Vokaro project car
Page: Previous  1, 2, 3 ... 7, 8, 9 ... 14, 15, 16  Next
Rome
Rome is offline
PostPosted: Sun Nov 27, 2022 7:33 am    Post subject: Re: Vokaro project car Reply with quote
Your extended chassis and body create a much more "mature" vehicle appearance than the original Vokaro. Looking forward to progress as you work through the component fitment challenges.
DeathBySnuSnu
DeathBySnuSnu is offline
PostPosted: Wed Nov 30, 2022 7:25 pm    Post subject: Re: Vokaro project car Reply with quote
Yeah well.....it is not just little bit longer.....it is a lot lower.
Drop spindles, adjusters, pie cut, relocated Napoleon hats.......and a major body drop
Look at that down hill bar from the torsion tube to where it used to live at.
modok wrote:
And look at the SHAPE of the curves, just smooth, like gods own slingshot. .
DeathBySnuSnu
PostPosted: Mon Dec 05, 2022 6:35 pm    Post subject: Re: Vokaro project car Reply with quote
The assembled rack and pinion.
slayer61
slayer61 is offline
PostPosted: Tue Dec 06, 2022 9:16 am    Post subject: Re: Vokaro project car Reply with quote
Man, we need a "like" button! Cool
Cusser wrote:
... Most folks are idiots when it deals with electrical !!!
67rustavenger wrote:
3/4 race cam? What's missing, one of the lobes? Shocked
Paul
'68 Manx clone... Sears??
RLR/Strange brakes
2276 built on AS21 case
W-125 w/ GB 1.25:1 rockers
Mahle forged pistons
CB 4340 crank
CB H beam rods
deep sump
45 DCOE
Garrett turbo (pending)
Tim's stage II turbo heads (pending)
MSD Box and distributor
Car Craft turbo header
View user's profile Send private message AIM Address Yahoo Messenger MSN Messenger Facebook Twitter Instagram Gallery Classifieds Feedback
DeathBySnuSnu
PostPosted: Sun Dec 11, 2022 5:03 pm    Post subject: Re: Vokaro project car Reply with quote
And some of the back end going together.
I did get the 28mm torsion bars set......at least for now.
It is just right..... right now.....I am guessing by the time all is together and settled in that I am going to need an upward adjustment .
DeathBySnuSnu
PostPosted: Sat Jan 21, 2023 10:44 am    Post subject: Re: Vokaro project car Reply with quote
Annnnd poof there goes a whole post.
Now to do it again.
Have not had much to me lately....lotsa work and a sickly wife. So most work as been small items.
Got the dial indicator and the degree wheel and found the sync for the distributor drive. Got the drive dog pinned on....which completes my Chevy distributor in a Mazda mod.
Made the throttle linkage and cables up.
In the meantime I have been jumping on the rear trying to settle the new springs. Seems to have worked. I have re-indexed the springs and put in the brake lines and axles.
Buggeee
Buggeee is offline
PostPosted: Sat Jan 21, 2023 8:03 pm    Post subject: Re: Vokaro project car Reply with quote
Such a beautiful build. Just Gorgeous.
Big Time 1988 Vanagon Westy
Dr. Kompressor 72 Super Duper
61 Turkis Pile (adopted out)
DeathBySnuSnu
PostPosted: Sun Jan 22, 2023 1:52 pm    Post subject: Re: Vokaro project car Reply with quote
This thing is more uneven and lopsided that you can see in the pictures.
The wheelbase/chassis/suspension is all in square/alignment. I cut the fender wells to make that happen.
But the rest of the body is up to an inch lopsided. Some of it averaged out.....some of it just had to be lived with.....or hack the whole body up into sections and remake the whole thing.
DeathBySnuSnu
PostPosted: Sun Feb 05, 2023 12:59 pm    Post subject: Re: Vokaro project car Reply with quote
The rear sub frame is going together.
DeathBySnuSnu
PostPosted: Sat Feb 11, 2023 7:51 pm    Post subject: Re: Vokaro project car Reply with quote
Made the gas tank ....
DeathBySnuSnu
PostPosted: Sun Feb 19, 2023 2:15 pm    Post subject: Re: Vokaro project car Reply with quote
Spent a my half a day making an off thermostat neck.
One more part done....
DeathBySnuSnu
PostPosted: Thu Mar 02, 2023 8:24 am    Post subject: Re: Vokaro project car Reply with quote
Mechanical nearly done.
Making catch cans now.
67rustavenger
67rustavenger is offline
PostPosted: Thu Mar 02, 2023 6:15 pm    Post subject: Re: Vokaro project car Reply with quote
I have been checking in on your progress every once in a while.
This is going to be a very sexy car, when it's completed.
Just looking at your fabrication on the frame, engine, body, looks like the car is in good hands.
When the time comes. Please post a vid of the engine running. We really wanna hear it running. Wink
Keep up the great work!
Buy Once, Cry Once!
GFY's Xevin and VW_Jimbo!
DeathBySnuSnu
PostPosted: Sun Mar 19, 2023 8:44 am    Post subject: Re: Vokaro project car Reply with quote
Have been on the little things.....brakes are done and functional. E brake cables done. Hoses/fittings/cables.
So no exciting pictures or changes.
Catch can.....
Rome
Rome is offline
PostPosted: Sun Mar 19, 2023 9:12 am    Post subject: Re: Vokaro project car Reply with quote
Have you put some weight on the rear of the chassis to make sure that the inside of the rear right tire does not touch the right vertical face of your gas tank when the suspension is at full compression? I realize you have IRS so that there is minimal camber change but now is the time to make sure before all is assembled.
DeathBySnuSnu
PostPosted: Sun Mar 19, 2023 10:50 am    Post subject: Re: Vokaro project car Reply with quote
Yes.
The gas tank was made in place to fit ..... Mocked up and tacked together.....with no springs or snubbers installed....so on hard bottom.
That is also how the fender wells (cut and flair) were done......along with the ground clearance of the frame and body (roughly 2" at full bottom)
DeathBySnuSnu
PostPosted: Sun Mar 19, 2023 11:07 am    Post subject: Re: Vokaro project car Reply with quote
And here is the radiator fill and pressure cap.
Beside it is the puke can.
DeathBySnuSnu
PostPosted: Sun Mar 19, 2023 11:21 am    Post subject: Re: Vokaro project car Reply with quote
And.....the hoses are all made up and on the remote filter and oil cooler.
Filled with oil and primed up.
Engine spun over after priming and the tdi starter on a type 1 ring on a Mazda flywheel in a Porsche bell housing all worked.
Now that the cooling hoses are newly done it is time to fill with water and check all that for leakes.
I did quickly check the gas tank, but did not hyro it (pressurize and monitor with gauges). I think I will fill it with water and let it sit for a long time.
DeathBySnuSnu
PostPosted: Tue Apr 18, 2023 7:07 pm    Post subject: Re: Vokaro project car Reply with quote
With the mechanical mostly done I have been on electrical.
The "body" wiring is mostly done. All on toggles in the overhead operating relays.
Wiring the "engine" up now with the modified kit computer (in a box with a disguise.
And the battery wedged in the front.
DeathBySnuSnu
PostPosted: Mon May 01, 2023 4:51 pm    Post subject: Re: Vokaro project car Reply with quote
Still working on the electronics.....had some problems there. I will get there though.
Made a grill for the back end.
Still working out some shape ideas on what to do with the fiberglass. The rest of the body is made just gotta make something work on the back end
Page 8 of 16
