66 cal look
Forum Index -> Custom Wheel/Tire Share: Facebook Twitter
Score300
Score300 is offline
PostPosted: Wed Mar 15, 2023 6:49 pm    Post subject: 66 cal look Reply with quote
I'll start with I'm almost clueless about tire sizes. I've been scanning through Thesamba hoping to find my answers without asking but I'm unsuccessful.
I'm building my '66 beetle that I had when I was a kid. I bought 15x4 rims for the front and 15x6 for the rear. Adjustable beam on the front 2" narrowed with disc conversion. The back has 2" dropped spring plates. I'm wanting a somewhat aggressive stance. I'm trying to figure out what size tires to use. Any help and suggestions are appreciated.
Right now, I'm thinking something like 135/60 15 on the front and 205/60 15 on the back. I really wished I could see it on the car before buying them though.
'67 Doublecab
'67 Sportsmobile camper
'66 beetle (I sold this car in '94 and found it in 2021 by luck) in process of restomod back to '80s cal look.
'71 convertible (the wifes)
1963 ragtop
1961 ragto[
Glenn Premium Member
Mr. 010
Glenn is offline
PostPosted: Wed Mar 15, 2023 6:58 pm    Post subject: Re: 66 cal look Reply with quote
A 295/60 is too wide for a 6" rim and you'll need wider rear fender.
A 215/60 will fit and is pretty aggressive.
Glenn
Member #1009
#BlueSquare
עַם יִשְׂרָאֵל חַי
NJ John
NJ John is offline
PostPosted: Thu Mar 16, 2023 5:54 am    Post subject: Re: 66 cal look Reply with quote
I have 145’s on 4.5 rims and 205/60’s on 5.5 rims. 3” narrowed beam. I like the drag race look.
11.41 et buggy. Long gone
Let’s go O’s! Let’s go O’s!
Score300
Score300 is offline
PostPosted: Thu Mar 16, 2023 6:00 am    Post subject: Re: 66 cal look Reply with quote
Would you mind showing me a pic of your setup?
'67 Doublecab
1963 ragtop
1961 ragto[
slalombuggy
slalombuggy is offline
PostPosted: Sun Mar 19, 2023 8:16 am    Post subject: Re: 66 cal look Reply with quote
135s SUCK. They don't turn, they don't stop, there are far better choices for tires.
205/60s are a good choice. I've put as big as 215/65/15 on a 6" wheel in the rear of a swing axles car.
Mr. 010
Glenn is offline
PostPosted: Sun Mar 19, 2023 8:19 am    Post subject: Re: 66 cal look Reply with quote
Yup.. 195/55-15 front and 205/60-15 rear
Glenn
Member #1009
#BlueSquare
עַם יִשְׂרָאֵל חַי
Bryan67
Bryan67 is offline
PostPosted: Mon Mar 20, 2023 6:14 pm    Post subject: Re: 66 cal look Reply with quote
Since your title here says Cal Look. I`ll say 145/80X15 and 205/70x15.
If you`re going to do something, do it right.
NJ John
NJ John is offline
PostPosted: Tue Mar 21, 2023 3:46 pm    Post subject: Re: 66 cal look Reply with quote
Yeah, yeah original Cal Look, we know.
Bryan67
Bryan67 is offline
PostPosted: Tue Mar 21, 2023 10:04 pm    Post subject: Re: 66 cal look Reply with quote
And if you don`t like skinny tires, try a 175/65X15.
Rattlecan
Rattlecan is offline
PostPosted: Sat Sep 16, 2023 2:03 pm    Post subject: Re: 66 cal look Reply with quote
[img]
I looked through 100s of pages for tire sizes trying to get an idea of what would fit on mine. I just got this set up on my with 5.5 wide on the front and 6 wide on the rear. Thanks for putting your information out there it helped.
OutbackUSA
OutbackUSA is offline
PostPosted: Mon Oct 16, 2023 11:19 am    Post subject: Re: 66 cal look Reply with quote
Can you spec the offset and width of the rims you are using?
Thank you
Reply to topic    Forum Index -> Custom Wheel/Tire All times are Mountain Standard Time/Pacific Daylight Savings Time
