Alaskaberrys  Samba Member
Joined: June 19, 2016 Posts: 1085 Location: SE Alaska
Posted: Mon Jan 30, 2017 2:46 am Post subject: Mud Flap Install; Passenger Side - w/pictures and lots of words |
Hi All, (and feel free to skip to the pictures - it's not rocket science )
With the fact that I recently installed a Propex HS2211 under the floor on the passenger side of our van. And will be installing a 2nd LP tank in front of it right behind the passenger front tire, and coupled with the notion that a car should have at least two mud flaps or none at all - my sensibilities got the better of me and I decided to add the passenger side flap.
I found several very helpful non-flap-centric threads that answered some of my head scratching questions as to installing the front OEM mud flap(s) on our Westy. I was a bit confused as to just how they were held on, and once discovering that nifty trick, how the heck to achieve a good install without making Swiss cheese out of our van. Just so the reader is aware, drilling holes in our van requires an inordinate amount of spousal consultations and the right mix of alcohol - too much/too little of either (in either of us) and the job/marriage can go south pretty quickly (the Propex install was a doozy!).
About three beers into the research and exploration side of the job and a few hundred pages read, it seemed like a good idea to post a straight up mudflap install thread. Not to deny you all of beer-research time (bresearch?) - but to facilitate more beer-research time on even more daunting projects. Please note, this is not for the feint of heart - there are pictures of drilling perhaps unessesary new holes in a perfectly good van. Most drinking was done off camera however, so this should be ok for minors...
Soo....I have been steeling myself for the big job ever since ordering a passenger side OEM Flap from Van-Cafe a few months back -
http://www.van-cafe.com/home/van_1471674545219/page_905_167/original-mud-flap-right-side.html
Although Van-Cafe suggests mounting with just the underside bar without the 'dowels' is sufficient and perfectly acceptable, I wanted to replicate the original install on the drivers side and prove my worth to those forgotten German engineers, so I stepped up and ordered the 'dowel' kit too -
http://www.van-cafe.com/home/van/page_376_167/mudflap-hardware-kit.html
Now to install...
Prep for surgery.
Mount the undercarriage bar - there are holes already in frame but they had to be enlarged a bit to fit bolts that came with the kit.
As the side panel had no holes, it was pretty much up to me where to put them. The flaps have an indication for two holes - one top, one bottom so I pre-drilled the rubber flap there, covered with blue painters tape and drew a centerline to the edges for vertically locating the holes.
Then applied blue tape to the van panel and holding the flap up to the mounted undercarriage bar, checking position (other side was pretty much vertical so I kept this side vertice too), I traced the outline and transferred the hole center lines to the panel tape. I then marked the center of those lines.
Then the hard part
Next, after dabbing some cold galvanizing on the bare steel, I pealed off the blue painters tape only to discover that it lifted my 25 year old clear coat!?!
After some counciling from the spouse and another consultation beer, I added the 'dowels' (1/4" x 1-1/4" hanger bolts) threading the pointy end into the rubber, inserting the plastic expando type anchors into the van body, dab of silicone, held my breath and pushed real hard. Zip. Solid. Whew.
Add the reinforcement strap to the front side of the flap and sandwich the rubber between with some stainless bolts and nylock nuts and we're done!
I've heard the rear flaps require some mods to the fiberglass bumper returns, so I'll let someone else add that.
For me, now it's time to start looking up painting threads...oh, boy  _________________ '91 Westfalia, Bordeaux Red Pearl 2.1L 2wd Auto
'91 T3 Syncro Doka, Escorial Green 1.9L TD AAZ “Gremian” (to provoke, irritate, exasperate, vex...) |
spitsnrovers Samba Member
Joined: December 17, 2005 Posts: 946 Location: Calgary, Canada
Posted: Mon Jan 30, 2017 5:21 am Post subject: Re: Mud Flap Install; Passenger Side - w/pictures and lots of words |
Hey Alaska.... very nice write up. Liked the ideaof using the painters tape to transfer the measurements from the flap to the body.
Shame about the clear coat - and I thought the blue stuff was the least tacky, and less likely to cause damage. Maybe it was the green stuff  _________________ '88 VW Westfalia
'75 Triumph Spitfire 1500 |
E1 Samba Member
Joined: January 21, 2013 Posts: 8927 Location: Westfalia, Earth
Posted: Mon Jan 30, 2017 7:41 am Post subject: Re: Mud Flap Install; Passenger Side - w/pictures and lots of words |
An old trick for taking tack off of tape is to rub its length across a pant leg until it loses resistance and barely tries to stick on the pants, then apply and press flat with a rag. I've always found the 3M green tape to have less tack, but it's been decades since using it every day when a sign painter and pinstriper.
I pretty much followed your path when doing mine, but used a thin sheet of cardboard as a template and flipped it over for the right side. I measured several times, and used a smaller drill bit for a pilot hole.
Very enjoyable post, Thanks.
Totally missed out on the bresearch. My Bad. I hate regret.  _________________ If ever twice as rich, we’re gettin’ a double-wide
’84 “Westfailure”/2.1 Digijet/5.43 Ring & Pinion/Peloquin/D-rated BFG KO2s
AI has spoken to further illiteracy, to steal, to cheat, and to replace humans
The caveman’s first question to the headhunter: “Hey, you got any coffee?” |
Posted: Mon Jan 30, 2017 10:19 am Post subject: Re: Mud Flap Install; Passenger Side - w/pictures and lots of words |
| spitsnrovers wrote: |
Shame about the clear coat - and I thought the blue stuff was the least tacky, and less likely to cause damage. Maybe it was the green stuff  |
Thanks spitsnrovers, was fun to put together - and my hats off to those that put together pic heavy rebuild threads!
It was indeed blue tape but really old and seems a tad sticker then usual - I'd use the 3M Green as per E1's recommend above for any more body work. I notice the clear coat almost wants to come off right there, could be an age thing perhaps? Paint is on the horizon as lots of chips to metal on the front end and some deep scuffs here and there. _________________ '91 Westfalia, Bordeaux Red Pearl 2.1L 2wd Auto
E1 Samba Member
Posted: Mon Jan 30, 2017 10:29 am Post subject: Re: Mud Flap Install; Passenger Side - w/pictures and lots of words |
I believe the only reason 3M introduced the blue tape was because it bends MUCH better on tight curves.
They're both great products and both necessary for varied uses. For a project like this, though, I find regular masking tape to be less capable of pulling clear or any refinished single-stage paint, but even then the tack-dulling I mentioned above is a great safety factor. _________________ If ever twice as rich, we’re gettin’ a double-wide
Posted: Mon Jan 30, 2017 10:34 am Post subject: Re: Mud Flap Install; Passenger Side - w/pictures and lots of words |
| E1 wrote: |
Totally missed out on the bresearch. My Bad. I hate regret.  |
Thanks for the tip on the pant leg trick. Am thinking it was a really old roll as it would come apart when peeling off the roll - should have been an indicator. Still surprised me how easily the clearcoat came off.
Oh well, lots of bresearch opportunities in the paint threads! _________________ '91 Westfalia, Bordeaux Red Pearl 2.1L 2wd Auto
E1 Samba Member
Posted: Mon Jan 30, 2017 10:52 am Post subject: Re: Mud Flap Install; Passenger Side - w/pictures and lots of words |
Tape "comes apart" like this if it ever got too hot, or is really old.
Happy Times to You in your bresearch!
I started my double-line dealer striping by laying down three layers of 1/8" tape and painting between the tape. This all worked well until striping a poor repaint, and it was a mess in a hurry!
I was so embarrassed I only did freehand pinstriping from there on out. _________________ If ever twice as rich, we’re gettin’ a double-wide
stasharello Samba Member
Joined: September 15, 2016 Posts: 8 Location: Portland, OR
Posted: Wed Mar 28, 2018 8:02 am Post subject: Re: Mud Flap Install; Passenger Side - w/pictures and lots of words |
Alaska - What sized drill bit did you use for the grommet hole?
Thanks for such an awesome write up with the pictures, I'll be tackling this project in the next day or two. |
K58 Samba Member
Joined: July 01, 2006 Posts: 1173 Location: Santa Barbara
Posted: Mon Sep 17, 2018 8:50 pm Post subject: Re: Mud Flap Install; Passenger Side - w/pictures and lots of words |
| stasharello wrote: |
I just sent an email to alaska asking the same question.
I'm installing a set of rears.
stasharello, what did you go with?
Thanks _________________ Westy HID Projector Retrofit |
shagginwagon83 Samba Member
Posted: Tue Sep 18, 2018 9:53 am Post subject: Re: Mud Flap Install; Passenger Side - w/pictures and lots of words |
| K58 wrote: |
Thanks |
Dang, it seems that I failed to write that down. Probably so focused on putting a hole I the van my brain locked up.
As shagginwagin83 mentions it’s a 6mm grommmet so that 15/64 would be closest. I was using a small drill bit set that wouldn’t of had 64th’s so I’m guessing I was using a a 7/32. The grommets will give you some leeway. _________________ '91 Westfalia, Bordeaux Red Pearl 2.1L 2wd Auto
K58 Samba Member
Posted: Tue Sep 18, 2018 11:59 am Post subject: Re: Mud Flap Install; Passenger Side - w/pictures and lots of words |
| Alaskaberrys wrote: |
| K58 wrote: |
Thanks |
As shagginwagin83 mentions it’s a 6mm grommmet so that 15/64 would be closest. I was using a small drill bit set that wouldn’t of had 64th’s so I’m guessing I was using a a 7/32. The grommets will give you some leeway. |
That's what Alaska said from memory as well. Thanks for posting, _________________ Westy HID Projector Retrofit |
nestorwest Samba Member
Posted: Sun Feb 26, 2023 12:36 pm Post subject: Re: Mud Flap Install; Passenger Side - w/pictures and lots of words |
@alaskaberrys I just have to say this write up came in super handy when I installed mine. And when I replace one a year later. Thanks again! Love this community!
Posted: Sun Feb 26, 2023 1:03 pm Post subject: Re: Mud Flap Install; Passenger Side - w/pictures and lots of words |
| nestorwest wrote: |
Glad it helped. I agree, sooooo many helpful folks here that have put a lot into making great threads with lots of pictures on how they went about a process. Takes some effort and forethought. Wealth of info here! _________________ '91 Westfalia, Bordeaux Red Pearl 2.1L 2wd Auto
Buggeee  Samba Member
Joined: December 22, 2016 Posts: 5057 Location: Stuck in Ohio
MsTaboo  Samba Member
Joined: June 02, 2006 Posts: 4643 Location: East Kootenay, British Columbia
Posted: Sun Sep 01, 2024 12:09 pm Post subject: Re: Mud Flap Install; Passenger Side - w/pictures and lots of words |
The alternative is to mount the flaps closer to the front wheels, in front of the body crease.
This allows drilling holes into an exposed location instead of into a blind location and the use of stainless Nyloc nuts.
(note how much dirt is between the rear flap and the wheel - why VW located the rears so far back is a mystery)
Only close up pic I have showing flap location:
I believe mounting the flares here not only makes the job easier but seems to protect the side of the body better. With OEM flaps and Terrawagen flares.
Old shot of just spats but similar conditions.
_________________ Currently:
Resist Kleptocratic Oligarchy (and Idiocracy)! |
Posted: Sun Sep 01, 2024 11:41 pm Post subject: Re: Mud Flap Install; Passenger Side - w/pictures and lots of words |
| MsTaboo wrote: |
I do wonder why VW decided to use blind studs in the location they did. Forward does make mounting, and especially removal, that much easier. I had to pull my flaps off to repaint and had to then re-glue the studs back into the flaps to remount as they pulled out on removal. Would have been a lot easier via through bolting. But my OCD wouldn’t allow me to not replicated the factory mounting location on the drivers side. _________________ '91 Westfalia, Bordeaux Red Pearl 2.1L 2wd Auto
Last edited by Alaskaberrys on Sun Sep 01, 2024 11:53 pm; edited 2 times in total |
Posted: Sun Sep 01, 2024 11:43 pm Post subject: Re: Mud Flap Install; Passenger Side - w/pictures and lots of words |
| Buggeee wrote: |
| Buggeee wrote: |
| Great write up! Thank you, now I ain't skeered. |
Having benefitted from this thread and successfully installing the passenger side OEM style mudflap, my contribution to future generations will be confirmation of dimensions, expressed in inches, in the following blue-tape template transfered from the OG driver's side holes to the passenger side position:
Thank you OP! |
Most excellent idea!
[interesting side note, I just finally finished that repaint that this dang thread started with the clear coat lifting - 7 years (…and many beers) ago. My, how time - and beer - flies] _________________ '91 Westfalia, Bordeaux Red Pearl 2.1L 2wd Auto
Posted: Mon Sep 02, 2024 5:05 am Post subject: Re: Mud Flap Install; Passenger Side - w/pictures and lots of words |
[interesting side note, I just finally finished that repaint that this dang thread started with the clear coat lifting - 7 years (…and many beers) ago. My, how time - and beer - flies] |
Good news! I avoided that catastrophe following the advice of a poster in response to your experience, by putting the tape on my t-shirt first to reduce stickiness. This is a great thread through and through. _________________ Big Time 1988 Vanagon Westy
Dr. Kompressor 72 Super Duper
61 Turkis Pile (adopted out) |
