No lights on dash, no crank, no start.
459032 is offline
PostPosted: Mon Mar 20, 2023 1:19 pm    Post subject: No lights on dash, no crank, no start. Reply with quote
I did something dumb. While trying to set timing and idle, the afm touched the B+ on the alternator. Now no lights on the dash. How bad did I mess this thing up?
1978 VW Beetle convertible w/ FI
1978 VW Bus w/ FI
jeffrey8164
jeffrey8164 is offline
PostPosted: Mon Mar 20, 2023 1:25 pm    Post subject: Re: No lights on dash, no crank, no start. Reply with quote
Probably just popped a fuse or two.
Volkswagen!
(Compression 8.7:1)
ashman40
ashman40 is offline
PostPosted: Fri Mar 24, 2023 9:57 am    Post subject: Re: No lights on dash, no crank, no start. Reply with quote
The red wire connected to the B+ stud on the alternator has a direct path to the battery positive terminal. If you shorted this to ground you may have overloaded this wire. It is not fused.
Using a VM test the red B+ wire for 12v. If you don't get a voltage reading you need to trace this wire back thru the junction below the left rear seat (white rectangular junction) and then the wire that runs from the junction back to the positive battery post. Check for voltage at each junction. Look for signs of the wires or terminals overheating and melting insulation. If you see signs of over heating wires you may need to replace the wires.
Post pics of what you find.
The white junction below the left rear seat is also the point where everything up at the dash gets power from. If you don't get a 12v reading here it means no power is making it up to the front.
AshMan40
459032
459032 is offline
PostPosted: Fri Mar 24, 2023 11:15 am    Post subject: Re: No lights on dash, no crank, no start. Reply with quote
I found that junction. In my car it's just the red and white wire wrapped around each other then taped up. Is that how it's supposed be joined?
I started to take the tape off that junction and the car started to work.
1978 VW Bus w/ FI
Cusser
Cusser is offline
PostPosted: Fri Mar 24, 2023 12:14 pm    Post subject: Re: No lights on dash, no crank, no start. Reply with quote
No
Now you know what to fix CORRECTLY !
459032
459032 is offline
PostPosted: Fri Mar 24, 2023 2:19 pm    Post subject: Re: No lights on dash, no crank, no start. Reply with quote
How is it supposed to go? How is it normally connected?
1978 VW Bus w/ FI
Cusser
Cusser is offline
PostPosted: Fri Mar 24, 2023 4:32 pm    Post subject: Re: No lights on dash, no crank, no start. Reply with quote
I believe each end of the wire has a female push-on connector and fit into an insulated male/male connector.
https://www.jbugs.com/product/WW-CON.html
ashman40
ashman40 is offline
PostPosted: Sat Mar 25, 2023 7:57 am    Post subject: Re: No lights on dash, no crank, no start. Reply with quote
Found a pic from the gallery that shows the under seat wiring from a late model Beetle that came with an alternator.
You can see the large white rectangle. This is the junction for 4 wires...
    Battery positive terminal
    Alternator B+ output
    Main #30 wire running to the front of the car
    #30 wire to rear window defroster relay
The stock junction uses larger terminals than the normal 1/4" ones. The male spades inside are 3/8" wide. If your wires still have female terminals on the end you will need a junction that supports 3/8" wide terminals.
If you don't have this white junction or the ends of your wires have been stripped you just need a good junction to bring 3 or 4 higher amperage wires together. Something like this would work just fine:
4-8 AWG Distribution Block
If you decide to add a power distribution block below the rear seat you may also want to consider adding a 60-80A re-settable circuit breaker on the wire coming from the battery. This is extra insurance in case the circuit ever shorted directly to ground... as you apparently did.
These wires carry a rather large current (up to 55A from the alternator) so must have a rock solid connection to each other and must be insulated so they can never touch ground. Just twisting them together won't be good enough.
If you really want to do it on the cheap, you could look to your local hardware store and find a ground clamp that uses a threaded bolt to clamp a ground wire securely to a copper pipe/stake. This firmly clamps the wires together. You will need to carefully insulate the junction so it can never touch ground.
AshMan40
459032
459032 is offline
PostPosted: Sat Mar 25, 2023 10:02 am    Post subject: Re: No lights on dash, no crank, no start. Reply with quote
That’s exactly what I need. That whole white junction is missing.
1978 VW Bus w/ FI
