
You can access the auto tensioner bolt through the license plate door. _________________ 87 Syncro Westy
Honda K24 swap |
Zeitgeist 13 Samba Member
Joined: March 05, 2009 Posts: 12168 Location: Port Manteau
Posted: Sat Feb 11, 2023 12:36 pm Post subject: Re: Any interest in Honda K-swap motor mount kit? |
What kind of mounts are those? This is the engine mounting direction I've been intending for my ALH swap @ 15 degrees. The ALH also has a center mount pendulum bracket which can be used similarly to your Honda setup. Ditching the underslung cradle has a lot of benefits I can see. _________________ Casey--
'01 Weekender --> full camper
y u rune klassik? |
Borg Samba Member
Joined: October 18, 2012 Posts: 131 Location: Western Washington
Posted: Sun Feb 12, 2023 11:33 am Post subject: Re: Any interest in Honda K-swap motor mount kit? |
This is looking like a well sorted swap, definitely on my radar should my aging EJ22 decide it has had enough.
As a potential swapper the hurdle most likely to cause my brain to freeze is the wiring harness. I can do a lot of things. Built my house and boats, cast bronze sailboat hardware, sew sails, cut weld grind sheetmetal, pull an engine and put it back in but trying to fathom a wiring diagram, especially one converting from one engine to another usually just leaves me buffaloed. Two thumbs up to the fellow who I bought my already converted van from 20 years ago because it runs just fine (on the electrical end, it is the mechanical bits that are wearing out) but he left behind a rats nest of wiring that I've taken a "leave well enough alone" stance on. The thought of working through a VW-Subaru-Honda swap is particularly daunting. It was a saving grace when restoring my '68 Bronco to be able to simply order a new wiring harness.
I don't think I'm alone in this and that a lot of folks would be helped by a comprehensive easy to understand for the layman wiring manual. Some people have 5-digits worth of money spend by dropping the van off and picking it up later, the rest of us with 4-digits worth need to be able to pull the van into the garage and spend a winter doing transplant surgery. _________________ Steve |
Posted: Sun Feb 12, 2023 4:24 pm Post subject: Re: Any interest in Honda K-swap motor mount kit? |
@Borg, valid concerns regarding the electrical systems. It's a critical component of a conversion that can either make or break the success and enjoyment.
I'm pursuing a K24 swap after seeing Pchill2's K-swapped Syncro in person. I've done quite a bit of research the past few months on ECU and wiring harness options. What has been impressive is the community of automotive enthusiasts who are swapping K24's into other vehicles. It's a matter of applying their lessons learned to adapting the engine to a Vanagon.
It would be great if we can get to a point of standardizing which aftermarket ECUs and wiring harness options to go with for these K-swap conversions. That way more people can adapt and enjoy rather than looking at Mom's spaghetti of an electrical wiring mess. _________________ 1986 Volkswagen Vanagon Westfalia "Von Westy"
3-Speed Automatic
Posted: Mon Feb 13, 2023 7:18 am Post subject: Re: Any interest in Honda K-swap motor mount kit? |
Something else that's great about this second gen engine mount design is the ability to have custom oil pans if someone wanted one. With some conversion cradles you have to think ahead about what oil pan you can use due to interference. _________________ 1986 Volkswagen Vanagon Westfalia "Von Westy"
3-Speed Automatic
Posted: Mon Feb 13, 2023 8:02 am Post subject: Re: Any interest in Honda K-swap motor mount kit? |
The wiring is very simple using an aftermarket version of the Acura RSX-S engine harness (All aftermarket K-swap harness are based off of RSX-S). A Hybrid Racing universal K-swap chassis harness includes pre-wired relays for fuel pump and O2 sensor and includes flying leads to connect to the 7-pin Vanagon engine harness plug that goes to the gauges and also a power wire for the ECU and relays.
All of the wiring components:
Mounted to a tail light pocket block off plate:
Flying leads on the right to connect in the Vanagon black box:
I did have to re-pin a few of flying lead wires to get the correct outputs from the ECU plug to the Vanagon connector for the gauges to function properly. Also the Bostig tach signal corrector and GoWesty variable resistor for coolant gauge will need to be added. My build thread has a link to the spreadsheet which includes a wiring pinout. _________________ 87 Syncro Westy
Honda K24 swap |
Posted: Tue Feb 14, 2023 9:55 am Post subject: Re: Any interest in Honda K-swap motor mount kit? |
There's a couple of different style and spec wiring harnesses for using with the Hondata ECU systems:
-regular FWD (front wheel drive)
-tucked FWD
-Mil-Spec FWD (heavy duty aerospace/military-spec materials)
-RWD (For Rear Wheel Drive Conversions)
I've sent inquiries to some of the wiring harness vendors about harness length. If a RWD conversion harness is long enough the Hondata ECU, fuses, and relays should be able to fit where the VW Digifant system resides under the bench seat protected from weather.
If one of the other FWD harnesses is used, then you could fit it in the left rear space in the engine bay with a weatherproof solution like Pchill2 did on his conversion. Or...might be able to fit the components in that space under the cabinet if your Vanagon is a Westy or Weekender. _________________ 1986 Volkswagen Vanagon Westfalia "Von Westy"
3-Speed Automatic
vanis13 Samba Member
Joined: August 15, 2010 Posts: 4456 Location: ABQ NM USA.... Except when not
Posted: Tue Feb 14, 2023 10:05 am Post subject: Re: Any interest in Honda K-swap motor mount kit? |
re: ECU Location - I put my Subi ECU/Relays on the bottom of the Westy closet. It is effectively dead space anyway. my AC hoses go up there anyway so just enlarged that hole a bit. Even with the later AC hoses going up the corner pillar, I believe the westy cabinet is a good place for the ECU since the space under the rear of the cabinet is nice to slide things like tools or some other more readily needed things in/out of - and if you cut off the angled section, a nice rectangular box fits there. _________________ 83.5 Westy with Subaru 2.5, 4 spd manual, center seat, COLD A/C on 134a!, Winter camp heated with an Espar B4 gasoline furnace
www.SuperVanagon.com - some stuff I make |
Posted: Wed Feb 15, 2023 9:20 am Post subject: Re: Any interest in Honda K-swap motor mount kit? |
That would be a great place to mount the ECU and electrical components. As long as the USB port on the Hondata ECU can be easily accessed it would be fine. The OBDII port on the universal conversion harness could be mounted with some L brackets under the cabinet for easy access.
For tin top Vanagons without camping cabinetry a panel could be made to fit behind the interior panel. _________________ 1986 Volkswagen Vanagon Westfalia "Von Westy"
3-Speed Automatic
blue72beetle Samba Member
Joined: April 23, 2008 Posts: 893 Location: Fort Wayne, IN
Posted: Wed Mar 15, 2023 6:31 pm Post subject: Re: Any interest in Honda K-swap motor mount kit? |
How's the clearance to the firewall? I'm thinking of doing this with my 71 Bay Window, the throttle body looks like it'd be awfully close to the firewall.
I'm not sure how a Vanagon firewall compares to a Bay Window. _________________ -Andy-
-1970 Ghia-
-1971 Bus Ongoing EJ22 Conversion- |
vanagonjr Samba Member
Joined: October 07, 2010 Posts: 3635 Location: Dartmouth, Mass.
Posted: Wed Mar 15, 2023 7:34 pm Post subject: Re: Any interest in Honda K-swap motor mount kit? |
Pchill2 wrote: |
I removed the thick foam sound deadening and replaced it with a thinner dynamat style sound deadening material and also trimmed some sections of the ribbing. An aftermarket low profile valve cover was also necessary. No raised deck lid necessary. |
Note that if it just fits in a Syncro, it will likely need a 2” raised lid for the 2WD version.
Also note, I find a 2” lifted engine cover is no big deal to me, as that’s what I have now. _________________ John - 86 Wolfsburg Westfalia "Weekender"
FAQ thread: http://www.thesamba.com/vw/forum/viewtopic.php?t=525798 |
Posted: Thu Mar 16, 2023 6:54 am Post subject: Re: Any interest in Honda K-swap motor mount kit? |
vanagonjr wrote: |
Pchill2 wrote: |
Also note, I find a 2” lifted engine cover is no big deal to me, as that’s what I have now. |
2WD vans would not need to raise the deck lid with this setup. _________________ 87 Syncro Westy
Honda K24 swap |
Posted: Thu Mar 16, 2023 7:07 am Post subject: Re: Any interest in Honda K-swap motor mount kit? |
blue72beetle wrote: |
I'm not sure how a Vanagon firewall compares to a Bay Window. |
I can take a measurement for you if needed. I'm using the RBC intake manifold which is not the factory intake manifold for the K24a4/a8 from the Accord. This intake manifold pushes the throttle body closer to the firewall and higher up towards the deck lid than the factory Accord intake manifold would so my swap is "worst case".
I will say though that there are many aftermarket intake manifolds available for K-series engines including center feed style intake manifolds which would eliminate any clearance issues you may have in a bay window all together.
Here is one of the many center feed manifolds for k-series:
https://skunk2.com/media/PR/Skunk2%20Centerfeed%20Manifold.pdf
The world is your oyster. _________________ 87 Syncro Westy
Honda K24 swap |
